stepper motor/ iacv question
vlewis
PostPosted: 18:25 - 28 Apr 2016    Post subject: stepper motor/ iacv question Reply with quote
thanks in advance so far for everyones help, and hello from sunny south wales lol,
i have a daytona 600 2004, with a high idling issue when cold and when warm,
when bike started from cold and warm it seems to go right up to 2/3k does come back down but very slowly, when i rev the bike it revs up and down like normal, it like the choke not coming down properly, i.e stepper motor.
it all started after a charity ride, on the way is was riding brilliant, then on way home it pissed down gave it some beans to get home and a mile before it started to have this problem, check all connections everything is dry
Question?
my stepper motor/ iacv, when bike is warm i notice it still stays in the up position, why my bike is idling high, like the choke is always on,
when i turn the ignition on and off it goes up and down as it should,
even when the bike is warm it goes all the way to the open position, comes down to normal but very slowly,
so my question is the stepper motor bad, or is there a sensor that is ment to tell the stepper motor to come back down but its not,
p.s i have tryed and tested for air leaks but all seems ok.
sorry for the essay, Very Happy Very Happy Very Happy [/b]
vlewis
PostPosted: 20:47 - 28 Apr 2016    Post subject: Reply with quote
Check the output of the coolant temperature sensor. If you can work out which wire it is check it at the ECU plug and at the sensor see how the results compare.
uberkron
PostPosted: 20:52 - 28 Apr 2016    Post subject: Reply with quote
They can get a weak or high resistance phase. They will usually work when removed but play up later while in the throttle body. I replace them in older Japanese cars regularly.
If you have a meter check resistance between windings. Should be 2 or 3 identical readings.
i ride a zip 50 2smoke. It overtakes a hundred times a day.
vlewis
PostPosted: 21:38 - 28 Apr 2016    Post subject: Reply with quote
ok thanks both shall check tomoz and let you no how it gos
vlewis
vlewis
PostPosted: 15:39 - 01 May 2016    Post subject: Reply with quote
am i able to just leave the stepper motor disconnected, i no i will have a light and maybe have to hold throttle when warm but would it be ok
thanks
will take to triumph when i have more funds but at the moment have to many rideouts to go to, Very Happy
vlewis
uberkron
PostPosted: 20:50 - 01 May 2016    Post subject: Reply with quote
You can "set " it half way and refit it unplugged so you have an idle. Check light will be on but shouldn't run differently.
The last post was made 10 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.68 - MySQL Queries: 15 - Page Size: 48.01 Kb
