Less workshop more driveway...
t121anf
PostPosted: 18:29 - 03 Apr 2016    Post subject: Less workshop more driveway... Reply with quote
I've got a block paving driveway and need to do some work on my car, requiring the front end off the ground.
My trolley jack hates block paving, any reason I can't put some board under the jacket to allow it to roll as it raises the car?
BTTD
PostPosted: 19:01 - 03 Apr 2016    Post subject: Reply with quote
None that I know of, I have done exactly that numerous times. You are using jack stands as well right? Or are you relying on o rings to not fail and drop a car on you?
Be safe. Thumbs Up
CaNsA
PostPosted: 19:03 - 03 Apr 2016    Post subject: Reply with quote
Once the car is jacked up, chock the trolly wheels.
t121anf
PostPosted: 19:07 - 03 Apr 2016    Post subject: Reply with quote
Its going on axle stands to do the work.
When i've jacked the car (or bike for that matter) I've found the jack pulls the car towards it rather than wheeling into the car as it does normally.
This is normally caused by the wheels reaching a joint in the blocks, using wood under the jack would allow the jack to roll into the car.
Always had tarmac or concrete drives before so never had this problem
CaNsA
PostPosted: 19:09 - 03 Apr 2016    Post subject: Reply with quote
Use the wood then.
problem solved.
Ben90
PostPosted: 19:26 - 03 Apr 2016    Post subject: Reply with quote
My driveway is similar and the jack wheels get stuck pulling the car towards you, which is much worse when you've done one side and start to jack up the other and it the car begins to pull the axle stand over Shocked
Yamaha FZ6 S2
t121anf
PostPosted: 19:27 - 03 Apr 2016    Post subject: Reply with quote
Exactly, Google is confirming wood is fine to use
grr666
PostPosted: 21:09 - 03 Apr 2016    Post subject: Reply with quote
Get a couple of scaffold board offcuts from the next crew you see lobbing it up somewhere. It's ideal for this task.
The last post was made 10 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 54.01 Kb
