Pulse Adrenaline 125 Help XD
SundayFunday
PostPosted: 21:17 - 16 May 2016    Post subject: Pulse Adrenaline 125 Help XD Reply with quote
Hi guys, (Sorry if this is in wrong section i'm new xD)
I recently passed my CBT and bought my first bike off of eBay which is a Pulse Adrenaline 125cc. I bought the bike on Friday and when I viewed it, it started fine and rode fine.
This morning I tried to start it just to see if it was still running fine and it wouldn't start!! Sad
Here is a video of the problem https://www.youtube.com/watch?v=Cur8IMapyC4
Any advice? I was wondering if the battery could be out of juice, but this is the first time i've had any road vehicle and have no idea about mechanics and not sure where the battery on the bike is located xDD
Also another problem is when you click the rear brake it does not turn on/trigger the brake lights, any ideas?
I would very much appreciate any advice/help!
Thanks guys!
mrbox
Wonderwall
PostPosted: 21:30 - 16 May 2016    Post subject: Reply with quote
battery is flat. battery is probably under the seat.
you can adjust the point at which the brake light comes on by turning the adjuster on the rear brake light switch Thumbs Up
next time put it in the workshop section. welcome to the forum
Current bikes: RE Himalayan, Bandit 12, MZ250ES
ZX-7R This post is not being displayed because the poster is banned. Unhide this post / all posts.
SundayFunday
PostPosted: 21:35 - 16 May 2016    Post subject: Reply with quote
Thanks for the quick reply and help !
I forgot to mention the indicators and headlights work fine, if the battery was flat shouldn't they not be working? I'm not trying to be funny or anything i'm genuinely wondering as I'm new to bikes haha xD
Once again thanks for the quick response Thumbs Up Very Happy
mrbox
Wonderwall
PostPosted: 21:38 - 16 May 2016    Post subject: Reply with quote
takes a lot more out of the battery trying to turn the bike over. the battery might be past its prime. you should be able to push start the bike until you can get a battery.
SundayFunday
PostPosted: 21:43 - 16 May 2016    Post subject: Reply with quote
I'm such a noob
SundayFunday
PostPosted: 21:45 - 16 May 2016    Post subject: Reply with quote
ZX-7R wrote:
Probably has enough to power the lights but not turn the engine over.
Charge it and go from there if still having problems.
Thanks mate will get the tools out tomorrow Razz
PostPosted: 22:40 - 16 May 2016    Post subject: Reply with quote
First thing you'll want to do is to check the level of the electrolytes in the cells
https://p.globalsources.com/IMAGES/PDT/B1091578118/Lead-Acid-Dry-Charged-Motorcycle-Battery-12v-9ah.jpg
If any of them are below the lower level mark, top them up with distilled / deionised water which you should be able to get from a garage, a moderate sized supermarket or at a pinch Halfrauds.
Next, while it's charging, get yourself a cheap multimeter and work out why it's flat. I'd take a wild guess that the charging system is hosed, and the seller just charged up the battery enough to get rid of it.
Don't just start throwing random parts at it, you can easily turn a simple fix into a very expensive one.
Once the battery is charged you should get a voltage of about 12.5V across the terminals. With the engine running, it should rise to about 14V, maybe a little more if you rev it. Much above or below that and you've got a problem, and we can take it from there.
The last post was made 10 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 65.35 Kb
