| Kaya75 |
 Kaya75 Trackday Trickster
 Posted: 15:54 - 04 Apr 2016 Post subject: pls reccomend me a good stud extractor.. |
Quick question, bandit 600 k1 header studs.. blah blah.
So two have gone the middle two as expected and the right-hand middle bottom will probably join them.
What's a good stud extractor?
No welder available and they are stainless bolts..
Cheers all  ____________________ ybr125 Sold, GSF600 K1 Bandit (For Sale), FJR13000 gen2. |
| MCN |
 MCN Super Spammer
 Posted: 16:10 - 04 Apr 2016 Post subject: |
Is the head off the block?
If you can get at the stumps easily:
Make a template using the studs as is. Or you can use the manifold.
Cut the studs flat.
Mark the stud centres using your template or the manifold.
Tip:
Use a drill the same size as the holes in the manifold to drill some centre holes in the studs using the manifold as a guide.
If the studs are SS then they will be difficult to drill using 'normal' HSS bits.
I use this method regularly for fcuked up 'hard' stuff.
Sharpen the Carbide Inserts of a masonry bit to put a leading edge on each insert. They come with edges suited to percussion so will struggle to cut steel in a drilling machine.
Use the modificated masonry bit to drill out the old studs.
You will also need to buy a set of metric taps M8 or M10 not sure but not too expensive if you find a pound shop. Near enough for home use.
It is a better job when you have your head tightened in a vice so you can control the angle of dangle more precisely.
Do not drill too deep as you may punch through into the water jacket.  ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| redeem ouzzer |
| Keir |
 Keir World Chat Champion
 Posted: 17:05 - 04 Apr 2016 Post subject: |
when my old fazer studs snapped leaving abou 8mm of stud exposed i used THESE. They work on quite a fine tolerance so make sure you have the right size for your stud. go slow and steady! ____________________ Current : '08 Yamaha FZ1s
Previous: '99 Honda CBR 600FX, 03 ZX636 B1H, 99 Fazer 600 (red), 02 GSX-R 600 K2, 00 SV650s (red), 2008 ZX10R, 97 Bandit 1200N, 04 ZX6RR K1H, 04 GSX-R 1000, 98 Fazer 600 (gold), 05 Madness 110 Pit bike, 04 CR125R, 00 SV650s (black), 06 KTM 625 SMC, 99 SRAD 600 track bike, 03 SV650, 98 Bandit 1200N, Bandit 600SY, 03 GSX-R 600 K3, 01 GSX-R 600, 01 Fazer 600 (black), VFR 400 NC30 x3, 78 Honda Dream, 00 Speedfight 50 |
| Kaya75 |
 Posted: 20:45 - 04 Apr 2016 Post subject: |
Thanks all,
Tried the big fuk off laser extractor... Which left me doubly fuked had they just sheared flush to the block.. happy daze.
So has my doctor just said, if yer snapped em twice, they anit lovin drill the fukers..dont use flutted extractors these will snap then it's down to the machine shop..
So I'll be drilling slowly - engine in still in situ, I should be good tho, cobolt bits from 2mm up and up till they collapse.. GO SLOW..
it I fuk it, and I just had my drillling licence revoked!! I'll be getting masonry bits and insert. Good tip about masonary bits, nice.
And about depth i'll tape the bits..
Here is a pic of the snaping good fun..
See what tommorrow brings  ____________________ ybr125 Sold, GSF600 K1 Bandit (For Sale), FJR13000 gen2. |
| Kaya75 |
 Posted: 20:49 - 04 Apr 2016 Post subject: |
On the plus side, changing the oil filter should be a piece of piss  ____________________ ybr125 Sold, GSF600 K1 Bandit (For Sale), FJR13000 gen2. |
| Kaya75 |
 Posted: 20:50 - 04 Apr 2016 Post subject: |
| redeem ouzzer |
| MCN |
 MCN Super Spammer
| temeluchus |
| sickpup |
 sickpup Old Timer
 Posted: 23:49 - 04 Apr 2016 Post subject: |
 Posted: 06:49 - 05 Apr 2016 Post subject: |
Bandit exhaust bolts are notorious for snapping in the middle. Personally I think it's down to the stainless losing it's properties.
Anyway, here's how I tackled it. You can buy the drill bushings quite cheaply if you haven't the facility to make them
https://www.bikechatforums.com/viewtopic.php?t=260458 ____________________ a.k.a 'Geri'
| Kaya75 |
 Posted: 00:11 - 06 Apr 2016 Post subject: |
Cheers all,
Bit behind today, had to pick up the rear master cylinder rebuild kit ( the fun never ends ) - the TV broke has I steamed it this morning boiling the kettle dry and I had to drop of the exhurst to the welder.
Quality result at the welder tho, phoned a few more this morning found a old school machine shop, drop it off as it is, no grinding and prep req, pick it up in two days when it will be fully stainless after a couple of hours work, cost £40 :up
I picked up the drill bits and and a couple of helicoils and 8 A2 header bolts from the fasteners shed next to the welders, gotto love ins estates, less then 20 quid for the bag inc selection of Colbolt bits, A note here, the helicoils are about a quarter of the length of the bolt ( or set screw I guess).. It's gonna be a bitch to center the drill and to align the angle I have no idea how I'm gonna to replicate a precision engneering tool shop while laying on my back giving myself neck strain tho.. But hey oh let's go drill...
Once I've replaced the steamed TV in the morning I'll get on with it.. I may rebuild the cylinder first depending on the weather.. Pic of fuked head to follow shortly..
Now I'm gonna study peters awesome post  ____________________ ybr125 Sold, GSF600 K1 Bandit (For Sale), FJR13000 gen2. |
| Kaya75 |
The last post was made 10 years, 209 days ago. Instead of replying here, would creating a new thread be more useful? |
