| Falco |
 Falco Traffic Copper
 Posted: 22:14 - 30 Apr 2016 Post subject: Grease - When, Where (and What) to use? |
I have been doing a bit of reading, prior to removing the front caliper on my CG. I found the pad pins to be very stiff to turn on my first attempt (though turn they did), so I went looking for information about how to grease them.
The result of this is a lot of conflicting information.
I have seen opinions that run the gamut from "never put any grease near the calipers, especially copper grease and especially on the back of the pads because the grease will make its way down the pistons and cause the rubber boots to swell up" all the way to "I grease every fastener on my bike and never had a problem ".
So my question is: What grease should be used and where?
There are plenty of bolts I don't want to seize but I also don't want to slap copper grease on everything and hope for the best. For example can I use it on my pad pins? Or the spark plug? Are there any general rules about what type of grease to use (copper/lithium/silicon/red rubber) for what applications? |
| NJD |
 NJD World Chat Champion
 Posted: 22:48 - 30 Apr 2016 Post subject: |
I made a similar thread. Some answers on their to read through. |
| Islander |
 Islander World Chat Champion
| Falco |
 Posted: 23:00 - 30 Apr 2016 Post subject: |
I do wish the search function worked for me. All I get for every search attempt is:
https://i68.tinypic.com/2s1ah35.jpg
Many thanks NJD and Islander, I'll read the already extant thread. |
| NJD |
| Hong Kong Phooey |
 Hong Kong Phooey World Chat Champion
| Falco |
 Posted: 23:20 - 30 Apr 2016 Post subject: |
| NJD wrote: | Click the "search BCF" to the right of the big search bar, gives you far better choice and works. Even when I type in a thread title that I've made it sometimes doesn't find it so I just type my username in the author box and select the section I made the post in. |
Very nice, thanks! Neither of these threads on grease come up when I search for it, but at least I get a list of results, so that is an improvement.
| NJD wrote: | | FredTheHorse wrote: | Or the spark plug? |
What I've only just noticed, and is interesting, is that on the thread I made and link one person says (in regards to putting copper lube on a spark plug) "Don't put it anywhere near bearings or spark plugs because of the copper particles. " and then another "You absolutely need copper grease and lithium. I wouldn't trust a spray, particularly when a very tiny bit of copper grease on spark plug threads stops them siezing to the head,"
Google seems to suggest anti-seeze on the threads and silcone / dialetric (the same thing, I think) on the ceramic part of the spark plug and in the spark plug cap. |
Yes, I noticed that as well. Not really sure which way to go on that. Having read the God.i thread, I have no inclination to get a spark plug stuck (thought it would be much less of a problem on a CG), so a tiny smear might be in order. |
| NJD |
| Falco |
| Matt B |
 Matt B World Chat Champion
| NJD |
| stevo as b4 |
| spottedtango |
 spottedtango Trackday Trickster
| Rogerborg |
 Rogerborg nimbA
 Posted: 13:01 - 01 May 2016 Post subject: |
I've always lightly copper-greased plug threads, and prefer to under- rather than over-tighten them.
The inconvenience of having to remove/replace or re-tighten slightly is far less than a 40+ page "plug snapped what do?" thread. ____________________ Biking is 1/20th as dangerous as horse riding.
| stevo as b4 |
 Posted: 13:35 - 01 May 2016 Post subject: |
It's personal preference alot of the time too. Take brake caliper pistons as an example.
Some people smear the seals and piston in clean brake fluid, some use rubber grease, silicone grease and even silicone spray.
You can use vaseline, lithium grease, copper grease, dielectric grease or molybdenum grease on battery terminals, it's not a critical application or requirement.
In a CV joint, wheel bearing, or something like an underwater marine gearbox housing, you need to use a more appropriate product to deal with the requirements, and have the properties required for dealing with more extreme applications.
It's the same deal with gasket compounds and applications too. Some people join crankcases with blue holomar, others use threebond, RTV or even bathroom silicone sealant. There's a right and wrong product for some applications, but a whole load of situations where people use their own ideas and methods for sealing and lubing things. |
| NJD |
| stevo as b4 |
| Matt B |
| Nobby the Bastard |
| P.addy |
 P.addy Red Rocket
| Falco |
| Kickstart |
 Kickstart The Oracle
| stevo as b4 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 20:54 - 01 May 2016 Post subject: |
Last time I had the cam cover off on Mrs Borg's mummy bus, I fitted a new gasket, carefully cleaned the faces and the threads, lubed the bolts with 5W30 and torqued them down exactly to the specified (wet) settings, checked with both a clicky- and a deflection-wrench.
It felt like it wasn't enough, and it leaked like a sieve.
My working hypothesis is that the specified settings are safe limits for not snapping the bolts rather than for actually securing the cover, and that they fully expect mechanics to torque to that and then give the bolts another quarter or half turn for luck.
Which is what I did and it's been fine since. ____________________ Biking is 1/20th as dangerous as horse riding.
| Hong Kong Phooey |
The last post was made 10 years, 156 days ago. Instead of replying here, would creating a new thread be more useful? |
