Is my ECU toast?
Bike Chat Forums Index -> The Workshop Goto page 1, 2, 3, 4  Next
Conzar
PostPosted: 14:24 - 12 May 2016    Post subject: Is my ECU toast? Reply with quote
So my bike (ZX6R B1H) cut out last week and wont start.
Recovered it home and managed to get it to throw out some fault codes...nine to be precise!
11 - Main throttle sensor malfunction, wiring open or short
12 - Inlet air pressure sensor malfunction, wiring open or short
13 - Inlet air temperature sensor malfunction, wiring open or short
14 - Water temperature sensor malfunction, wiring open or short
15 - Atmospheric pressure sensor malfunction, wiring open or short
21 - Crankshaft sensor malfunction, wiring open or short
23 - Camshaft position sensor malfunction, wiring open or short
31 - Vehicle-down sensor malfunction, wiring open or short
32 - Subthrottle sensor malfunction, wiring open or short
The bike cut out at 60 with total loss of power, all the electrics work fine, it tuns over but with no start. Took ages to get it show the fault codes, seems as though it only does it randomly which leads me to think of the ECU again.
The bike was running fine before hand and there is too many sensors failing for it to be a coincidence in my opinion.
found a thread with a 2008 zx6r with very similar issues to mine, he replaced the ecu and the bike fired up strait away.
Could mine be a similar fix?
Thread
https://www.zxforums.com/forums/zx-6r-forum/151330-08-zx6r-wont-start-multiple-error-codes.html
Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
11:05:35 Rob Fzs: i just wanna own an rd350 valve before they send us to war with durkadurkastan
Matt B
PostPosted: 15:10 - 12 May 2016    Post subject: Reply with quote
That's a lot of faults, and yes it could be the ECU. £80 2nd hand off ebay because I bet you don't have a mate with the same bike to swap over and check?
Conzar
PostPosted: 15:28 - 12 May 2016    Post subject: Reply with quote
Just bought on off ebay for £25, im praying this solves it!
PostPosted: 15:40 - 12 May 2016    Post subject: Reply with quote
Could be the ECU, or could be a disconnected multi-connector? Always check the cables first! Smile
Conzar
PostPosted: 15:46 - 12 May 2016    Post subject: Reply with quote
Had the tank off last night as was searching around for any wire breaks or shortages, disconnected and reconnect every multi connecter, but if the ECU doesn't fix it i shall be going over again in more detail Thumbs Up
Matt B
PostPosted: 16:32 - 12 May 2016    Post subject: Reply with quote
Bargain. Definitely worth a punt at that price Thumbs Up
PostPosted: 17:53 - 12 May 2016    Post subject: Reply with quote
Do they have one of those shonky multi-earth connector things?
Or perhaps you fitted a tail tidy?
Conzar
PostPosted: 18:25 - 12 May 2016    Post subject: Reply with quote
What's one of those shonky multi earth connectors?
aha defiantly not done anything like that, although that is hilarious!
PostPosted: 18:36 - 12 May 2016    Post subject: Reply with quote
Some bikes have a hidden ?diagnostic? socket somewhere in the loom where a whole bundle of earth wires connect together into one earth wire. Thing is, they are in series so if one connection fails, everything upstream of it does too.
Was a particular problem in Blackbirds as I recall and caused odd/intermittant ECU/FI faults.
https://www.bikersoracle.com/blackbird/forum/archive/index.php?t-16438.html
Entirely possible there is something similar on other bikes.
Conzar
PostPosted: 18:54 - 12 May 2016    Post subject: Reply with quote
Yeah mine has a diagnostic socket, used it for getting the fault codes.
All you have to do is eath it to the bike but it was not doing after several trys, then randomly it worked and threw out the codes so i don't know if that had anything to do with it???
But cheers ill have a another check tonight Thumbs Up
Meatybeaty
PostPosted: 21:10 - 12 May 2016    Post subject: Reply with quote
Hi Conzar, definately sounds like your on the right line with the ECU Thumbs Up
winz
PostPosted: 23:37 - 12 May 2016    Post subject: Reply with quote
WOW, that's crazy.
Current Bikes: BMW K1200S
Previous: Honda CBR929RR, Honda CBR1100XX, Honda CB600F
Nobby the Bastard
Harley Gaydar
PostPosted: 00:27 - 13 May 2016    Post subject: Reply with quote
I believe that Stinky was taking the piss about a crap earth being a crap diagnostic socket.
To explain Stinky's post to the terminally stupid, somewhere on your loom all your earths join together. If this is broken (due to a load of earths being linked in sequence in the wiring) it could have the same symptoms as every sensor failing.
Triumph Sprint ST 1050
Conzar
PostPosted: 13:59 - 16 May 2016    Post subject: Reply with quote
New ECU turned up and unfortunately it did not fix the fault.
Going to see if a motor electrician can help as I reached the limit on my electrical knowledge I'm afraid.
PostPosted: 14:03 - 16 May 2016    Post subject: Reply with quote
You have checked the main earths right?
Conzar
PostPosted: 15:15 - 16 May 2016    Post subject: Reply with quote
Being honest pal I'm not entirely sure for what I'm checking.
Rob Fzs
PostPosted: 18:10 - 16 May 2016    Post subject: Reply with quote
Have you checked the fuses? is it sparking?
unconnect everything and then reconnect it
'00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30> Yamaha RD350 YPVS F2 > Kawasaki ZZR 600 D1 > Yamaha TZR 250 2MA >Suzuki TL1000R > Yamaha TDR250 > Honda 929 blade > Suzuki SV1000 > Honda H100
Mod 2 Passed 09/06/2011
Nobby the Bastard
Harley Gaydar
PostPosted: 19:32 - 16 May 2016    Post subject: Reply with quote
Rob Fzs wrote:
unconnect
Unconnect? Fucking unconnect? Jebus H crust
PostPosted: 20:42 - 16 May 2016    Post subject: Reply with quote
This ^
Conzar
PostPosted: 20:43 - 16 May 2016    Post subject: Reply with quote
Wafer_Thin_Ham wrote:
This ^
By this do you mean the engine ground lead?
PostPosted: 22:17 - 16 May 2016    Post subject: Reply with quote
Check the - from battery, should also have one on the engine? Mines near the starter motor and got furry as f. Quick scuff with sandpaper and wd40 around it, chuck some grease lightly on it and reattach.
My R1 also had a multi plug that could corrode and cause random issues like lights just not working and funny temp readings.
Image....to the left of the right side coolant pipe in middle of engine.
https://i.imgur.com/acFQzaa.jpg
Conzar
PostPosted: 01:59 - 17 May 2016    Post subject: Reply with quote
Tonight I disconnected and cleaned all two of the earth wires and still not starting Crying or Very sad
Time to invest in a new loom or take it somewhere?
Meatybeaty
PostPosted: 06:34 - 17 May 2016    Post subject: Reply with quote
Hi Conzar, just a thought, it reminded me of an earlier post where someone installed a new engine, and couldn't get it started, when you got the new ECU, did you put the red key in to set up the immobiliser again, dont know if yours is configured that way but worth a try, if you got a red key , if it does you can reprogramme your black keys Question Thumbs Up
Conzar
PostPosted: 12:25 - 17 May 2016    Post subject: Reply with quote
Iv'e only got 2 black keys, I can check up to see if mine is configured that way but I think now it is to do with a fault in the loom and every bike shop I've tried is too busy to have a look at.
Used looms are £50 online, is it worth a punt at just fitting a new one?
mysterious_rider
PostPosted: 13:02 - 17 May 2016    Post subject: Reply with quote
Hello mate definitely worth a punt. I did on my zzr. In the end it turns out killswitch was faulty (i tried to fix by joining with wire before but thinner than original. Cdi needs to read a certain voltage or it thinks its being hotwired and wont start. So i just twisted wires together).
A new loom isnt too hard to fit. Just start at the arse end and work your way along. U may find it easier to unplug the old one a bit at a time and plug in new as you go.
50 quid is less than an hours labour charge from a garage. So worth a shot id say.
KAWASAKIIIII
The last post was made 10 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 130.45 Kb
