Fork seal leak and stanchion repair :(
john24ssj
PostPosted: 12:33 - 26 Mar 2016    Post subject: Fork seal leak and stanchion repair :( Reply with quote
Hi Guys,
So my fork seal started leaking I took the forks a part and realised that the stanchion is at fault here as it has small rust bumps in it which cut the seal.
I can't afford a new stanchion is there any way I could repair it?
Thanks
Bikes: Honda CBR600Fi, Kawasaki ER5
Pjay
PostPosted: 12:51 - 26 Mar 2016    Post subject: Reply with quote
I know it sounds odd, but I have in the past used kitchen foil scrunched up soaked* in T-Cut. It works in the theory that the foil wont damage the stanchion, but along with the mild abrasive properties of the T-Cut, it gives you just enough abrasion to remove the rust and not affect the chroming.
Someone is bound to call me an idiot, but it has worked a treat for me on more than one occasion.
*I know foil wont soak.
PostPosted: 13:25 - 26 Mar 2016    Post subject: Reply with quote
You learn fast. Thumbs Up
I'm a fan of foil + vinegar for cleaning chrome. Some people use coca-cola as an acid.
Robby
Dirty Old Man
PostPosted: 13:29 - 26 Mar 2016    Post subject: Reply with quote
The only proper repair is to rechrome or replace. Both are expensive.
A fix that may work is just sanding it back. If the pitting very bad, use fine emery paper with gentle pressure. If the pitting isn't too bad, rub it down with a finishing pad. This will remove the roughness and high points and give the seal a fighting chance.
Remember that rust is a lot softer than chrome - so you can sand it a bit. The rust will wear away long before the chrome is affected in any way, and it doesn't matter if you wear away a microscopic bit of chrome - the stanchion is fucked already.
Islander
PostPosted: 16:51 - 26 Mar 2016    Post subject: Reply with quote
This^^
Fine emery, light pressure and check your progress frequently. This will also hone the edges off of any pits and should get you going.
If the stanchions are very badly pitted then there's a ghetto fix using epoxy resin to fill the pits that'll last a while. If you search the forum for stanchion repair and author Stinkwheel, you'll find a detailed post.
whitedevil
PostPosted: 17:29 - 26 Mar 2016    Post subject: Reply with quote
This^^
I've done similar with super glue instead of resin. It works great.
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
Skudd
PostPosted: 17:43 - 26 Mar 2016    Post subject: Reply with quote
Does everyone split the forks when changing the seals, mine are a pain to split.
Islander
PostPosted: 17:55 - 26 Mar 2016    Post subject: Reply with quote
How else can you check and change the bushes and clean the shite out of the fork bottom and damper rod?
Nobby the Bastard
Harley Gaydar
PostPosted: 20:02 - 26 Mar 2016    Post subject: Reply with quote
All forks are a pain to split....
Triumph Sprint ST 1050
mauzo
PostPosted: 23:19 - 26 Mar 2016    Post subject: Reply with quote
It's not just the abrasion: 'tin' foil is actually aluminium, so the acid encourages a thermite-type reaction which turns the rust back into steel.
'04 CG125, '07 CBF500
Islander
PostPosted: 23:36 - 26 Mar 2016    Post subject: Reply with quote
What did I just read?? Shocked Rolling Eyes
If it were any type of 'thermite- type reaction' You'd be in a lot of pain as you severely burned the ends of your fingers. Laughing
mauzo
PostPosted: 00:53 - 27 Mar 2016    Post subject: Reply with quote
It's not the highly-energetic reaction you get when it burns, obviously Smile.
Islander
PostPosted: 01:06 - 27 Mar 2016    Post subject: Reply with quote
The reason aluminium works is that you're actually using aluminium oxide from the surface of the foil and that harder than steel and acts as an abrasive.
temeluchus
PostPosted: 02:15 - 27 Mar 2016    Post subject: Reply with quote
It's a 5 minute job on sachs forks.
I was able to replace the fork seals on a K75, refill with oil and refit the front wheel in a grand total of 15-20 minutes.
Islander
PostPosted: 02:19 - 27 Mar 2016    Post subject: Reply with quote
The ability to drain and refill them without having to remove them is something all fork designs should incorporate. Superb design. Thumbs Up
temeluchus
PostPosted: 02:34 - 27 Mar 2016    Post subject: Reply with quote
managed it in under ten when we did my chums K100, for a giggle.
jack under motor, remove wheel and bungee the calipers out the way, put a big pan under the forks, undo bolts and pull off sliders and led the oil splat out into the gert pan. Yank the seals out, put in the fresh, stuff the sliders back on and re tighten the bolts, wipe the oil splashes off, wheel and calipers back on. squeeze fresh oil back in from the top, cap screw back in.
Stanchions stay in the yokes, the sliders stay attached to the brace and mudguard and the fork caps have holes in em so you usually only need to remove them to replace the springs.
After working on forks that seem to be designed by Japanese sadists it was one of the most beautiful things I had ever seen.
Ichy
PostPosted: 09:45 - 27 Mar 2016    Post subject: Reply with quote
No, not always. At risk you can use a wood screw to pull the seal out.
john24ssj
PostPosted: 14:39 - 27 Mar 2016    Post subject: Reply with quote
Thanks for all the replies guys Smile Cleaned off as much crap of the forks as I could and will see if the new seal will hold, if not I'll try to find the forks on ebay or something.
The last post was made 10 years, 199 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 102.79 Kb
