Silly question, will a unplugged optimiser drain my battery?
Willy_westside
PostPosted: 07:46 - 05 May 2016    Post subject: Silly question, will a unplugged optimiser drain my battery? Reply with quote
So like a lot of people out there that aren't hardcore all weather riders like DrSnooSnoo, I suffer from low battery levels when my bike has been stood in the garage for long periods of rubbish weather. I've installed a cheap halfords optimiser which several of the reviews warned about leaving plugged in for days at a time.
I can turn the power to my garage on and off from the house without going outside so my plan was to leave it all wired up when ever i leave the bike then the night before I'm planning to ride (long ride or work) i can just flick the switch in the house and I'll be guaranteed the battery will be ready by the morning.
My question is this, by leaving it wired up to the battery with the power turned off could I inadvertently be draining my battery even more?
Thanks in advance
WW
jaffa90
PostPosted: 09:35 - 05 May 2016    Post subject: Reply with quote
Do you have any lights showing on the charger when unplugged?
Fizzer Thou
PostPosted: 10:46 - 05 May 2016    Post subject: Reply with quote
A friend had left his bike connected to an Optimate for several weeks,not realising that he had forgotton to switch it on.It drained the battery so severely that it had to be replaced.HTH
Always have a 'Plan B'
monkeybiker
PostPosted: 10:52 - 05 May 2016    Post subject: Reply with quote
I had similar. Had it plugged in and switched on but one of the wires had a bad connection and I ended up with a completely flat battery and had to replace it.
A100man
PostPosted: 11:41 - 05 May 2016    Post subject: Reply with quote
Trickle chargers are hateful devices. If you're leaving your bike for any length of time just disconnect the earth.
Matt B
PostPosted: 12:53 - 05 May 2016    Post subject: Reply with quote
Why are they hateful? Once you have the Optimate lead connected to the battery it's simple to plug it in and keep the battery topped up every now and then. Much less grief than disconnecting the battery every time you park the bike up for a while, especially when you consider that some bikes need the tank lifted, or other major surgery, to get to the terminals.
DrSnoosnoo
PostPosted: 13:07 - 05 May 2016    Post subject: Reply with quote
I reckon it would drain the battery. If, like mine, when I plug to the bike and not into the wall, the internal fan (of the charger) powers up, as do the LED lights. That takes power from the bike.
I'd have the leads out ready to be plugged in and plug it in for a day every week or something (perhaps that might be excessive) if I was leaving it for a long period.
Nobby the Bastard
Harley Gaydar
PostPosted: 13:46 - 05 May 2016    Post subject: Reply with quote
FFS, just ride the fucking bike regularly. Then you won't need to trickle charge it...
Triumph Sprint ST 1050
rubyhorse2
PostPosted: 14:04 - 05 May 2016    Post subject: Reply with quote
i've used one for years on all my bikes.
Much better to be using one than not as they tend to the battery, not just charge it.
DrSnoosnoo
PostPosted: 15:47 - 05 May 2016    Post subject: Reply with quote
I did suggest this to him via text message.
Willy_westside
PostPosted: 18:03 - 05 May 2016    Post subject: Reply with quote
That's what i suspected. I'll just unplug it when I'm not using it.
Thanks
A100man
PostPosted: 18:50 - 05 May 2016    Post subject: Reply with quote
A number of bad experiences I guess resulting in knackered gel batteries, dead cells in lead acid, broken optimates... In the long run just disconnecting works better for me.
Willy_westside
PostPosted: 20:02 - 05 May 2016    Post subject: Reply with quote
I can't be dealing with disconnecting. I have to remove my fuel tank and some fairing to get to the battery so not the easiest. Most of the time I don't plan on leaving it for a long time either. The weather will just turn crap and I can't be bothered going out in the wet and cold when i can sit in a nice warm car and sup a cuppa on my way to work.
jaffa90
PostPosted: 23:00 - 05 May 2016    Post subject: Reply with quote
You should have a permanent battery cable connection kit with the charger, this socket lead kit can be routed so that you can couple up with the charger without removing anything on the bike.
temeluchus
PostPosted: 01:30 - 06 May 2016    Post subject: Reply with quote
If you even need an optimate something is horribly wrong with your bike or battery.
If the bike is going to sit through winter or whatever, pullnthe battery off the bike and keep it somewhere warm. A cheap £4 wall wart trickle charge for a bit before putting it away and when digging out will be fine.
monkeybiker
PostPosted: 08:52 - 06 May 2016    Post subject: Reply with quote
I had a serious case of man flu over the xmas period so couldn't ride it.
The last post was made 10 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 89.61 Kb
