| owl10 |
 owl10 Could Be A Chat Bot
| Ariel Badger |
 Ariel Badger Super Spammer
| P.addy |
 P.addy Red Rocket
| Ariel Badger |
| wristjob |
 wristjob World Chat Champion
| Ichy |
 Ichy World Chat Champion
 Posted: 22:35 - 02 May 2016 Post subject: |
I'm with Ariel on this. It's the contaminates and heat cycles from running that degrades the oil. If it's sat in an engine for 18 months doing nothing then I'd be using it without any worry. It 'might' of got a bit of water in it but it'll evaporate once the engine has run properly.
OP, 18 months is nothing. Charge battery and crank it over. Easy start is your friend. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| owl10 |
| WD Forte |
 WD Forte World Chat Champion
| P.addy |
 P.addy Red Rocket
 Posted: 00:11 - 03 May 2016 Post subject: |
It ain't gonna start first turn so the pump will shove some oil around. The head will still have oil in the cam wells anyway. Charge the battery and crank it. ____________________ a.k.a 'Geri'
| Diggs |
 Diggs World Chat Champion
 Posted: 00:42 - 03 May 2016 Post subject: |
Clean the plugs first, put a new battery on it as the old one won't hold charge and will only leave you bumping it the first time you turn the engine off, some new fuel then press the magic button. Remember that your brake pistons have probably seized, your chain will have dry links and that your clutch plates may be stuck, so don't try to ride it until you have looked at these and run it on a paddock stand in gear for a few minutes. Its a good way to check for leaks too without going for a spin and getting stranded.... ____________________ Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting... |
| c_dug |
 c_dug Super Spammer
| Diggs |
 Posted: 08:51 - 03 May 2016 Post subject: |
My comment about the new battery still stands as it will almost certainly be shagged. Bear in mind I have owned GS550s where a shagged battery means certain burning out of electrics as there is nothing to absorb the excess charge (done that...), I own a Mk1 Speed Triple where a weak battery means a new sprag clutch (not done that but know folk who have...) and nearly ridden my GSXR into a wall when bumping off at a petrol station with a flat battery. ____________________ Now - Speed Triple, old ratty GS550, GSXR750M
| owl10 |
| owl10 |
 Posted: 06:41 - 04 May 2016 Post subject: |
Nope, that'll work. Just put red-red, black-black. ____________________ a.k.a 'Geri'
| Diggs |
 Posted: 08:04 - 04 May 2016 Post subject: |
Connect black-black before red-red and disconnect red before black...
Don't leave on for more than a split second or you may smell burning, which is rarely good. Honestly, buying a new bike battery is the safest option! ____________________ Now - Speed Triple, old ratty GS550, GSXR750M
| Polarbear |
 Polarbear Super Spammer
| BillyJ |
 BillyJ Nearly there...
| Pjay |
 Pjay World Chat Champion
| ZebraDriver |
 ZebraDriver Scooby Slapper
| ZebraDriver |
| BillyJ |
| Diggs |
 Posted: 07:43 - 05 May 2016 Post subject: |
Have I been doing it wrong all these years!!! I was always told to have the earth connected at all times when connecting or disconnecting the positive to avoid possible damage. You do get a small spark 'tis true, but it reduces the potential for other problems.
Do we have a qualified auto-electrician in the house to clear this up? I am happy to stand corrected...  ____________________ Now - Speed Triple, old ratty GS550, GSXR750M
The last post was made 10 years, 128 days ago. Instead of replying here, would creating a new thread be more useful? |
