Keeping a steady throttle opening on bumpy roads
B5234FT
PostPosted: 09:11 - 13 May 2016    Post subject: Keeping a steady throttle opening on bumpy roads Reply with quote
Hi, this may sound daft but bear with me!
I ride a Triumph Street Triple which has fairly heavy engine braking even at cruising speeds and I find it difficult to maintain a steady throttle on bumpy sections of country roads which occasionally results in engine braking and then too much throttle and then engine braking until either I ease off, or the road flattens out.
It's really uncomfortable and doesnt do the confidence any good, how do people manage it?
rubyhorse2
PostPosted: 09:18 - 13 May 2016    Post subject: Reply with quote
sounds like you might be holding the throttle too tightly, you literally can just rest your hand on it you know.
Or just blast along it and have fun Smile
Monkeypony
PostPosted: 09:34 - 13 May 2016    Post subject: Reply with quote
Your arms should be loose and flappy, not locked and tight, this will help your body smooth out the bumps and eliminate the jerky throttle.
Current bike - 2018 H2-SX, 2004 SV1000s, 2016 Aprilia RSV4 RF, 2017 Sherco SERF 300, 2003 Suzuki DRZ400 (stolen - AY53 JUU)
B5234FT
PostPosted: 09:41 - 13 May 2016    Post subject: Reply with quote
I possibly am gripping too tight, but my arms are loose and I can waggle my elbows as someone else suggested this.
I've adjusted the slack out of the throttle
I guess I just need to try and relax
Bozzy
PostPosted: 09:59 - 13 May 2016    Post subject: Reply with quote
Could this be making the issue worse?
Undinist
PostPosted: 10:01 - 13 May 2016    Post subject: Reply with quote
You could change to a higher gear to reduce the engine braking.
B5234FT
PostPosted: 10:03 - 13 May 2016    Post subject: Reply with quote
It seems to have improved it, I did it last night and rode to work this morning. The issue still exists when cruising at say 6krpm in 6th
It happens in top gear
PostPosted: 12:38 - 13 May 2016    Post subject: Reply with quote
This could cause a tantrum from the FI system too.
All the reasonably recent triumphs I've seen have a throttle cable tensioner cam that activates when you turn the ignition on to set the correct "closed" throttle tension. My understanding is it uses this position as a basis for the idle setting (which it sets each time based on thottle position, atmospheric pressure, and as far as I know, the phase of the moon).
I spoke to the guy who helped design it, he was very proud of it and couldn't see why I thought it was just something else to go wrong once the bike got a little older and the cables start going sticky.
B5234FT
PostPosted: 13:20 - 13 May 2016    Post subject: Reply with quote
interesting, begs two thoughts. First I adjusted it with it running, so hopefully it should be ok. Second, why would there have been any slack in the first place...
Chuffin Nora
PostPosted: 13:44 - 13 May 2016    Post subject: Reply with quote
1st & 2nd fingers on the brake lever.
And when you hit smooth road keep them there for that oft needed ½ second's difference between a crumple zone and getting home in one piece. Thumbs Up
Same for clutch lever, why not.
There's a fine line between integrity
PostPosted: 13:55 - 13 May 2016    Post subject: Reply with quote
Presumably because it is normal to have some slight slack in a throttle cable when it is fully closed.
It also didn't do a whole lot as I recall. It deformed the cable sideways slightly. I suspect wouldn't be able to take a large amount of slack out of the cable.
B5234FT
PostPosted: 14:08 - 13 May 2016    Post subject: Reply with quote
Interesting feature, cheers for the info!
PostPosted: 14:12 - 13 May 2016    Post subject: Reply with quote
Fit a Cramp Bustertm.
https://kawasakier6.files.wordpress.com/2012/03/crampbuster-kawasaki-er6.jpg
Rest your hand gently on the now-misnamed "grip", use the heel of your hand to maintain throttle.
Alternatively, it may significantly exaggerate the problem, so be sure to video the results for our amusement. Whistle
Notj7
PostPosted: 14:13 - 13 May 2016    Post subject: Reply with quote
Grip the tank properly with your knees and engage your core. You should be able to take your hands off the handlebars, even when braking, and still be upright (easier said than done, though).
If you do that, and you go over bumps, your hands will barely be touching the grips; so you won't be transferring the momentum onto your hands and then onto the throttle as a result.
Left the forum.
PostPosted: 15:19 - 13 May 2016    Post subject: Reply with quote
You can get a nice, steady maintenance of throttle position with one of these.
WD Forte
PostPosted: 17:23 - 13 May 2016    Post subject: Reply with quote
Cramp buster?
pah! thas fer jessies
just jam some clothes line between the grip and switch housing
like a real man
bikers smell of wee
PostPosted: 17:41 - 13 May 2016    Post subject: Reply with quote
Slack or free-play in a cable is a requirement, because the walls of the outer casing have thickness. When you bend the cable by turning the bars the outer casing becomes longer. The slack is to prevent the engine revving on full lock and to prevent the push-pull arrangement from binding.
orac
PostPosted: 17:45 - 13 May 2016    Post subject: Reply with quote
this might seem like an odd question, but what road is bumpy enough to cause these issues at around 60mph.
put the slack back into the cable, its there for a reason, its been put there by bike designers and engineers since the earliest incarnation of motorcycle. The slack is there to ensure the butterflies return to the correct position for idle air fuel mix.
The FI wont be OK, it sets the idle each an every time the bike is started, not just the time when you adjusted the cable.
Unless you undoubtable know more than the people who designed the thing the chances are they will know that the system needs a little slack.
honestly, when I get a little over excited on mine the front will spend a reasonable amount of time in the air, so a few bumps on a normal ride on a normal bit of road should not be causing any issues. Just relax, let the bike do what it does.
MCN
PostPosted: 18:59 - 13 May 2016    Post subject: Reply with quote
Poor Man's Cruise control is the wee pinky finger around the bar end to retard the throttle a bit.
If you have ghey twirling bar ends then you are ghey and like being bumped on the back roads.
Pigeon
PostPosted: 19:17 - 13 May 2016    Post subject: Reply with quote
My Striple generated a touch too much slack after 10k miles and needed a small adjustment.
6k rpm in 6th gear is about 70mph no?
My bike does a weird surge when rolling off the throttle from WOT, when it gets to about 5.5k rpm, always has done.
But other than that, fuelling seems spot on.
2013 bike.
Also, "heavy engine braking". Seems the opposite to me. But I vaguely remember reading the '13 onwards bikes had some thing which adds a little fuel to stop the revs dropping......mmm, maybe that explains the annoying surge.
What year is yours?
EDIT:
Sold. I have now bought one.
chickenstrip
PostPosted: 19:27 - 13 May 2016    Post subject: Reply with quote
Probably because your other ride is a V twin? I've noticed more engine braking on the Striple, being used to an IL4. Caught me out a couple of times in 1st and 2nd, where it's noticeable, on my first couple of rides.
c-m
PostPosted: 11:09 - 14 May 2016    Post subject: Reply with quote
Could be suspension. My bike is currently like a hard tail and it's near impossible to keep a steady throttle over bumps. Suffice to say I've got another one on the way
Val
PostPosted: 20:28 - 14 May 2016    Post subject: Re: Keeping a steady throttle opening on bumpy roads Reply with quote
I am not familiar with Triumph, but why you just do not go 1 or 2 gears up? I doubt it will have the same engine braking in 6th gear. Means you will be riding in lower revs. You can also do 18 front sprocket.
barrkel
PostPosted: 01:36 - 15 May 2016    Post subject: Reply with quote
Always be braking or accelerating Smile
Though seriously, unless I'm on a motorway (usually a smooth surface) or going past a speed camera, I'm very rarely holding the same speed. I'm always reacting to the view ahead, potential hazards, planning overtakes, etc.
The two finger trick (using the brake lever as a reference point) works well enough for me when I'm inclined to hold a low gear at constant, higher revs, which isn't too often. When I'm being very polite (e.g. touring and going through a village), I simply shift to higher gears and lower revs, where the throttle is less responsive.
I doubt gripping the bars too tight is the problem; a looser grip isn't enough to fix it. I grip lightly enough that I can e.g. brake fairly hard when holding on by just my right and not affect my line, but when I'm going over a very bumpy surface, I'll reduce the load on the bike's suspension by tensioning my legs, letting the bike bounce around beneath me. That naturally increases the amount of movement at the human-bike interface which can lead to varying throttle inputs.
I think gripping too tight is more a problem for bikers who dislike windy weather.
Undinist
PostPosted: 02:23 - 15 May 2016    Post subject: Reply with quote
This may be one of those things where you just to have to get someone else to test ride the bike. Do you trust your dealer?
The last post was made 10 years, 171 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 130.55 Kb
