Where have you mounted your cams
lee8040
PostPosted: 07:03 - 03 Apr 2016    Post subject: Where have you mounted your cams Reply with quote
Got a cam one designed like a go pro, I'd rather it not be on the side of my crash helmet. Has anyone fitted there's in other places, espically with cams like the go pro.
t121anf
PostPosted: 08:44 - 03 Apr 2016    Post subject: Reply with quote
Tried on the front fairing near the headlight but the footage was quite shakey, not had a chance to try elsewhere.
PostPosted: 09:14 - 03 Apr 2016    Post subject: Re: Where have you mounted your cams Reply with quote
In the head... connected to the Cam chain?... was my immediate thought.
Only times I've used one recently has been on the rear fairing pointing forwards I think.
Val
PostPosted: 09:28 - 03 Apr 2016    Post subject: Reply with quote
I have two of them mounted permanently as kind of a black box. Front one is mounted on the mirror. Rear one is mounted on the rack. You may try handlebars for front one. For me was no good because of my fairing standing in a way.
I have done nice holes in the water proof cases with soldering iron and stuck usb leads connected to PDM60 power supply. Some kitchen silicone sealant to seal the usb leads to the case gives me back water proofing.
The set up is in car mode and auto power on/off for the cameras.
Means when I turn the ignition the cameras are on and when I turn it off the cameras are off.
https://farm2.staticflickr.com/1717/25296200894_4349bb8cb7_c.jpg
https://farm2.staticflickr.com/1719/25910858120_d081b9ea41_c.jpg
-Matt-
PostPosted: 10:09 - 03 Apr 2016    Post subject: Reply with quote
Use a top-mounted Drift on helmets sometimes which doesn't really cause any problems. Not sure if i'd fancy a chunkier Gopro-shaped camera on the helmet though.
My Sj4000 is mounted on the bottom of the screen which gives a good unobstructed viewpoint.
https://i66.tinypic.com/2lnu0lv.jpg
lee8040
PostPosted: 10:11 - 03 Apr 2016    Post subject: Reply with quote
that's the one I have. Did you use the stick pad to attach there or another mount?
Andy_Pagin
PostPosted: 10:15 - 03 Apr 2016    Post subject: Reply with quote
I have one on the tail pointing backwards. Other one is helmet mounted, there really is no better place since it's always pointing where you're looking.
-Matt-
PostPosted: 10:22 - 03 Apr 2016    Post subject: Reply with quote
Yeah thats just clipped in to one of the curved 3M adhesive mounts. I'd check the angle of the screen before sticking it down though, mine has to be tilted right back on the clip as far as it will go to get a clear view.
https://i66.tinypic.com/2salbuu.jpg
lee8040
PostPosted: 15:11 - 21 May 2016    Post subject: Reply with quote
Stuck mine to the fIring and it came unstuck a week later
andyscooter
PostPosted: 15:16 - 21 May 2016    Post subject: Reply with quote
Mount mine on the mirror stem
Snowdonia Rider
PostPosted: 15:32 - 21 May 2016    Post subject: Reply with quote
Mount it front of helmet if you don't like side.
The Tot
PostPosted: 15:58 - 21 May 2016    Post subject: Reply with quote
I mount mine on the yoke. Unfortunately, you can see your speed which yould either need to blur out, or just leave it for show if it's on the track. It's on a RAM mount!
Never argue with autism
t121anf
PostPosted: 16:39 - 21 May 2016    Post subject: Reply with quote
Is the footage not shakey when mounted to the bike?
Snowdonia Rider
PostPosted: 17:59 - 21 May 2016    Post subject: Reply with quote
This was on my lower cowling, it's not too bad... No image stabilisation from camera or post processing.
https://youtu.be/WATXBOJKUJ8
uberkron
PostPosted: 20:24 - 21 May 2016    Post subject: Reply with quote
Cylinder head usually.
Helmet offset to one side, clamped to bars?
i ride a zip 50 2smoke. It overtakes a hundred times a day.
uberkron
PostPosted: 20:25 - 21 May 2016    Post subject: Reply with quote
MarkF666
PostPosted: 07:44 - 22 May 2016    Post subject: Reply with quote
I have a gopro 3+ mounted on top of my helmet, it see's what i look at! I have caught all sorts of complete tits & their bad driving, as well as some tart that reversed into me last week!
Dav1son
PostPosted: 07:54 - 22 May 2016    Post subject: Reply with quote
Mines mounted through the stem bolt.
Fairly decent positioning.
This was my first attempt, have since moved the view to cut out the speedo, which obviously reads in KM
https://youtu.be/hiMprP1hrKA
Future: ....
Present: GSXR-750 L0
Past: ZX10R C2H, TL1000R, CBR400 NC29, GPR50RR/RS50
lee8040
PostPosted: 07:58 - 22 May 2016    Post subject: Reply with quote
What type of bracket fits onto that? Thing I like is people see it on the front and you notice they look at it and wait instead of trying to force you over
Dav1son
PostPosted: 08:11 - 22 May 2016    Post subject: Reply with quote
On that flat plate is a mounting clip that's supplied with the camera just stuck on with that 3M adhesive foam. Had no issues. Good quality footage and since its on the front suspension pretty much it doesn't shake at all unless the wheel is in the air
Future: ....
kilroy was here This post is not being displayed because the poster is banned. Unhide this post / all posts.
Snowdonia Rider
PostPosted: 08:38 - 22 May 2016    Post subject: Reply with quote
This happened to me in the New Year only by a bloke, and guess what? It was the one time I didn't have my camera with me Rolling Eyes
MarkF666
PostPosted: 08:50 - 22 May 2016    Post subject: Reply with quote
Typical that!
I try to make it a rule that i never get on the bike without my camera! Too many bloody idiots on the roads near me!
Ajo
PostPosted: 12:47 - 22 May 2016    Post subject: Reply with quote
Don't forget you can also get body mounts, I've used a chest harness pulled high up under my chin as I don't want it on my helmet. Also you can get wrist mounts to carry it like a watch but I've never tried mine
groovylee
PostPosted: 15:29 - 22 May 2016    Post subject: Reply with quote
Just don't try on the front fairing with a suction mount. Just above the headlight. I nearly took Carvel out with mine 😳
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
The last post was made 9 years, 274 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 125.78 Kb
