Honda CBF 125. Rear drum break
Majeeko
PostPosted: 07:25 - 04 Apr 2016    Post subject: Honda CBF 125. Rear drum break Reply with quote
Hi all, i'm a relatively new biker, done about 1700 miles on my CBF 125, just commuting to work and back. its second hand and a 2010 model. Yesterday i noticed rear break didn't feel right, when i pressed the pedal it didn't spring back like it use to, i have had a look and all the linkage seems fine it appears to be the workings inside the drum break
https://youtu.be/1tjmBwIWxQI
I've attached a short video for clarification. ideally id like to do the repair myself to save a few quid but i'm nervous about taking the wheel off and getting it back safe enough to ride.
there is also a squeaking sound when i first use the rear breaks, it stops after a few minutes.
i'm guessing that some of the internals have seized or i need new break pads or shoes but i would like a more expert opinion please.
Many thanks in advance
Luke
spottedtango
PostPosted: 09:56 - 04 Apr 2016    Post subject: Reply with quote
Brake drums usually have 2 main springs inside them.
-A main return spring within the drum to pull the shoes back from the drum once the you've applied the brakes.
-A smaller retaining spring usually connecting the two brake shoes at the bottom holding them in.
Id inspect inside the brake drum to see if these springs have snapped as they tend to rust up. I think in your case the return spring inside the drum has corroded and snapped causing your brake pedal to not return.
Its not too difficult a job, theres plenty of youtube vids and how tos on the web. Id do some research
MCN
PostPosted: 10:29 - 04 Apr 2016    Post subject: Reply with quote
Is you're break broaken?
The mechanism is relatively simple.
Check that all the pivots are free to move.
Check that the brake linings are not worn down to the quick.
After the checks you need to adjust the linkage as per the O.E.M. instructions.
PostPosted: 10:38 - 04 Apr 2016    Post subject: Reply with quote
Hi Luke.
Assuming that you've lubed the actuator arm and it's not helped then you are going to have to start stripping and cleaning. Could be a snapped spring, could just be gummed up with crud like the rear on my GPz305 when I got it. You're not going to know until you get in there.
It's not complicated and this video covers it.
PostPosted: 10:46 - 04 Apr 2016    Post subject: Reply with quote
From how far wound in the adjuster nut appears to be on your video (pretty much fully compressing the control rod spring). I'd surmise your brake shoes are very nearly worn out causing the cam to start going over-centre.
There may be some corrosion around the cam pivot area too.
I'd suggest you blow £13.50 on a set of brake shoes in preparation for stripping and cleaning your rear brake drum.
You may find this helpful.
Don't do nothing because the next step may be the brake locking on and staying there. Not much fun if you're moving at the time.
Majeeko
PostPosted: 11:37 - 04 Apr 2016    Post subject: Reply with quote
Thanks everyone. The break still works although not very well. it looks like i will be spending one Sunday stripping and cleaning.
The video and guides are really helpful.
Luckily i've found a mobile bike mechanic near me so if all goes tits up ill ask him to come round and help me put it back together.
Very Happy
MCN
PostPosted: 11:39 - 04 Apr 2016    Post subject: Reply with quote
Very Happy
BRAKE. BRAKE. BRAKE.
Majeeko
PostPosted: 12:08 - 04 Apr 2016    Post subject: Reply with quote
BRAKE.........got it.
Majeeko
PostPosted: 12:13 - 04 Apr 2016    Post subject: Reply with quote
Just got that joke now. Touché.
PostPosted: 13:25 - 04 Apr 2016    Post subject: Reply with quote
I wouldn't wait for a Sunday, because as stinkwheel says, there's some risk of it locking up. Really, it's as simple as it looks. There are no surprises lurking in there, and for once, reassembly really is is the opposite of disassembly, as the Haynes Book of Lies is fond of claiming.
Just take care to get the spacers on the correct side and the right way round (slide them onto the axle as soon as its out so that they don't go astray or get mixed up), go over it twice to be sure that you've done everything up, and get the wheel alignment and tension right, and you're done.
mauzo
PostPosted: 15:14 - 04 Apr 2016    Post subject: Reply with quote
Also, if you're cleaning and greasing: DO NOT get any grease on the friction surfaces or the drums they press against. Also don't breathe the black dust inside the brake drum, it'll give you cancer.
'04 CG125, '07 CBF500
The last post was made 9 years, 295 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 69.67 Kb
