| rubyhorse2 |
 rubyhorse2 Traffic Copper
 Posted: 11:51 - 05 May 2016 Post subject: chain and sprockets - how easy? |
well i've got all parts for my pre-euro trip, which consists of
2 new tyres
chain and sprockets
spark plugs
oil and filter
brake pads
i've just rang rocket centre and its £240 to fit it all.
Now i'm more than happy doing oil and filter, brake pads and the spark plugs.
tyres i can get done for £10 each
only issue i have is the chain and sprockets. never done this on a motorbike before (plenty times on MTB), is it something i can have a go at and be confident its safely installed? happy to buy the tool for the chain and can take my time, just worried about making sure chain is installed properly but i guess its similar to a MTB chain.
Come on, fill me with confidence and say its an easy job  |
| pompousporcup... |
 pompousporcup... World Chat Champion
| rubyhorse2 |
| Minty |
 Minty World Chat Champion
| rubyhorse2 |
| pompousporcup... |
 Posted: 12:09 - 05 May 2016 Post subject: |
oh.. nice
you'l be wanting to rivet the links. if you're going travelling, get a pro to do it. they'l be liable for anything that happens i think.
if it was a split link type thing i'd say do it yourself but rivets can fail very easily if not done right |
| rubyhorse2 |
 Posted: 12:10 - 05 May 2016 Post subject: |
damn didnt want to hear that  |
| Minty |
 Posted: 12:13 - 05 May 2016 Post subject: |
I have done it once, on my Fireblade and it is still there and I have not died that many times.  ____________________ My fingers smell of your mum. |
| pompousporcup... |
| killa |
 killa Won't Shut Up
| davebike |
 davebike World Chat Champion
 Posted: 12:36 - 05 May 2016 Post subject: |
Make sure you get the riveting right a sapped chain would ruin you euro trip ! ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| weasley |
 weasley World Chat Champion
| rubyhorse2 |
| davebike |
 Posted: 12:50 - 05 May 2016 Post subject: |
No most look fine I never river a chain unless I had a proper rivet tool and I fussy which chains I will fit I refuse to fit cheap chains to powerful bikes
But I am a pro so not getting it right could be costly ____________________ Dave
[email protected] |
| DRZ4Hunned |
 DRZ4Hunned World Chat Champion
| Minty |
 Posted: 13:28 - 05 May 2016 Post subject: |
Splitter:
https://assets.jewson.co.uk/category-images/9624/Main/9624.jpg
Impact gun requirement negated with a bit of wood through back wheel (to butt against swingarm - chain still on at this point) and crack the nut off the front sprocket whilst everything is 'locked up'. ____________________ My fingers smell of your mum. |
| rubyhorse2 |
| Islander |
 Islander World Chat Champion
 Posted: 13:39 - 05 May 2016 Post subject: |
It's not hard to do if you take your time. When I did the chain on my Hornet, I loosened the front sprocket nut before I did anything else by using a breaker bar and holding the brake on while I cracked it. I used the brake to hold the wheel while I cracked the rear sprocket nuts as well.  |
| Minty |
| Islander |
 Posted: 13:53 - 05 May 2016 Post subject: |
I have the Draper tool which works well.
Either use a grinder to cut the old chain in two or grind the heads off of the soft rivets before you attempt to press them out.  |
| rubyhorse2 |
| smallfrowne |
 smallfrowne Scooby Slapper
| pompousporcup... |
| rubyhorse2 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 15:44 - 05 May 2016 Post subject: |
How much?
I got what looks like an identical set off of eBay for £11.79
Granted, I snapped the top clean off the outer part while winding the inner in. Fortunately it was on the 2nd rivet and I was giving it Full Hulk to be sure it was spread. So, disposable, but at under £12 still cheaper than going to a garage. And now I know the "snap tool, then reduce torque by 10%" limit.
And yes, angle grinder to split, although a grinding wheel in a normal drill will easily enough remove the heads and let you press the pins out. ____________________ Biking is 1/20th as dangerous as horse riding.
The last post was made 10 years, 128 days ago. Instead of replying here, would creating a new thread be more useful? |
