Grease - When, Where (and What) to use?
Falco
PostPosted: 22:14 - 30 Apr 2016    Post subject: Grease - When, Where (and What) to use? Reply with quote
I have been doing a bit of reading, prior to removing the front caliper on my CG. I found the pad pins to be very stiff to turn on my first attempt (though turn they did), so I went looking for information about how to grease them.
The result of this is a lot of conflicting information.
I have seen opinions that run the gamut from "never put any grease near the calipers, especially copper grease and especially on the back of the pads because the grease will make its way down the pistons and cause the rubber boots to swell up" all the way to "I grease every fastener on my bike and never had a problem Thumbs Up ".
So my question is: What grease should be used and where?
There are plenty of bolts I don't want to seize but I also don't want to slap copper grease on everything and hope for the best. For example can I use it on my pad pins? Or the spark plug? Are there any general rules about what type of grease to use (copper/lithium/silicon/red rubber) for what applications?
NJD
PostPosted: 22:48 - 30 Apr 2016    Post subject: Reply with quote
I made a similar thread. Some answers on their to read through.
Islander
PostPosted: 22:51 - 30 Apr 2016    Post subject: Reply with quote
Anti seize grease (copper grease) on the pins and the back of the pads - just a smear, not too much.
Red rubber grease for seals and pistons, and if it's a sliding caliper then use this or a silicon grease (rubber friendly) on the sliding pins under the rubber boots.
Falco
PostPosted: 23:00 - 30 Apr 2016    Post subject: Reply with quote
Embarassed I do wish the search function worked for me. All I get for every search attempt is:
https://i68.tinypic.com/2s1ah35.jpg
Many thanks NJD and Islander, I'll read the already extant thread.
NJD
PostPosted: 23:06 - 30 Apr 2016    Post subject: Reply with quote
Click the "search BCF" to the right of the big search bar, gives you far better choice and works. Even when I type in a thread title that I've made it sometimes doesn't find it so I just type my username in the author box and select the section I made the post in.
FredTheHorse wrote:
Or the spark plug?
What I've only just noticed, and is interesting, is that on the thread I made and link one person says (in regards to putting copper lube on a spark plug) "Don't put it anywhere near bearings or spark plugs because of the copper particles. " and then another "You absolutely need copper grease and lithium. I wouldn't trust a spray, particularly when a very tiny bit of copper grease on spark plug threads stops them siezing to the head,"
Google seems to suggest anti-seeze on the threads and silcone / dialetric (the same thing, I think) on the ceramic part of the spark plug and in the spark plug cap.
Hong Kong Phooey
PostPosted: 23:18 - 30 Apr 2016    Post subject: Reply with quote
Me 2...
https://lmgtfy.com/?q=site%3Ahttp%3A%2F%2Fwww.bikechatforums.com%2F+grease
Falco
PostPosted: 23:20 - 30 Apr 2016    Post subject: Reply with quote
Very nice, thanks! Neither of these threads on grease come up when I search for it, but at least I get a list of results, so that is an improvement. Razz
NJD wrote:
FredTheHorse wrote:
Or the spark plug?
Yes, I noticed that as well. Not really sure which way to go on that. Having read the God.i thread, I have no inclination to get a spark plug stuck (thought it would be much less of a problem on a CG), so a tiny smear might be in order.
NJD
PostPosted: 23:40 - 30 Apr 2016    Post subject: Reply with quote
I think that thread came about as a result of a spark plug that hadn't been removed in forever, I've only been following it briefly.
On the other hand as not to cause such an issue meanwhile a deep 3/8 socket and I say 3/8 because 1/2 would be overkill and 1/4 has limitations in sizes something like this (one came with my bikes toolkit that I'm yet to use) keeps it simple. Stick a screwdriver through the hole and jobs a gooden (he says but is yet to do). Finger tight to thread the plug in and then a 1/2 turn for a new plug or 1/4 for one that's been re-used (I don't think anyone knows what that means and has their own understanding, just not to tight after being hand tightened).
https://static.flickr.com/5252/5456621384_67fd080080.jpg
Falco
PostPosted: 00:20 - 01 May 2016    Post subject: Reply with quote
Yes, it was stuck in there due to having never been removed.
My bike came without a tool kit (oh the joys of buying used) so I have only recently bought a new one (that doesn't fit in the space under the airbox Doh!).
I replaced the spark plug a few weeks back (twice actually), with a spark plug socket. It's essentially the same thing as you show; a deep socket, the difference being it narrows towards the top and has a rubber ring around the top.
The idea being that it grips the top of the spark plug; it's kind of irrelevant on a little 125 where the spark plug is so easy to access. On bigger machines the plugs seem to be much more recessed, so I guess it might come in useful when I get a bigger bike.
Matt B
PostPosted: 10:33 - 01 May 2016    Post subject: Reply with quote
The plug socket that comes in the Bandit toolkit has the rubber insert to grip the plug. I have no choice but to use it because my proper plug sockets are too fat to fit in there.
Going back to the grease thing - copper grease is fine to use on the back of pads. People who say differently are just plain wrong. Use a smear on the back of the pads where they contact the pistons. Next time you have your pads out take a look and you will see it actually thickens and hardens over time, doesn't melt. No danger of it getting onto the rotors.
NJD
PostPosted: 12:08 - 01 May 2016    Post subject: Reply with quote
Just some digging around.
"NGK does not recommend the application of lubricant to spark plug threads as the resultant reduction of frictional forces at the thread faces will render the torque charts inaccurate and over tightening could occur"
Seems like silicone on the ceramic and in the spark plug cap if any at all based on that.
.. Oh, mini edit, and there's another link somewhere that I come across written by NGK (cannot find) that states it has some coating of some form and lube is only needed on those spark plugs that do not.
stevo as b4
PostPosted: 12:31 - 01 May 2016    Post subject: Reply with quote
I always use copper grease on spark plug threads and any bolt or nut that's not plastic anywhere on the bike. A smear of copper grease on a spark plug won't hurt at all.
You shouldn't be fitting spark plugs if you need a torque chart or wrench to do the job. Common sense and experience is all that's required. If a tiny bit of copper got into the combustion chamber (another scare story myth) it won't make your engine blow up or wear out in 5miles as some say.
I use the wrong grease technically for lots off applications, like for example copper grease on battery terminals etc. But people can get far too anal about what to use for every little Job and think they need dozens of different products because it says in the book etc.
spottedtango
PostPosted: 13:00 - 01 May 2016    Post subject: Reply with quote
See if you're skint and because red rubber grease is based on vegetable oil. Could you not just use veg oil for lubing up brake caliper pistons?
PostPosted: 13:01 - 01 May 2016    Post subject: Reply with quote
I've always lightly copper-greased plug threads, and prefer to under- rather than over-tighten them.
The inconvenience of having to remove/replace or re-tighten slightly is far less than a 40+ page "plug snapped what do?" thread.
stevo as b4
PostPosted: 13:35 - 01 May 2016    Post subject: Reply with quote
It's personal preference alot of the time too. Take brake caliper pistons as an example.
Some people smear the seals and piston in clean brake fluid, some use rubber grease, silicone grease and even silicone spray.
You can use vaseline, lithium grease, copper grease, dielectric grease or molybdenum grease on battery terminals, it's not a critical application or requirement.
In a CV joint, wheel bearing, or something like an underwater marine gearbox housing, you need to use a more appropriate product to deal with the requirements, and have the properties required for dealing with more extreme applications.
It's the same deal with gasket compounds and applications too. Some people join crankcases with blue holomar, others use threebond, RTV or even bathroom silicone sealant. There's a right and wrong product for some applications, but a whole load of situations where people use their own ideas and methods for sealing and lubing things.
NJD
PostPosted: 13:59 - 01 May 2016    Post subject: Reply with quote
So in my book of notes I have copper grease as one that you use on bolts that you may want to remove in the future. So, copper grease on the oil sump plug also?
stevo as b4
PostPosted: 14:07 - 01 May 2016    Post subject: Reply with quote
It probably won't be likely to seize due to its constant immersion in oil at the end of the thread. Stopping leaks is a bigger problem for many than worrying about trying to undo the drain plug come service time IMO.
Matt B
PostPosted: 14:23 - 01 May 2016    Post subject: Reply with quote
As said, don't need to bother. Unless you leave the bike draining until every last drop of oil is out, and then scrupulously clean both threads, there will always be a smear/drip of oil on them. Worry more about replacing the sump plug washer and not over tightening.
Nobby the Bastard
Harley Gaydar
PostPosted: 14:40 - 01 May 2016    Post subject: Reply with quote
or you could use the correct grease.
https://www.paddockspares.com/red-rubber-grease.html?gclid=CK_1wJOAucwCFbQV0wodD3cOMA
(Other suppliers exist etc...)
Triumph Sprint ST 1050
PostPosted: 14:52 - 01 May 2016    Post subject: Reply with quote
Turn off adblocker for bcf. Search will work.
Falco
PostPosted: 15:48 - 01 May 2016    Post subject: Reply with quote
Out of interest does adding grease to a bolt change the torque setting at all? I know that most torque settings are given for lightly oiled bolts, would the change for grease (of whatever type) be negligible?
PostPosted: 16:01 - 01 May 2016    Post subject: Reply with quote
I use copper grease on plugs, and on most other bolts. Makes life a lot easier when you have to undo the item at some point in the future (and as I hate selling things, that could be a decade or more later).
I avoid using copper grease on anything that is going in to an oil bearing part of the bike. Don't really want the copper floating around in the oil.
I have heard of claims that copper grease should not be used on plugs for vehicles with catalytic converters. Not sure if this is true, or just one of those scare stories.
On a sump plug I wouldn't use it. They tend to be a pretty coarse thread, are not very long and have plenty of oil lubing the thread anyway.
Yes, it changes it by a quite dramatic amount.
Katy
stevo as b4
PostPosted: 18:44 - 01 May 2016    Post subject: Reply with quote
As Katy said torque settings can change alot if you lubricate a thread before tightening a fastener.
For some applications it's critical, but for many it's not. Experience and common sense tell far more than torque settings for assembly of many components. Even installing a cylinder head on a car engine with say 10bolts or studs, I'd put everything on finger tight first or using an extension bar with no breaker bar or wrench. Then I'd give everything probably 1/2 a turn in sequence, before only then looking at the full torque setting figures and setting my torque wrench to suit.
On loads of mechanical assemblies you don't need a torque setting at all, other than sense. The problem with people that don't know what they are doing but think they can follow a manual or set of figures, is that they have no experience or common sense regarding how tight things should be and they break things then. I'd never expect anyone to follow or use a torque setting on a wrench to fit a car wheel, but people that have never done it and thing a book can show them everything will try to measure everything and apply exact figures.
Some critical fasteners will specify that you torque them up dry, while others will tell you to lubricate a thread before tightening them to get the correct figures. Big end cap bolts or flywheel/clutch hubs are maybe one such example where there's an exact specific figure to achieve. A thermostat housing bolt or inlet manifold bolt less so.
Putting the manual down and using experience and feel for many things is often the right and best way to proceed IMO.
PostPosted: 20:54 - 01 May 2016    Post subject: Reply with quote
Last time I had the cam cover off on Mrs Borg's mummy bus, I fitted a new gasket, carefully cleaned the faces and the threads, lubed the bolts with 5W30 and torqued them down exactly to the specified (wet) settings, checked with both a clicky- and a deflection-wrench.
It felt like it wasn't enough, and it leaked like a sieve.
My working hypothesis is that the specified settings are safe limits for not snapping the bolts rather than for actually securing the cover, and that they fully expect mechanics to torque to that and then give the bolts another quarter or half turn for luck.
Which is what I did and it's been fine since.
Hong Kong Phooey
PostPosted: 21:00 - 01 May 2016    Post subject: Reply with quote
Suppose I must agree, never owned or used a torque wrench. Snapped a few smaller bolts in the early days, but never had anything leak or come undone since. Using right size spanner or ratchet in relation to bolt size is key.
Having said that it's a must for cylinder head bolts.
The last post was made 10 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 137.58 Kb
