quick car question
andyscooter
PostPosted: 08:29 - 10 May 2016    Post subject: quick car question Reply with quote
been offered a set of wheels for my car
only thing is they are two inches bigger then standard
should they fit or not without having to have spacers etc
there looks to be good clearance round wheels at the moment
PostPosted: 08:43 - 10 May 2016    Post subject: Reply with quote
No point changing. You'll have increased tyre prices and you may need spacers depending on what car they came from. The ride will be quite different also.
arry
PostPosted: 08:49 - 10 May 2016    Post subject: Re: quick car question Reply with quote
More important questions - Are they same:
PCD
Centre Bore
Offset
Width
More info required.
Robby
Dirty Old Man
PostPosted: 08:54 - 10 May 2016    Post subject: Reply with quote
If they are the right wheels for the car, then the bigger diameter isn't a problem, you fit lower profile tyres to make the overall diameter the same.
However, as others have, there are a lot more variables than just rim diameter to make wheels fit. Also low profile tyres tend to give a harsher ride and can lose grip in a less predictable way. More sidewall = more flex, which is useful in keeping the contact patch the same size on mac struts.
andyscooter
PostPosted: 10:01 - 10 May 2016    Post subject: Reply with quote
wheels where off a Peugeot 205 gti black steely alloy type ones
was thinking of seeing if they would just go onto the 206 I have
B5234FT
PostPosted: 10:05 - 10 May 2016    Post subject: Reply with quote
See if you can find a set on ebay and post the link, from there people will know what wheels you're talking about and can hopefully find the relevant info.
arry
PostPosted: 10:16 - 10 May 2016    Post subject: Reply with quote
Same PCD and CB, likely different offset - looks like it can vary heavily on the 206 by model type / year
https://www.wheel-size.com/size/peugeot/206/2012/
1.6 and 1.9 GTi alloys are also different, so which are they?
1.6 wheels:
https://images.pistonheads.com/nimg/21189/205gti_1-L.jpg
1.9 wheels:
https://images.pistonheads.com/nimg/23392/Peugeot%20205%20GTI%20(19)-L.jpg
Specs for both are here:
https://forum.205gtidrivers.com/index.php?showtopic=125923
andyscooter
PostPosted: 12:22 - 10 May 2016    Post subject: Reply with quote
Was the 1.9 wheels but sold to someone else
Not a major loss just as they were cheap with good tyres would of had them
Would of blinged the pug up a bit
The last post was made 10 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 55.8 Kb
