Microsoft office....harder to get free now?
AngelGrinder
PostPosted: 18:41 - 09 May 2016    Post subject: Microsoft office....harder to get free now? Reply with quote
As per title really, havn't needed it personally for many years...now I do. I was running a cracked version, but MS have discovered it and want an activation code. I'm feeling really stingy....how easy is it to get code generators that work? Or cracked versions that don't get discovered?
Or shall I just stump up the £6 a month?
linuxyeti
PostPosted: 18:55 - 09 May 2016    Post subject: Reply with quote
Any specific reason not to use LibreOffice? I use it at home & at work, has good compatability with MS Office, can export and import various formats.
Good connectors to various DMS , such as Alfresco etc, and more generic DMS using the CMIS protocol, maintaining version control.
Beware what photos you upload, or link to on here, especially if you have family members on them
kingnathski88
PostPosted: 20:11 - 09 May 2016    Post subject: Reply with quote
I got one a few months back and it works ok.
Pirate Bay is your friend.
andym
PostPosted: 20:21 - 09 May 2016    Post subject: Reply with quote
In all my years of using dodgy software I've only ever had 2 programs stop working (briefly) as they were allegedly unregistered etc.
Switch off all updates for Windows and after you install anything go to the preferences and disable the Check for updates (wording could be different).... then go to your firewall and add an exception for said software then block all access to and from the internet
PostPosted: 20:30 - 09 May 2016    Post subject: Reply with quote
OpenOffice. Thumbs Up
So much easier than spending time fucking around with serials and activation codes, not to mention there's nothing to worry about with updates or firewalls. Wink
linuxyeti
PostPosted: 20:56 - 09 May 2016    Post subject: Reply with quote
Yeah, I agree, although my preference is for LibreOffice, seems to have a faster development cycle, but not much in it between OpenOffice & Libreoffice
Also ...
Really advocating, if you use MS Windows, to switch off updates (including security updates) ???? Shocked
dydey90
PostPosted: 21:32 - 09 May 2016    Post subject: Reply with quote
i have a 100% legit unlimited access code for office 2007, but I probably shouldn't post in a thread that's not marked NSFW as it can then be found and blocked. If they care. I still use it though, so I'd like it to still work.
anthony_r6
PostPosted: 22:14 - 09 May 2016    Post subject: Reply with quote
The only versions I have seen have been self-activation in the .exe. No serial, no activation, no issue.
Through work I get access to MS office pro+ 2016 for £10, but only one licence.
J.M.
PostPosted: 10:42 - 10 May 2016    Post subject: Reply with quote
Again, what is it that you actually want to do?
LibreOffice and OpenOffice are good.
If you just want to make documents, why not even consider something like Google Docs? You can download the files as pdf/docx.
Personally I now use Latex most of the time I want to make a document. It's got a steep learning curve, but makes awesome looking documents with little effort once you learn it.
2004 R1 & 2018 XSR900
UnknownStuntm...
PostPosted: 12:37 - 10 May 2016    Post subject: Reply with quote
Do people still want 9 year old software? I mean, yeah, it's what businesses 'use' but only because other businesses do.
Sack it off and use something more modern. Google Docs is pretty good, and as above, if you need it to be offline, LibreOffice is still actively and aggressively developed.
J.M.
PostPosted: 12:43 - 10 May 2016    Post subject: Reply with quote
Even Google Docs can be accessed offline now!
nb: never tried it because if I don't have an internet connection, I'm not anywhere that I would consider doing work Very Happy
dydey90
PostPosted: 18:17 - 10 May 2016    Post subject: Reply with quote
What's the difference between Office '07 and the more modern software for a home user?
I'll keep using it because it's free and because I'm a dinosaur. The only reason I'm using Windows 7 is because there's no 64 bit version of Windows 2000 Razz
metalangel
PostPosted: 02:29 - 11 May 2016    Post subject: Reply with quote
I got Office 2007 recently and it does everything you need it to.
Unfortunately, Windows 10 knows this and so pops up nag notifcations (!!!) saying that I have an old version of Office and wouldn't I like a 50% discount on the newest version instead?
AngelGrinder
PostPosted: 17:11 - 11 May 2016    Post subject: Reply with quote
Thanks all, and thanks for everyone who PM'd me with info or links.
I've just become self employed, so need to be able to create invoices, do expenses etc.
Office online looked ok, but couldn't open normal documents as templates etc.
Will give Openoffice/libre and see how they go!
doggone
PostPosted: 16:37 - 22 May 2016    Post subject: Reply with quote
My Office 2010 180 day grace just expired on W10 but the activator still works OK to renew it.
Andy_Pagin
PostPosted: 18:02 - 22 May 2016    Post subject: Reply with quote
Libreoffice will do 99% of what MsOffice does, and 100% of what you actually need to do. The 1% is whistles & bells.
linuxyeti
PostPosted: 18:07 - 22 May 2016    Post subject: Reply with quote
Hi there
Depending on your business, a dedicated accounting or even crm and/or erp package may be worth looking at.
Have a look at those mentioned here ..
https://www.smallbusinesscomputing.com/slideshows/open-source-accounting-software-for-small-business.html
Also worth having a look here as well.
https://www.odoo.com/
Tony
Im-a-Ridah
PostPosted: 19:34 - 23 May 2016    Post subject: Reply with quote
Libre Office is my first preference, over MS office. Even if MS Office was free, I would still use Libre Office.
someotherguy
PostPosted: 00:48 - 28 May 2016    Post subject: Reply with quote
Why?
Andy_Pagin
PostPosted: 11:42 - 28 May 2016    Post subject: Reply with quote
Timmy wrote:
Why?
It runs on Linux and Windows.
The MsOffice ribbon is horrible and counter intuitive, unless you use it all the time.
someotherguy
PostPosted: 12:08 - 28 May 2016    Post subject: Reply with quote
I do use it all the time (I'm a financial modeller). I was hoping for someone to give me a reason to switch. What can LibreOffice Calc do that MS Excel can't?
Andy_Pagin
PostPosted: 12:29 - 28 May 2016    Post subject: Reply with quote
Nothing, they're both just simple spreadsheets with a lot of fancy visual effects. Libreoffice does support Open Document Format though, not sure if MSOffice does. Some organisations are making ODF their default format, whether this will catch on and become a significant consideration is anybody's guess. I suspect if it does catch on MS will incorporate it anyway.
If I had to give a reason to switch it would be that MS is driven by market forces and continually has to 'new and improved'-ise it's products, so you can never be certain in which direction they'll go next, and personally I've had a few apps broken when MS decided to drop/change features or lock down stuff they'd suddenly decided was a security risk. Libreoffice being open-source isn't under that pressure and theoretically should provide a more predictable platform, which may be a consideration if you're developing extremely complex workbooks.
someotherguy
PostPosted: 18:30 - 28 May 2016    Post subject: Reply with quote
Is there VBA in LibreOffice?
Andy_Pagin
PostPosted: 18:49 - 28 May 2016    Post subject: Reply with quote
A glance through stuff on the internet about this seems to suggest you can use VBA, but it ain't a good idea, there are other ways of achieving the same results. Personally I've never gone that far with spreadsheets.
someotherguy
PostPosted: 21:25 - 28 May 2016    Post subject: Reply with quote
Just had a quick look also. I don't like the idea of rewriting 10 years of add-ins Laughing
I like the open source nature of it though. Hopefully they'll add VBA support one day.
The last post was made 10 years, 107 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 130.61 Kb
