Mens grooming items
hellkat
PostPosted: 18:02 - 17 Apr 2016    Post subject: Mens grooming items Reply with quote
So I decided I might buy the Prez a set of hair clippers to go with the unspeakably posh man-smell that I bought him today. A razor and foam-gel-goo is one thing, these are quite another territory into which I have never ventured.
And I need to know:
(aside from the obvious) ...
* Hair clippers: does this include body hair?
Do you have to have separate:
* Beard and stubble trimmers
and/or
* Nose and ear clippers (yes yes, but why can you not do that with an extension to the beard trimmer?)
Would you buy all of those as opposed to an all in one grooming kit? Why? Why not?
Jewlio Rides Again LLB
PostPosted: 18:10 - 17 Apr 2016    Post subject: Reply with quote
The shaver I use for my face I also use for my balls. Thumbs Up
Shave your face first, obviously.
Mpd72: I can categorically say i’m Brighter than that, no matter how I come across on here.
HAHAHA HAHAHA Blew Chilly MyCrowSystems
hellkat
PostPosted: 18:17 - 17 Apr 2016    Post subject: Reply with quote
Well show me a pic then (shaver, not balls, thank you very much)
doggone
PostPosted: 18:21 - 17 Apr 2016    Post subject: Reply with quote
If it's hair and beard these are the ones to get.
It might be a bit more than you initially thought but more or less *the best*. Al lot of lesser ones will do well to last 2 or 3 years.
I expect you can trim other bits with it too. Rolling Eyes
https://www.amazon.co.uk/Wahl-Super-Taper-Hair-Clipper/dp/B000GI3V1G
Snodvan
PostPosted: 18:24 - 17 Apr 2016    Post subject: Reply with quote
HK
It is MY birthday today and being someone with very short beard / muzzy who wishes to keep those in control, but with such limited scalp hair that attention is rarely needed, I arranged to acquire
https://www.argos.co.uk/v1/static/Product/partNumber/4440965.htm
Perfectly adequate. I had one previously but being a twat I left it in a hotel room overseas.
Same thing with slightly more "gadgets" which personally I would never use.
https://www.argos.co.uk/v1/static/Product/partNumber/4441218.htm
LOTS of other option with some at stupid prices. These things DO get blunt so in my view better to buy cheaper and replace every so often --- like we are talking every 5-10 years.
Snod
04 (UK Reg) BMW F650cs, but really 02 first Reg in Holland
hellkat
PostPosted: 18:27 - 17 Apr 2016    Post subject: Reply with quote
They're mains-run?
For some reason I assumed they would be rechargeable on a little stand.
Do you not stand at the bathroom mirror and do it, then?
(that's where it appears to usually be performed with the razor: head, chops, miscellaneous other beard-trimming activities).
hellkat
PostPosted: 18:29 - 17 Apr 2016    Post subject: Reply with quote
Awww H.B. Snodders, well done on getting another year ticked up towards your Oldest Fella on the Forum badge Cool Wub xx
Snodvan
PostPosted: 19:15 - 17 Apr 2016    Post subject: Reply with quote
Thank you for the BD wish HK
Both the cheapo Babybliss ones are NiCad or similar rechargeable batteries. That means no wires etc while you use it and it will run 20-30 mins on a charge ---- usually enough for a few trims if you take the thing on hols . . . . but do not leave it in the hotel room like I did.
Snod
PostPosted: 19:16 - 17 Apr 2016    Post subject: Reply with quote
I've had the Babyliss iTrim before, was good but I didn't use it enough, and the in built battery ended up fucked.
I have a cheap battery Wahl one now, but going to invest in a rechargeable one again, likely to be this --> Remington MB320C Barba Beard Trimmer https://www.amazon.co.uk/dp/B000OS72Y0/ref=cm_sw_r_other_awd_El9exbX4JD865
hellkat
PostPosted: 19:38 - 17 Apr 2016    Post subject: Reply with quote
I have to say I'm none the wiser, despite the sterling effort you guys have made.
What's the thing they use when you go to the barbers and say "gimme a number 1" (or, apparently, a number 0) -
Does that same thing do body hair, like for gorilla body hair? Sometimes I think I have died in my sleep and come back as David Attenborough.
https://newsimg.bbc.co.uk/media/images/46400000/jpg/_46400217_gorilla.jpg
Pjay
PostPosted: 19:43 - 17 Apr 2016    Post subject: Reply with quote
I have a cordless Wahl jobbie.
Wahl are the daddies, tis why salons use them, doesn't it?
Pjay
PostPosted: 19:47 - 17 Apr 2016    Post subject: Reply with quote
As I recall:
1 = 3mm
2 = 6mm
3 = 9mm
4 = etc
5= ?????
6 = Profit
Poseidon
PostPosted: 20:01 - 17 Apr 2016    Post subject: Reply with quote
I've got a Wahl beard clipper that is awesome. I plumped the extra for the lithium ion cordless one. That thing can go months without charging (literally... I lost the charger for 11 months, yet was able to use it weekly without any loss of power). It also has a fair bit of horse power for chomping through coarser hair (could be handy for non-facial hair I suppose). They do a hair version...
https://www.amazon.co.uk/Wahl-Lithium-Power-Hair-Clipper/dp/B00M24ODIM (edit: this is the one that will do a barbers esque No1/2/3 cut)
But that might be a bit large for more intimate grooming (ears/nose etc).
I have the beard one, which comes with nostril attachement, precision trimmer and a wider head which would make fairly short work of the hair on top of your bonce.
This'un
1977 Honda CG125
swampy
PostPosted: 20:03 - 17 Apr 2016    Post subject: Reply with quote
The ones for cutting hair are bigger (wider and generally heavier duty). Beard trimmers are narrower and lighter weight. Mine is battery powered (not that I've had to change them in the last 2 years). It still has the clipper guides (#1,#2 etc), but mine also have an adjustable guide too, and I just use that in the middle setting somewhere. Take the guide off to do nose hair... Job done.
Like this one: https://www.argos.co.uk/static/Product/partNumber/2958758.htm (only not quite as cheap)
Boom_meringue
PostPosted: 20:14 - 17 Apr 2016    Post subject: Reply with quote
Do you have power in your bathroom?
I got the Mrs to buy me this set for xmas https://www.boots.com/en/Wahl-Classic-Edition-Grooming-Gift-Set_1492008/
Small trimmer is perfect for facial hair, balls and pits, big trimmer shaves my head every couple of weeks and sorts out the chest hair.
Suzuki Vstrom 1000 - looking for people to ride with
hellkat
PostPosted: 20:40 - 17 Apr 2016    Post subject: Reply with quote
Thinking We've not got power in the bathroom.
I can't see much use for anything beyond #2, I guess.
Thanks, you guys: really helpful and interesting. Cool Cool xx
mudcow007
PostPosted: 21:14 - 17 Apr 2016    Post subject: Reply with quote
I had a Remington cordless shaver with ceramic blades that was awesome - i used it everyday, lasted about 6 years unyil i dropped it an shattered the blades Crying or Very sad
I have replaced it with a Wahl* with titanium blades an its pants, so im on the hunt for a new set too
*might be Remington
haroman666
PostPosted: 21:36 - 17 Apr 2016    Post subject: Reply with quote
I use THIS for balls and face.
https://www.shavers.co.uk/media/catalog/product/cache/1/image/380x/9df78eab33525d08d6e5fb8d27136e95/5/1/5113.jpg
Ariel Badger
PostPosted: 00:01 - 18 Apr 2016    Post subject: Reply with quote
Kent Combes[url][/url]
c_dug
PostPosted: 06:03 - 18 Apr 2016    Post subject: Reply with quote
I've had the same Wahl clippers for 16 years and they're still going strong.
I'm looking to replace them, but only because having them mains powered means dragging an extension lead to the bathroom which is frustrating.
The numbers are actually 8ths of an inch for what difference it makes. My Wahl clippers also have a slidey thing that does half sizes sort of by moving the spacer forward and backward on the blades.
The main difference between head trimmers and rest of body trimmers is the size of the cutting head on the trimmers. Given a human head is a reasonably flat area (ok, round, but nothing jutting out), you can use a big wide trimmer to cut the most hair at a time.
Big trimmers are much harder to get around areas like the nose, or the gentleman sausage if that's your thing. So trimmers designed for the rest of the body generally seem to have a thinner cutting head (like an inch or less across the blades rather than 1.5 inches for head trimmers). Hair is mostly the same no matter where it's sprouting from, so the trimmers will work anywhere, but trimmers that are designed for the whole body will take longer to do a big area like the head purely because they cut less at a time.
I've rambled on a bit, but hopefully that makes some sense.
As for recommending a good product - I've been in the process of replacing mine for about 2 years and still not found something that looks as good quality for a reasonably price - given I could buy new blades and spacers for £20. Still, let us know what you go for, I might be convinced.
PostPosted: 08:45 - 18 Apr 2016    Post subject: Reply with quote
The title of this thread is very misleading. I was expecting a lively debate on the merits of diethyl ether vs flunitrazepam.
panrider_uk
PostPosted: 10:35 - 18 Apr 2016    Post subject: Reply with quote
I use Scherna trimmers for my hair. Very good - had them for years.
Philips trimmer for beard n bits. Again good. Can wash under the tap.
Both of the above are ceramic blades so no oil required.
I use Aesculap clippers for the dog. Very expensive but would trim your gorilla Smile
hellkat
PostPosted: 21:04 - 18 Apr 2016    Post subject: Reply with quote
Thinking
Hmmm, he wouldn't use all those combs. Only likely to use number 0 or 1, nothing else suits that "Geezer" look, really does it. Perhaps #2 if defurring the gorilla in the summer, I suppose.
I guess going for a Wahl might be a good start, can always donate the "longer" combs to a worthy cause.
And maybe a Babyliss for the nostril/ear conundrum. Thinking
Is the oil to stop it from rusting? I used to use an old safety razor for years on my legs/pits when I was growing up; I was fairly low maintenance* so didn't use it for ages, and in between it always got a bit "rusty" where I used to leave it out on the handbasin, invariably in a puddle of soap and water. I just used to scrub it with a toothbrush and fit a new blade when I wanted to use it again Laughing
*still am, actually... Shifty
hellkat
PostPosted: 21:17 - 18 Apr 2016    Post subject: Reply with quote
Almost certainly there must be someone with more desire than me to start such a thread (?Robby ? the latest manifestation of "Tritey")
I do, however, await its conception with interest.
hellkat
PostPosted: 21:19 - 18 Apr 2016    Post subject: Reply with quote
Ariel Badger wrote:
Helpful in the general sense of grooming, my dear, but unfortunately I think my Beloved's Kent comb days are well and truly over. Mr. Green
The last post was made 10 years, 77 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.36 - MySQL Queries: 13 - Page Size: 132.73 Kb
