| NJD |
 NJD World Chat Champion
 Posted: 11:27 - 05 Apr 2016 Post subject: Working out a locknut size? |
Lexmoto arrow before we begin, before anyone asks and I forget.
Cutting a long story short so far I've spent one pond and seventy pence on two locknuts that aren't the right size based on the wrong advice and the interwebs are confusing me on the most simplest of matters. BCF's turn to educate me yet again.
So as per the pictures below I've damaged the seat locking nut (OEM) and want to replace it. The nut will tighten and loosen but it's easier just to replace since (and when the find the right size) they're cheap enough anyway. I'm struggling to work out what size I'd need. I've looked on the Lexmoto parts section but fail to find what I'm after.
All I can tell you is that it requires a 12mm spanner to undo.
Guy working in Homebase told me that a M10 = 10mm spanner, M12 = 12mm spanner as so on and so forth. Based on that advice I got confused what spanner size was required while shopping and purchased two m10 locknuts thinking that it would fit a 10mm spanner although it turns out they require something bigger than a 14mm spanner to get around the head so they're defiantly not the right size. And I'm lost.
Any ideas?
Also, and finally, is there a simple way to tell what way to undo nuts and bolts without having to find myself in a similar situation again with a more expensive part?
https://s16.postimg.org/gp74mqhlh/nut1.jpg
https://s21.postimg.org/p7adbu4nr/nut3.jpg |
| sickpup |
 sickpup Old Timer
| iooi |
 iooi Super Spammer
| NJD |
| sickpup |
 sickpup Old Timer
| Polarbear |
 Polarbear Super Spammer
| tom_e |
 tom_e Brolly Dolly
| NJD |
| Monkeywrenche... |
 Monkeywrenche... Nearly there...
| grr666 |
 grr666 Super Spammer
 Posted: 15:28 - 05 Apr 2016 Post subject: |
The guy working in Homebase should lose his job. I regularly find myself in DIY builders merchants often and the staff there
usually know absolutely nothing about what they sell except the price.
Try a trade counter next time, they tend to be manned by staff familiar with the things they stock and what they
are used for etc.I used to use a place called Cookes in Chadwell Heath for all my nut and bolt needs, I wonder if it's still there? ____________________ Currently enjoying products from Ford, Mazda and Yamaha
Ste wrote: Avatars are fine, it's signatures that need turning off.  |
| chris-red |
| mauzo |
 mauzo Nova Slayer
| NJD |
 Posted: 23:41 - 05 Apr 2016 Post subject: Re: Working out a locknut size? |
| mauzo wrote: | Get'chaself a socket set, you're much less likely to round off bolts like that. |
<Blank face, urm wut?>
Have you read the OP? I haven't damaged or rounded of any bolt. I've damaged the head a little of the locking nut.
.. And I have one, a socket set that is, given the grab rail, side fairing and awkward angle a ring spanner does the job just nicely in a tight gap.
| mauzo wrote: | But if those nuts really are LH thread you won't be able to buy them anywhere normal. (I don't believe they are either. I think you're still confused somewhere.) |
<Hand over face, shakes head>
I'm not really bothered what you do and don't believe because as per my last post I went out and double checked on the bike what way the locking nuts on both sides require turning with a spanner to loosen and tighten and posted the results. I then asked if those results mean it's a reverse thread.
| Monkeywrencher wrote: | just to clear, it doesn't matter where you're standing or where the bike faces, left and right are in relation to the fastener when viewed from its face looking straight at it...not where you stand or in relation to anything else.. |
My comment: "(also when I say left and right I'm talking as if we're standing behind the rear of the bike looking towards the front)" was to clarify that anyone else reading what way the locking nut tightens / loosens understands exactly what side of the bike I'm talking about. The aforementioned comment is not in any way an attempted explanation or contribution to an explanation regarding what way the actual nut tights or loosens.
| grr666 wrote: | The guy working in Homebase should lose his job. |
Potato advice but cost me under two ponds to find that out, lesson learnt next time.  |
| MCN |
 MCN Super Spammer
| mauzo |
 mauzo Nova Slayer
| MCN |
 MCN Super Spammer
 Posted: 01:35 - 06 Apr 2016 Post subject: |
Those nuts and bolts will be standard thread direction. i.e. Right Hand thread.
Looking on top of the bolt or nut you turn socket/spanner CLOCKWISE to tighten
Or ANTI-CLOCKWISE to loosen.
Left Hand threaded stuff is Extremely unusual and very specific.
It is difficult to find LH thread taps and dies.
For nuts and bolts that are damaged you need to use 6 point/single hex tools.
Normal ring spanners and sockets are 12 point which can damage soft metal fastener heads that have been damaged or are rusted in.
Try to avoid using open end spanners to loosen nuts and bolts. They do not offer any grip and slip off. That will positively have a negative effect and fuk up your day. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| grr666 |
 Posted: 08:19 - 06 Apr 2016 Post subject: |
| NJD |
| Raffles |
 Raffles World Chat Champion
| tyler12 |
 tyler12 L Plate Warrior
 Posted: 11:33 - 06 Apr 2016 Post subject: |
| NJD |
| Islander |
 Islander World Chat Champion
| NJD |
 Posted: 16:23 - 06 Apr 2016 Post subject: |
[quote="Islander"]Those look like nylock nuts - nothing wrong with that but the original was a flanged nut so you'll probably need washers to go under them.
Locking nuts don't run freely like a plain nut and will need a small amount of force to thread them on.[\quote]
Below is what it looks like. Only reason I asked is because I wasn't sure if the bolt was getting caught on the blue inner part of the nut or it just needed some force.
13mm spanner and M8 washers. Have to wait for another day due to work. The gift that keeps on giving.
https://s8.postimg.org/i4ycb97xh/image.jpg
Also is my phone browser special or is this site a pain in the rear to use on phones in general? Typing and the next moment I end up typing in the search bar along with many other quirks. Been writing this got about 10 minutes.  |
| tom_e |
 tom_e Brolly Dolly
| ondabike |
 ondabike Borekit Bruiser
The last post was made 10 years, 197 days ago. Instead of replying here, would creating a new thread be more useful? |
