| Paulmanx |
 Paulmanx Derestricted Danger
| ADSrox0r |
 ADSrox0r World Chat Champion
| Rogerborg |
 Rogerborg nimbA
| Paulmanx |
| Paulmanx |
| haroman666 |
 haroman666 World Chat Champion
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 18:38 - 02 Apr 2016 Post subject: |
| Paulmanx wrote: | I know the battery is good as it came off of her twin sisters identical uncrashed bike and hers went onto her sisters and worked fine |
Nope, 've seen too much of porn.
Find the main fuse, change it. It's on the plus wire coming from the battery (part of the starter relay housing).The main fuse is the first thing plugged to the battery. If it's blown, then no current won't get any further.
If that doesn't solve your problem, then it's damaged wiring, have fun. I take it, that when you turn the key to the on position, there is no power at all, the lights not working etc.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| RhynoCZ |
| Paulmanx |
| Paulmanx |
 Posted: 18:53 - 02 Apr 2016 Post subject: |
Yes mate it's totally dead but it's got no wiring damage I've only had to replace the left hand switchgear and headlight neither of which should of killed it ____________________ Jesus I was quick |
| haroman666 |
| Paulmanx |
| RhynoCZ |
| Paulmanx |
| Polarbear |
 Polarbear Super Spammer
| Polarbear |
 Posted: 00:15 - 03 Apr 2016 Post subject: |
| Paulmanx wrote: | I've only had to replace the left hand switchgear and headlight neither of which should of killed it |
It was working after the crash. You replaced the headlight and the left hand switch and now it doesn't work.
If it's like any othe rnaked bike I know, pretty much every wire on the whole bike goes through the headlamp shell so you've pretty much had it all apart.
Applying Occums razor.
You didn't connect something back up properly.
As Roger says, you need to find where the electricity stops being in the wires starting at the battery. I don't know your specific bike but it would usually go battery, starter solenoid, main fuse, ignition switch, accessory fuses. If there's 12v at the accessory fuses. SOMETHING should work.
If tha main fuse is blown and immediately re-blows. Connect a bulb and bulb holder in its place. Now when there's a short, the bulb wil light up instead of the fuse blowing. Pull the accessory fuses one at a time until the bulb goes out and that'll tell you which circuit the short is on. Some smaller bikes have no accessory fuses in which case disconnect all the wires you've messed with one at a time until it goes out. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Nobby the Bastard |
| Nobby the Bastard |
| RhynoCZ |
| Paulmanx |
This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
| Paulmanx |
| Andy_Pagin |
 Andy_Pagin World Chat Champion
| Paulmanx |
The last post was made 10 years, 14 days ago. Instead of replying here, would creating a new thread be more useful? |
