scottoilers
talkToTheHat
PostPosted: 04:59 - 15 Apr 2016    Post subject: scottoilers Reply with quote
So it's time to consider a scottoiler for my gsf600s k2.
Is it worth going for the E system over the vacuum operated one, how much temperature related messing about is required on a standard v system to keep flow rate sane?
Is the dual injector worth it?
Anything else i shold consider before ordering? Anywhere that giz discaant coz bcf innit works?
Bandit. does. everything.
BrownTrousers
PostPosted: 05:37 - 15 Apr 2016    Post subject: Reply with quote
Am also considering this and interested in replies.
Dual injector being offered for free with V system on sportsbikeshop.com currently.
Bikers make great organ donors - add your name to the register
Ducati Multistrada 950 | Triumph Tiger 800 XR | Honda CBR500R | Yamaha YBR 125 Custom
c_dug
PostPosted: 05:53 - 15 Apr 2016    Post subject: Reply with quote
I swore by shaft drives, but that limits bike choice quite considerably. When I bought my vfr, one of the criteria in choosing a bike was that it came with a Scottoiler.
I've not bothered filling it up in probably 4 months now, maybe longer. Mines a single outlet, which in my experience is definitely not adequate. A twin might be better, but for piece of mind and better flexibility I'd stick with oiling by hand.
I'm going to sort myself out a squirty oil tin with some left over shaft/gearbox oil in it, I think this will be the best solution of all to be honest.
PostPosted: 07:21 - 15 Apr 2016    Post subject: Reply with quote
When they are set up properly they are brilliant.
Wifey had one on her Divvy 600 which took me ages to get right but that was many moons ago, I'm sure they are better now.
I would go electronic because it's easier to run a wire then to drill and tap a hole in a manifold. (If you have already got a hole Thumbs Up )
I have no idea about the twin feed but would expect it to be better or why would they bother making it.
Triumph Trophy Launch Edition
linuxyeti
PostPosted: 08:32 - 15 Apr 2016    Post subject: Reply with quote
I've put one of these on my CF650TR, and have another ready to put on another bike ..
https://www.tutorochainoiler.com/collections/frontpage
It gets really good reviews, no need to splice it in with the electrics, or carb. No mod to the bike itself required. Plus, it's considerably cheaper that a scottoiler.
Seems to work well, only difference being, I'm going to add the twin feed nozel. Oh, and I'm using some spare gear oil I had lying around, which feed through well.
Tony
Beware what photos you upload, or link to on here, especially if you have family members on them
barrkel
PostPosted: 10:26 - 15 Apr 2016    Post subject: Reply with quote
I fitted an e version to my ER6f while my VFR came with a vacuum operated valve version already fitted.
The single biggest problem with the vacuum version is that you need to adjust the flow rate depending on the ambient temperature. If you're living in the UK, the temperature range during the day usually isn't too large so it isn't a big problem. But many times when touring, I've had to slowly adjust the rate upwards to get some oil flowing on a motorway trip, and then find out it's entirely emptied its contents once you've gone over a mountain pass into different climate on the other side.
The e system is more expensive, but it's worth it if you tour. If you're staying in the UK and don't expect big temperature swings, then the v system may be enough.
(I used the dual nozzle on my ER6. The one that came fitted to my VFR is a single nozzle set to splash on the inside of the chain. It's definitely sufficient to oil not just my chain, but also my swingarm and rear caliper. I'd much rather a dual nozzle skimming the surface of the rear sprocket, but the VFR doesn't have a rear sprocket well shaped for this, what with the single sided swingarm.)
Ribenapigeon
PostPosted: 10:32 - 15 Apr 2016    Post subject: Reply with quote
I've come to the conclusion your better lubing the chain yourself manually as its a good opportunity to check the chain, sprockets and rear wheel and brake. Oilers are bloody expensive as well.
barrkel
PostPosted: 10:38 - 15 Apr 2016    Post subject: Reply with quote
Oilers are only expensive if your time is cheap. You can't get a decent dinner for two with wine for less than the cost of a v system, while the amount of time you spend oiling a bike without a centrestand on a single two or three week tour would be more than the time taken to eat the meal.
I usually cover 5 to 10k on my tours, and I wouldn't go more than 500 miles and more typically 300 without oiling. That's at least 10, or as much as 33 times oiling the chain. Life is too short.
davebike
PostPosted: 11:00 - 15 Apr 2016    Post subject: Reply with quote
Vacuum system is best value fro money notably if fitted in the touring kit form
Touring kit last 2k + miles so less lightly to run out
Fitted behind the rear no plate meets the mounting conditions AS near vertical as possible (will work on side but much less reliable ) away from heat and vibration
I been using and selling Scotoilers fro 20 years I would not own a chain driven bike without one or another auto oiler
Dave
NC750Xdct + others at work !
davebike1@gmail.com
MCN
PostPosted: 11:11 - 15 Apr 2016    Post subject: Reply with quote
I fitted a vac system to an 09 er6f and an E sys. to my S1000RR. No issues.
The E-sys on the S1000RR is concealed in the tail. Only thing visble is the nib and the control panel. I fitted the lubetube too as I have to open the tail to fill so I now fill about once a year. The control panel has a meter to tell how much is left in the system.
If you fit a scottoiler and store the bike unused for a while you should clean the chain and give it a wipe over with a scottoiler soaked rag. This is a sort of standard service item for open gear/chain/rope systems and a recommendation from Scottoiler.
Islander
PostPosted: 12:35 - 15 Apr 2016    Post subject: Reply with quote
Have a look at the PDOiler as well. It has an electronic delivery system and uses a wick rather than a nib to deliver the oil to the chain. Works well and isn't that expensive in the scheme of things.
I have a vacuum Scotoiler on my Hornet and a PDOiler on my M900. Both work well and are not too difficult to set up - the PDOiler is a bit easier to fit and set up.
You still need to check chain and sprockers periodically, and you'll need to clean them from time to time too but nowhere near as frequently as with a manually lubed chain. Thumbs Up
Ribenapigeon
PostPosted: 13:19 - 15 Apr 2016    Post subject: Reply with quote
I can see the convenience if you're touring. But if not it dousent take ten minutes to pop the bike up on a stand at home every four or five tankfulls.
linuxyeti
PostPosted: 13:34 - 15 Apr 2016    Post subject: Reply with quote
4 or 5 tankfulls? You either have a very small tank, abysmal fuel efficiency, or you don't lube your chain frequently enough, especially if you ride in all weathers. I lube mine every 200 miles or so, pretty much every tank full, again, especially in this weather & worse.
Matt B
PostPosted: 13:50 - 15 Apr 2016    Post subject: Reply with quote
I can't. Lots of European touring, many thousands of miles each time and I've never been tempted to fit one.
Stick a small 200ml can of lube under the seat. It takes literally 30 seconds to lube the chain, even on a sports bike without a centre stand. Every other day before you set off, job done.
PostPosted: 13:54 - 15 Apr 2016    Post subject: Reply with quote
The dual sided injector is fucking awful, stick with the single.
temeluchus
PostPosted: 14:39 - 15 Apr 2016    Post subject: Reply with quote
The cheap loobman also does the job.
I have a chameleon oiler on the GSXR which is also a good bit of kit.
monkeybiker
PostPosted: 15:41 - 15 Apr 2016    Post subject: Reply with quote
I bought one ages ago but not got round to fitting it. In theory seems just as practical as the automatic ones but at a fraction of the cost.
redeem ouzzer
PostPosted: 17:21 - 15 Apr 2016    Post subject: Reply with quote
Remember vac systems can fuck up the carburation on some bikes as you are robbing vacuum used to lift carb slides for operating the oiler valve.
Be a REAL MAN!
Islander
PostPosted: 17:29 - 15 Apr 2016    Post subject: Reply with quote
Not that old chestnut again. It uses a minimal amount of the engine vacuum to lift a valve and it's a closed system. It doesn't have any net effect overall.
temeluchus
PostPosted: 18:16 - 15 Apr 2016    Post subject: Reply with quote
You best disconnect the vacuum line from your fuel tap just in case then Razz
Pigeon
PostPosted: 18:51 - 15 Apr 2016    Post subject: Reply with quote
Not heard of PDOiler before, thanks Islander. Am very tempted.
I don't mind lubing my chain, do it once a week or every 150 miles.
When out on a jolly, carry a 2x2x13(ish) block of wood and a can of lube. 30 seconds to jack the bike under swingarm, spin the wheel while spraying lube everywhere.
On the plus side, I adjust chain tension every 3k miles by the width of a Rizla.
On the downside, I coat the rear wheel in lube all the time, the underside of the bike is coated. But most importantly, I spend fortunes on lube.
Probably in a year (10k miles)
1.5L of 80w90 Gear Oil
5 cans of chain wax
5 cans of dry lube
That's around £110 on lube Shocked
I just cant be trusted to use the right amount. PDOiler is 1/3 the cost of equivalent Scottoiler. Will do some reading now, but think I'm getting one Thumbs Up
MCN
PostPosted: 19:05 - 15 Apr 2016    Post subject: Reply with quote
Islander wrote:
Not that old chestnut again. It uses a minimal amount of the engine vaccum to lift a valve and it's a closed system. It doesn't have any net effect overall.
It will only fcuk up the carbs if the tube or Scoiler is broken. And that's rare unless improperly fitted and poorly maintained.
They are more or less fit and forget.
The thing holding it back is that some prefer to do it manually using old oil etc. Or don't see any value of an auto system.
I like. Infact I like them so much I'll put one on the shafty too. Smile
ADSrox0r
PostPosted: 19:16 - 15 Apr 2016    Post subject: Reply with quote
The only 'bad' thing I've had happen with a Scottoiler is the vacuum tube slip out of the t-piece regulator valve where I'd spliced it in. Ran like shit for a while till I realised the tank had pushed it off the last time I had it up.
I had one get gunked up with white jizz at the bottom of the reservoir too, fuck knows what that was about but I can tell you they're not meant to be disassembled. Nope.
talkToTheHat
PostPosted: 02:04 - 17 Apr 2016    Post subject: Reply with quote
Last bike was shaft drive. Before that i had 125s and didn't do that many miles.
Bandit has vacuum fuel tap and extra vacuum nipples for carb balancing so no concerns about fitting a vacuum system.
I don't do abroad or more than a tank of fuel in a day. Just losts of short trips on british roads and the odd long trip.
The white jizz is likely water/oil emulsion.
I quite like the look of the pdoiler. One knob over an lcd screen i have to mount. I'm not sure i like the wick system, i wonder whether if it does not work for me I could get a scottoiler dual injector linked up to one.
turtoro auto involves least messing about, but I assume it needs adjusting just as much as a v-system?
Time is quite valuable to me, physical effort more so. For all that I do becasue i refuse to let M.E. stop me, the less time i can spend bending over the bike on trivial things, the more productive things i can do. Anything that is a net labor saver is a win.
temeluchus
PostPosted: 02:52 - 17 Apr 2016    Post subject: Reply with quote
The tutoro auto does work fine. If you go for it, my advice is do not bother trying to use the single or dual feed heads as they often clog or get eaten by the chain if not adjusted 100%
Position the delivery hose so the end is about an inch in front of the sprocket and dripping onto the rollers. This is the least fuss and the least human intervention needed.
along the lines of
https://i.ytimg.com/vi/dvM4HShwGd0/hqdefault.jpg
Adjusting the unit is just by a simple dial, you just tweak the knob until the chain is sufficiently oily.
The last post was made 9 years, 294 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 134.22 Kb
