Sprockets + chain size query - 2004 Bandit 600 K4
dansos
PostPosted: 14:06 - 11 May 2016    Post subject: Sprockets + chain size query - 2004 Bandit 600 K4 Reply with quote
Hi. My sprockets and chain are due to be replaced and I wanted to switch things up a tiny bit.
I wanted to get a 14T front sprocket, standard size rear:
https://www.banditmaniashop.co.uk/sprocket-rear--renthal-hard-anodised-for-bandit-600-95---04-mk1--mk2-199-530-47ha-673-p.asp
https://www.banditmaniashop.co.uk/sprocket-front-14t-renthal-for-bandit-600--1200-mk1--mk2-289-530-14-684-p.asp
I was looking into getting a DID X-ring gold chain fitted however I am not sure how long it needs to be seeing that Im changing the front sprocket size?
Also, maybe someone here has better suggestions for my bike when it comes to the sprocket/chain manufracturers and models?
Any advice would be much appreciated.
tom_e
PostPosted: 14:35 - 11 May 2016    Post subject: Reply with quote
1 tooth less I'd just buy the standard length which you'll probably find will fit no problems but if it is a little slack then you can always just chop a link off.
PostPosted: 14:40 - 11 May 2016    Post subject: Reply with quote
Resulting in an odd number of links, you say? Thinking
The internets screams "NO!" but I'm not entirely sure why. I think I need an animated gif.
Kris
PostPosted: 14:49 - 11 May 2016    Post subject: Reply with quote
I think standard length chain will be fine. Katy (Kickstart) has often linked a gearing website that calculates all this out for you.. Might be worth a PM..
www.prisonplanet.com
Matt B
PostPosted: 14:50 - 11 May 2016    Post subject: Reply with quote
https://www.gearingcommander.com/
Edit - which says standard length chain will be fine and sprocket distance is only reduced by 0.14 inches.
PostPosted: 14:53 - 11 May 2016    Post subject: Reply with quote
Never mind me, apparently the internets is talking about pairs of inner + outer links, so it's only possible to have an even number. I'm a simple Borg, I tend to think in terms of outer links since that's in practice what you'd see and count when it's mounted.
Also: standard length. I've been both up and down a tooth on the front with standard chains, no problems.
Meatybeaty
PostPosted: 15:01 - 11 May 2016    Post subject: Reply with quote
Hi ,take a look at this, its an old site but will give you plus and minus into changing sprockets , its all gain and lose , that swap acceleration for top end speed Thumbs Up
PostPosted: 15:56 - 11 May 2016    Post subject: Reply with quote
For one tooth you need approx 4mm adjustment. It'll be fine.
dansos
PostPosted: 18:21 - 12 May 2016    Post subject: Reply with quote
Thanks for all of your replies. You've been really helpful!
The last post was made 10 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 60.71 Kb
