exhaust swap now not running properly
chay
PostPosted: 07:59 - 22 Apr 2016    Post subject: exhaust swap now not running properly Reply with quote
Hi I have a wk 450 rx which is a crf450x rip off basically
It has a standard can with a built-in cat but no sensors so I have swapped for a full system off a crf450x
It now struggles to start and when it does it cuts out when reved
Any tips would be great
pompousporcup...
PostPosted: 08:09 - 22 Apr 2016    Post subject: Reply with quote
not enough fuel to account for the increased flow of the new system? try turning the pilot screw out half a turn and see what happens
edit: if adding fuel to the idle circuit helps, then its almost certainly a fuel issue. A reject may be needed or the same will likely happen under load
chay
PostPosted: 10:25 - 22 Apr 2016    Post subject: Reply with quote
Ok mate will give it a try cheers
Formerly known as
P.
PostPosted: 11:02 - 22 Apr 2016    Post subject: Reply with quote
Under powered 450 single.
Add powerful 450 single free flowing exhaust.
Thinking
An exhaust change alone will likely make a large difference on something like that.
chay
PostPosted: 17:37 - 22 Apr 2016    Post subject: Reply with quote
Thinking
What do you mean paddy
The last post was made 9 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 41.44 Kb
