M.o.t
Ricky.Hicks
PostPosted: 16:16 - 07 Apr 2016    Post subject: M.o.t Reply with quote
Hi guys just wondering it a scooter can fail the m.o.t if the fan cover isn't on thanks in advance
Nobby the Bastard
Harley Gaydar
PostPosted: 16:20 - 07 Apr 2016    Post subject: Re: M.o.t Reply with quote
If the cover prevents fingers and things from getting caught in it, then yes, probably.
It's like having a sharp knife stuck on your mudguard.
Triumph Sprint ST 1050
RhynoCZ
PostPosted: 16:25 - 07 Apr 2016    Post subject: Reply with quote
Depends on the MOT place. Twisted Evil
PostPosted: 16:32 - 07 Apr 2016    Post subject: Reply with quote
Not likely tested. I'd take it with no fan cover.
skatefreak
PostPosted: 16:35 - 07 Apr 2016    Post subject: Reply with quote
duct tape over fan Thinking
mauzo
PostPosted: 17:30 - 07 Apr 2016    Post subject: Reply with quote
Read this and find out…
AFAICS the only thing they might get you on is 2 (Refusal to test) h:
MOT manual wrote:
The condition of the vehicle is such that, in the opinion of the NT, a proper examination would involve a danger of injury to any person or damage to the vehicle or other property.
There is no specific item for fan covers.
'04 CG125, '07 CBF500
PostPosted: 17:32 - 07 Apr 2016    Post subject: Reply with quote
[UPDATE] Pipped. What he said ^^^
Can't see any specific grounds for it. Fill your boots:
https://www.gov.uk/government/publications/mot-inspection-manual-for-class-1-and-2-vehicles
Ricky.Hicks
PostPosted: 21:07 - 07 Apr 2016    Post subject: Reply with quote
Brilliant thank you to all of you for replying the bike is in good condition and I have the cover just it's snapped where it bolts on to the casing
Shaft
PostPosted: 23:39 - 07 Apr 2016    Post subject: Reply with quote
I'll just chip in my two penn'rth, as an MOT tester.
A fan guard isn't specifically mentioned in the test manual, but it could be construed as coming under Section 6.1 Body Structure: Condition.
A particularly picky tester might wonder if it would be possible to catch a loose item of clothing in the spinning fan, but because we are meant to give the benefit of the doubt, at worst it would be an advise and pass.
If you take it in and it fails on that particuler item, I would use the prescribed complaints procedure and appeal.
PostPosted: 08:13 - 08 Apr 2016    Post subject: Reply with quote
What would the specific reason for rejection be?
Awesome, it can now be done online.
Shaft
PostPosted: 10:22 - 08 Apr 2016    Post subject: Reply with quote
There isn't one that I can see, but there is the provision to manually enter an advisory notice, for items that aren't specifically within the scope of the test.
In this case, you could advise that the rider risks having his trousers torn off by the unprotected fan, but you don't have the option to fail based on a manual advisory, so it's an advise and pass.
PostPosted: 13:31 - 08 Apr 2016    Post subject: Reply with quote
Thanks, that makes sense.
Monkeywrenche...
PostPosted: 16:52 - 08 Apr 2016    Post subject: Re: M.o.t Reply with quote
This is also not a fail Smile
2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900
arry
PostPosted: 18:55 - 08 Apr 2016    Post subject: Reply with quote
And yet at the same tine doesn't as it's a test designed to check whether a vehicle is roadworthy yet anything that doesn't fit the scope, regardless of whether it's downright dangerous, can only fit the Advisory bill
PostPosted: 21:22 - 08 Apr 2016    Post subject: Reply with quote
Shaft, without hijacking the thread, would replacement hood ornaments fail because they have sharp edged/don't retract?
I have a gorgeous art deco one I want to fit to an old Rover.
Triumph Trophy Launch Edition
Shaft
PostPosted: 21:42 - 08 Apr 2016    Post subject: Reply with quote
To be fair, the design of most scooters is such that the fan usually has some other bit of bodywork between it and the user, so the risk of accidentally coming into contact with it would be quite low and, if you're stupid enough to deliberately poke around a high speed fan, then, frankly, you deserve all you get.
The only other downright dangerous things that spring to mind, concern tyres, where moped tyres only have to have a visible tread pattern and on all bikes you can have deterioration cracks the size of the Grand Canyon, but if the carcass isn't exposed, that's fine.
I'm also quite surprised at how poor brakes can be and still pass, but that's another story.
The manual advisory system only really exists as an arse covering exercise, so that testers have somewhere to put things that aren't covered by the test (which isn't much) but they want everybody, ie the DVSA, to know they've noticed it, if something goes the way of the pear at a later point; I think I've used it twice in the last year.
For all the important stuff, there's a complete set of tick boxes that allow you to pass, fail and advise.
Shaft
PostPosted: 22:04 - 08 Apr 2016    Post subject: Reply with quote
Good question and I refer my learned colleague to Con & Use Regs 1986, section 53:
"Mascots
53.—(1) Subject to paragraph (2), no mascot, emblem or other ornamental object shall be carried by a motor vehicle first used on or after 1st October 1937 in any position where it is likely to strike any person with whom the vehicle may collide unless the mascot is not liable to cause injury to such person by reason of any projection thereon."
I'm not certain how Rolls Royce or Jaguar got around this for many years after 1937 (before they made them collapsible, I'm sure a Spirit of Ecstasy could rip you a whole variety of new ones) but it would appear they are illegal, unless you mount them far enough back that they aren't dangerous, when they tend to look faintly ridiculous.
I should point out that I'm not a car tester, so I can't go completely definitive, plus it's worth noting that just because a thing is illegal, doesn't mean it's an automatic MOT fail, but I wouldn't go drilling holes in your bonnet just yet.
I'll check with our car guys tomorrow.
Monkeywrenche...
PostPosted: 11:01 - 09 Apr 2016    Post subject: Reply with quote
sharp edges and protrusions that are likely to cause injury will fail, but only if they are caused by corrosion or damage, additional items added securely are not fails.
However, same caveat as above...MOT pass does not always equate to legality.
Shaft
PostPosted: 23:47 - 09 Apr 2016    Post subject: Reply with quote
^^^ Beat me to it.
As I suspected, it's illegal, but not an MOT fail.
I have no idea what the offence code or likely fine would be, should a particularly clued up plod decide to write you up for it, nor do I know how many people have actually been prosecuted for a section 53 offence.
I'll let you have the pleasure of researching that one Very Happy
PostPosted: 08:34 - 10 Apr 2016    Post subject: Reply with quote
Shaft wrote:
^^^ Beat me to it.
Cheers Thumbs Up
The last post was made 9 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.43 - MySQL Queries: 15 - Page Size: 111.01 Kb
