| Conzar |
 Conzar World Chat Champion
 Posted: 14:24 - 12 May 2016 Post subject: Is my ECU toast? |
So my bike (ZX6R B1H) cut out last week and wont start.
Recovered it home and managed to get it to throw out some fault codes...nine to be precise!
11 - Main throttle sensor malfunction, wiring open or short
12 - Inlet air pressure sensor malfunction, wiring open or short
13 - Inlet air temperature sensor malfunction, wiring open or short
14 - Water temperature sensor malfunction, wiring open or short
15 - Atmospheric pressure sensor malfunction, wiring open or short
21 - Crankshaft sensor malfunction, wiring open or short
23 - Camshaft position sensor malfunction, wiring open or short
31 - Vehicle-down sensor malfunction, wiring open or short
32 - Subthrottle sensor malfunction, wiring open or short
The bike cut out at 60 with total loss of power, all the electrics work fine, it tuns over but with no start. Took ages to get it show the fault codes, seems as though it only does it randomly which leads me to think of the ECU again.
The bike was running fine before hand and there is too many sensors failing for it to be a coincidence in my opinion.
found a thread with a 2008 zx6r with very similar issues to mine, he replaced the ecu and the bike fired up strait away.
Could mine be a similar fix?
Thread
https://www.zxforums.com/forums/zx-6r-forum/151330-08-zx6r-wont-start-multiple-error-codes.html ____________________ Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
11:05:35 Rob Fzs: i just wanna own an rd350 valve before they send us to war with durkadurkastan |
| Matt B |
 Matt B World Chat Champion
| Conzar |
| MarJay |
 MarJay But it's British!
 Posted: 15:40 - 12 May 2016 Post subject: |
Could be the ECU, or could be a disconnected multi-connector? Always check the cables first!  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| Conzar |
| Matt B |
| Conzar |
 Posted: 18:25 - 12 May 2016 Post subject: |
What's one of those shonky multi earth connectors?
aha defiantly not done anything like that, although that is hilarious! ____________________ Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
| Conzar |
 Posted: 18:54 - 12 May 2016 Post subject: |
Yeah mine has a diagnostic socket, used it for getting the fault codes.
All you have to do is eath it to the bike but it was not doing after several trys, then randomly it worked and threw out the codes so i don't know if that had anything to do with it???
But cheers ill have a another check tonight  ____________________ Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
| Meatybeaty |
 Meatybeaty World Chat Champion
 Posted: 21:10 - 12 May 2016 Post subject: |
Hi Conzar, definately sounds like your on the right line with the ECU  |
| winz |
 winz World Chat Champion
 Posted: 23:37 - 12 May 2016 Post subject: |
WOW, that's crazy. ____________________ Current Bikes: BMW K1200S
Previous: Honda CBR929RR, Honda CBR1100XX, Honda CB600F |
| Nobby the Bastard |
| Conzar |
| P.addy |
 P.addy Red Rocket
| Conzar |
| Rob Fzs |
 Rob Fzs World Chat Champion
| Nobby the Bastard |
 Posted: 19:32 - 16 May 2016 Post subject: |
Unconnect? Fucking unconnect? Jebus H crust ____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Triumph Sprint ST 1050 |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
| Conzar |
| P.addy |
 P.addy Red Rocket
 Posted: 22:17 - 16 May 2016 Post subject: |
Check the - from battery, should also have one on the engine? Mines near the starter motor and got furry as f. Quick scuff with sandpaper and wd40 around it, chuck some grease lightly on it and reattach.
My R1 also had a multi plug that could corrode and cause random issues like lights just not working and funny temp readings.
Image....to the left of the right side coolant pipe in middle of engine.
https://i.imgur.com/acFQzaa.jpg |
| Conzar |
 Posted: 01:59 - 17 May 2016 Post subject: |
Tonight I disconnected and cleaned all two of the earth wires and still not starting
Time to invest in a new loom or take it somewhere? ____________________ Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
| Meatybeaty |
 Posted: 06:34 - 17 May 2016 Post subject: |
Hi Conzar, just a thought, it reminded me of an earlier post where someone installed a new engine, and couldn't get it started, when you got the new ECU, did you put the red key in to set up the immobiliser again, dont know if yours is configured that way but worth a try, if you got a red key , if it does you can reprogramme your black keys  |
| Conzar |
 Posted: 12:25 - 17 May 2016 Post subject: |
| Meatybeaty wrote: | Hi Conzar, just a thought, it reminded me of an earlier post where someone installed a new engine, and couldn't get it started, when you got the new ECU, did you put the red key in to set up the immobiliser again, dont know if yours is configured that way but worth a try, if you got a red key , if it does you can reprogramme your black keys  |
Iv'e only got 2 black keys, I can check up to see if mine is configured that way but I think now it is to do with a fault in the loom and every bike shop I've tried is too busy to have a look at.
Used looms are £50 online, is it worth a punt at just fitting a new one? ____________________ Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
| mysterious_rider |
 mysterious_rider World Chat Champion
The last post was made 10 years, 130 days ago. Instead of replying here, would creating a new thread be more useful? |
