Is it safe for me to mount this used tyre? Pics inside
Yasine
PostPosted: 16:13 - 08 Apr 2016    Post subject: Is it safe for me to mount this used tyre? Pics inside Reply with quote
Bought a used Dunlop Sportmax Roadsmart with 5.8mm tread across.
Thought it was a good deal at £36
It appears that it has some small damage where the bead of the tyre is.
You can see it in the second picture attached.
It looks like it probably happened when someone tried to mount/unmount the tyre using the tyre removal tools.
The damage is not on any area where the tyre will touch the ground.
What would you're advice be... to mount or not to mount?
Yamaha XJ6N
fw750x
PostPosted: 17:32 - 08 Apr 2016    Post subject: Reply with quote
The Only Half safe way to use that Tyre would be to put a tube in it, Where the Damage is means you will have a tyre going down slowly OR it will suddenly Deflate some day WHICH could end up with you getting KILLED. If it was me i WOULD not take the Chance.Francis
Ichy
PostPosted: 17:41 - 08 Apr 2016    Post subject: Reply with quote
Drama queens are called Francis.
The bead is an important part of the structure of a tyre. If you are confident that it will seal and the main carcass isn't damaged then go for it. If you're not happy, get a refund. In reality no one is in a position to tell you what YOU should do. (I learned how to use caps from Francis)
recman
PostPosted: 17:55 - 08 Apr 2016    Post subject: Reply with quote
I'll have a couple of ponds on the fact that it won't hold air.
fw750x
PostPosted: 18:08 - 08 Apr 2016    Post subject: Reply with quote
Hi Ichy Sorry i am not a Drama Queen. A few Years ago while Traveling along a Class B Road going round a Gentle Left Hand Bend , The Rear Tubed Tyre on my then Honda Transalp Deflated in a Matter of Seconds . I was sitting at 60 mph at the time and Because i could not Hold the Line i was on ended up on the Right hand side of the road I E in the opposing Lane on the Hard Shoulder. I was very Lucky that i did not Hit any cars coming in the opposite direction . So again if it was me i would not use it. Francis
Many years ago I had a tyre with a kink in the bead just like that. There was no damage to see except a little nick so I fitted it to my GS550. I got the bike out one Saturday morning and was just getting ready to set off when the rear tyre literally exploded as I sat there outside my house. The bead wire had rusted through right where the kink was.
I realise that modern tyres might not have a steel bead wire but I just wanted to highlight the fact that the tyre was not obviously damaged to any extent but it let go in spectacular fashion.
recman
PostPosted: 18:29 - 08 Apr 2016    Post subject: Reply with quote
Op, if you're not entirely happy with it, please sell it to bodyguard. Praying
wristjob
PostPosted: 20:20 - 08 Apr 2016    Post subject: Reply with quote
if it was free and it would hold air then yes i would use it.
wouldnt part with any money for such a tyre.
if jivebunny thinks its ok, well.
you make youre own punchlines.
nowhere.elysium
The Pork Lord
PostPosted: 20:43 - 08 Apr 2016    Post subject: Reply with quote
Are you a Teflon-Mike sock account?
Ichy
PostPosted: 21:48 - 08 Apr 2016    Post subject: Reply with quote
I thought you were a better person than that. The poor guy has an obvious caps-Tourette issue and you naturally assume Tefalitus? Shame.
nowhere.elysium
The Pork Lord
PostPosted: 21:53 - 08 Apr 2016    Post subject: Reply with quote
I can't help the fact that I feel the need to point at spackers.
Actually, that's not entirely true: I can help it, I just don't want to.
Dave70
PostPosted: 22:35 - 08 Apr 2016    Post subject: Reply with quote
Personally, when it comes to tyres, I wouldn't chance it.
I'd rather wave goodbye to the £36 than wave goodbye to the air inside it while riding.
angryjonny
PostPosted: 22:52 - 08 Apr 2016    Post subject: Reply with quote
God.i wrote:
Yes I would use it. Though expect a tyre arm chair expert to be along shortly with an essay. Sleeping
There you go. You can sell it to Bodyguard.
PostPosted: 00:48 - 09 Apr 2016    Post subject: Reply with quote
GodyBuard wrote:
https://cokieblume.files.wordpress.com/2015/09/mfwspoilerstoanythingilovedontyoudaresay_366e98_5133999.gif
Ooh, tough choice. Thinking
Monkeywrenche...
PostPosted: 08:24 - 09 Apr 2016    Post subject: Reply with quote
That tyre is brand new looking, so why isn't it on a bike?
I'll tell you for why, because they damaged the bead fitting it and it leaks
https://infopeake.org/blog/wp-content/uploads/2015/01/walk-away-moss-IT-Crowd.gif
2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900
Bozzy
PostPosted: 15:21 - 09 Apr 2016    Post subject: Reply with quote
I wouldn't fit that to my bike. It really isn't worth taking the risk.
Hahadumball
PostPosted: 15:52 - 09 Apr 2016    Post subject: Reply with quote
i hate when moneys tight and i have to get a part worn off egay.
i bought one last year, it had a nail in it.. sent back got another the compound was so fucked i could squash the tyre with 1 hand.
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
mysterious_rider
PostPosted: 16:57 - 09 Apr 2016    Post subject: Reply with quote
Tyre is perfect. Just bang some bead sealer on the damaged spot and fit it then forget. All these people saying no dont understand what they see. The whole bead sits on the rim so unless that whole flat bit is damaged i wouldnt worry.
KAWASAKIIIII
Commuter_Tim
PostPosted: 21:48 - 09 Apr 2016    Post subject: Reply with quote
Genuine question, Under what circumstance would somebody sell a perfectly workable part worn tyre? Thinking
I ride a Bandit 600... badly.
Ichy
PostPosted: 22:10 - 09 Apr 2016    Post subject: Reply with quote
Nine times out of ten I buy a used bike and replace the tyres for what I want on there.
PostPosted: 22:13 - 09 Apr 2016    Post subject: Reply with quote
Send it back and get a refund.
Even without the damage, £49 for that tyre is a bit steep.
https://www.ebay.co.uk/itm/55450-DUNLOP-Sportmax-Roadsmart-160-60ZR17-69W-Part-Worn-Tyre-5-8mm-/281376972713?hash=item41835fdfa9:g:eygAAOSw7ThUgF2V
Hahadumball
PostPosted: 23:11 - 09 Apr 2016    Post subject: Reply with quote
a fair few bikers buy a bike with tyres or buy tyres, dont like them and replace them, ive had a few almost new look like under 200 miles use tyres from a tyre wall at a local main honda dealer as some people just dont like the tyres they use.
im changing my tyres soon and my fronts got a few k miles left on it but i just dont like it.
it barely heats up and when it does it loses it within 30 seconds of stopping.
it all depends on what they want the bike for, buy a hypersport with touring tyres for hooning around youd want to change them.
the local main honda dealer is full of people that have stupidly expensive shiny exhausts and they want the best.
evoboy
PostPosted: 15:18 - 10 Apr 2016    Post subject: Reply with quote
Apart from when they blow out because of damaged cords in the bead due to the bead being overly stretched when forced over the arm of the machine that was used to remove it. Which is what normally causes damage like that. Roadsmarts are prime for this to happen as they are rock hard.
I keep part worns on the shelf, but only if I have removed them and checked them.
When they have chunks missing like that they are normally a bugger to blow up to seat the bead in the first place. I just bin them if there is any damage like that regardless of age or tread.
APT Motorcycles
Yasine
PostPosted: 08:35 - 11 Apr 2016    Post subject: Reply with quote
Thanks for all the helpful replies.
This part worn tyre has now been sent back to the seller.
Went to the local bikeshop and replaced the rear tyre with a new one.
Went with what is recommended in the owners manual.
For a Yamaha XJ6N it is recommended either to fit a Bridgestone Battlax 021 or a Dunlop Roadsmart.
Went with the Bridgestone tyre, as the bike already had a Bridgestone tyre on there but it was a 023.
This was a learning curve! next time its just easier and safer to buy brand new!
Yamaha XJ6N
The last post was made 10 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 132.01 Kb
