| talkToTheHat |
 talkToTheHat World Chat Champion
| BrownTrousers |
 BrownTrousers Trackday Trickster
 Posted: 05:37 - 15 Apr 2016 Post subject: |
Am also considering this and interested in replies.
Dual injector being offered for free with V system on sportsbikeshop.com currently. ____________________ Bikers make great organ donors - add your name to the register
Ducati Multistrada 950 | Triumph Tiger 800 XR | Honda CBR500R | Yamaha YBR 125 Custom |
| c_dug |
 c_dug Super Spammer
| Polarbear |
 Polarbear Super Spammer
 Posted: 07:21 - 15 Apr 2016 Post subject: |
When they are set up properly they are brilliant.
Wifey had one on her Divvy 600 which took me ages to get right but that was many moons ago, I'm sure they are better now.
I would go electronic because it's easier to run a wire then to drill and tap a hole in a manifold. (If you have already got a hole )
I have no idea about the twin feed but would expect it to be better or why would they bother making it. ____________________ Triumph Trophy Launch Edition |
| linuxyeti |
 linuxyeti World Chat Champion
 Posted: 08:32 - 15 Apr 2016 Post subject: |
I've put one of these on my CF650TR, and have another ready to put on another bike ..
https://www.tutorochainoiler.com/collections/frontpage
It gets really good reviews, no need to splice it in with the electrics, or carb. No mod to the bike itself required. Plus, it's considerably cheaper that a scottoiler.
Seems to work well, only difference being, I'm going to add the twin feed nozel. Oh, and I'm using some spare gear oil I had lying around, which feed through well.
Tony ____________________ Beware what photos you upload, or link to on here, especially if you have family members on them |
| barrkel |
 barrkel World Chat Champion
 Posted: 10:26 - 15 Apr 2016 Post subject: |
I fitted an e version to my ER6f while my VFR came with a vacuum operated valve version already fitted.
The single biggest problem with the vacuum version is that you need to adjust the flow rate depending on the ambient temperature. If you're living in the UK, the temperature range during the day usually isn't too large so it isn't a big problem. But many times when touring, I've had to slowly adjust the rate upwards to get some oil flowing on a motorway trip, and then find out it's entirely emptied its contents once you've gone over a mountain pass into different climate on the other side.
The e system is more expensive, but it's worth it if you tour. If you're staying in the UK and don't expect big temperature swings, then the v system may be enough.
(I used the dual nozzle on my ER6. The one that came fitted to my VFR is a single nozzle set to splash on the inside of the chain. It's definitely sufficient to oil not just my chain, but also my swingarm and rear caliper. I'd much rather a dual nozzle skimming the surface of the rear sprocket, but the VFR doesn't have a rear sprocket well shaped for this, what with the single sided swingarm.) ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
| Ribenapigeon |
 Ribenapigeon Super Spammer
| barrkel |
 Posted: 10:38 - 15 Apr 2016 Post subject: |
| Ribenapigeon wrote: | I've come to the conclusion your better lubing the chain yourself manually as its a good opportunity to check the chain, sprockets and rear wheel and brake. Oilers are bloody expensive as well. |
Oilers are only expensive if your time is cheap. You can't get a decent dinner for two with wine for less than the cost of a v system, while the amount of time you spend oiling a bike without a centrestand on a single two or three week tour would be more than the time taken to eat the meal.
I usually cover 5 to 10k on my tours, and I wouldn't go more than 500 miles and more typically 300 without oiling. That's at least 10, or as much as 33 times oiling the chain. Life is too short. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| davebike |
 davebike World Chat Champion
 Posted: 11:00 - 15 Apr 2016 Post subject: |
Vacuum system is best value fro money notably if fitted in the touring kit form
Touring kit last 2k + miles so less lightly to run out
Fitted behind the rear no plate meets the mounting conditions AS near vertical as possible (will work on side but much less reliable ) away from heat and vibration
I been using and selling Scotoilers fro 20 years I would not own a chain driven bike without one or another auto oiler ____________________ Dave
NC750Xdct + others at work !
davebike1@gmail.com |
| MCN |
 MCN Super Spammer
| Islander |
 Islander World Chat Champion
 Posted: 12:35 - 15 Apr 2016 Post subject: |
Have a look at the PDOiler as well. It has an electronic delivery system and uses a wick rather than a nib to deliver the oil to the chain. Works well and isn't that expensive in the scheme of things.
I have a vacuum Scotoiler on my Hornet and a PDOiler on my M900. Both work well and are not too difficult to set up - the PDOiler is a bit easier to fit and set up.
You still need to check chain and sprockers periodically, and you'll need to clean them from time to time too but nowhere near as frequently as with a manually lubed chain.  |
| Ribenapigeon |
| linuxyeti |
| Matt B |
 Matt B World Chat Champion
| chris-red |
| temeluchus |
| monkeybiker |
 monkeybiker World Chat Champion
| redeem ouzzer |
 redeem ouzzer World Chat Champion
| Islander |
| temeluchus |
| Pigeon |
 Pigeon World Chat Champion
 Posted: 18:51 - 15 Apr 2016 Post subject: |
Not heard of PDOiler before, thanks Islander. Am very tempted.
I don't mind lubing my chain, do it once a week or every 150 miles.
When out on a jolly, carry a 2x2x13(ish) block of wood and a can of lube. 30 seconds to jack the bike under swingarm, spin the wheel while spraying lube everywhere.
On the plus side, I adjust chain tension every 3k miles by the width of a Rizla.
On the downside, I coat the rear wheel in lube all the time, the underside of the bike is coated. But most importantly, I spend fortunes on lube.
Probably in a year (10k miles)
1.5L of 80w90 Gear Oil
5 cans of chain wax
5 cans of dry lube
That's around £110 on lube
I just cant be trusted to use the right amount. PDOiler is 1/3 the cost of equivalent Scottoiler. Will do some reading now, but think I'm getting one  |
| MCN |
 MCN Super Spammer
| ADSrox0r |
 ADSrox0r World Chat Champion
| talkToTheHat |
| temeluchus |
 Posted: 02:52 - 17 Apr 2016 Post subject: |
The tutoro auto does work fine. If you go for it, my advice is do not bother trying to use the single or dual feed heads as they often clog or get eaten by the chain if not adjusted 100%
Position the delivery hose so the end is about an inch in front of the sprocket and dripping onto the rollers. This is the least fuss and the least human intervention needed.
along the lines of
https://i.ytimg.com/vi/dvM4HShwGd0/hqdefault.jpg
Adjusting the unit is just by a simple dial, you just tweak the knob until the chain is sufficiently oily. ____________________ Some shite cruiser. Now with guns and FREEDOM! |
The last post was made 9 years, 295 days ago. Instead of replying here, would creating a new thread be more useful? |
