Do you bother to replace sump plug/washers?
Cronik
PostPosted: 12:22 - 20 May 2016    Post subject: Do you bother to replace sump plug/washers? Reply with quote
Whatever they're called...Cronik does not certainly know.
£7 seems too taxing
*A Vacuous Vacancy*
DrSnoosnoo
PostPosted: 12:24 - 20 May 2016    Post subject: Reply with quote
Not the plug, but washer yes. If it's already crushed, it won't crush as well the next time and you then risk stripping the thread much easier.
BTTD
PostPosted: 12:30 - 20 May 2016    Post subject: Reply with quote
Copper or aluminium washers are cheap to replace. Some people prefer dowty washers.
B5234FT
PostPosted: 13:49 - 20 May 2016    Post subject: Reply with quote
I never used to as they dont come in with the filters (stupid) or the plugs (more stupid) so are easy to forget.
After having one not seal on someone elses car and having to go 50 miles out of my way to fix it, I started keeping them on the shelf and my tame parts fella is a legend and now tapes the appropriate one to the box for anything I order even if I forget to ask.
skatefreak
PostPosted: 14:00 - 20 May 2016    Post subject: Reply with quote
Not had a problem yet so don't bother... *shrugs*
PostPosted: 14:02 - 20 May 2016    Post subject: Reply with quote
Yes, with Dowty washers.
https://www.hitchcocksmotorcycles.com/accessory-engine-gasketseals-gen#part_6079
jaffa90
PostPosted: 15:54 - 20 May 2016    Post subject: Reply with quote
Just clean mine and apply a little sealant to the washer.
nisp
PostPosted: 16:51 - 20 May 2016    Post subject: Reply with quote
if its a copper or aluminium washer I just anneal them.
Suzuki TS 50 1999 Honda CB 125 t2 1981 Yamaha XJ 600 s Diversion Honda cx 500 MZ ETZ 250 1985 Yamaha FZR 400 1981 Suzuki TS 185 1984 Triumph bonneville 790 2001 MZ TS250 1979 Suzuki sv 650 1999 KTM exc RFS 450 2007 Hercules mx 125 1976
Snowdonia Rider
PostPosted: 17:09 - 20 May 2016    Post subject: Reply with quote
Washer yes, plug no. For the price of a washer it'd be criminal not to.
FlightRisk
PostPosted: 17:12 - 20 May 2016    Post subject: Re: Do you bother to replace sump plug/washers? Reply with quote
Cronik wrote:
£7 seems too taxing
From Honda/Yamaha/Kawasaki or whoever in a nicely labelled separately packed little plastic bag - £7.
From your local hardware merchant - probably about 0.20p
Honda CB500S
EazyDuz
PostPosted: 21:41 - 20 May 2016    Post subject: Reply with quote
I swap the plug with a magnetic ended one and keep it, washers maybe once every 3rd oil change. For the sake of a few pence its worth it
Commuter_Tim
PostPosted: 21:56 - 20 May 2016    Post subject: Reply with quote
I just bought a 1995 Bandit 600, drained the oil and the plug washer was so mashed it was effectively bonded to the drain bolt.
I had to blowtorch the thing for far too long to remove the washer until I can replace the bolt.
Replace your washer man. (if the threads look damaged, replace the bolt too)
I ride a Bandit 600... badly.
Islander
PostPosted: 22:03 - 20 May 2016    Post subject: Reply with quote
Crush washers are pennies and ensure a decent seal without over tightening. They're also a consumable. Why wouldn't you replace them?
Raffles
PostPosted: 22:35 - 20 May 2016    Post subject: Re: Do you bother to replace sump plug/washers? Reply with quote
That's amazing value for money
PostPosted: 22:59 - 20 May 2016    Post subject: Reply with quote
Don't replace them always, but do often. Tight git, so often reuse them if only used once.
But they are cheap if bought in bulk. Measure it, then look on Ebay and buy a packet of a few dozen.
Katy
smegballs
PostPosted: 03:25 - 21 May 2016    Post subject: Reply with quote
I always do, it only costs a few quid for 20 or so, so why not. I took a few with me touring for when I changed my oil along the way, the tiny size and weight means it is no bother.
trevor saxe-coburg-gotha
PostPosted: 03:33 - 21 May 2016    Post subject: Reply with quote
I've never replaced either on six bikes and 10 or more oil changes on each. Yet to ever notice any oil loss around the sump plug. I probably do tend to under-torque slightly though, fwtw.
RhynoCZ
PostPosted: 10:04 - 21 May 2016    Post subject: Reply with quote
I always make a visual check and if the copper washer looks good I reuse it. Thumbs Up
There goes next to no torque to screw down the sump plug, so the washer never gets damaged.
grr666
PostPosted: 10:05 - 21 May 2016    Post subject: Reply with quote
Even Mercedes Benz charge just 58p for one to suit my van. Also got 20 litres of OE low ash oil for £50!!!!
Alan1986
PostPosted: 13:56 - 21 May 2016    Post subject: Reply with quote
I have the same bike as Cronik, (I have ridden mine Very Happy)
Someone recommended an M12 Dowty washer to me on here,
I had a look on eBay and they were about a pound for 2,
Probably get them cheaper elsewhere, but that would last me a year,
So at least you know the size as well now
Cbt Done, Currently wobbling around on a Cbf125 and love it
DAS some time soon
Cronik
PostPosted: 14:07 - 21 May 2016    Post subject: Reply with quote
ACF50 arrived today. Going to blob it on and watch it emanate.
Start of next month the Cee-Ronik will tax it, insure it, and quite certainly...ride it!
*A Vacuous Vacancy*
Hong Kong Phooey
PostPosted: 14:16 - 21 May 2016    Post subject: Reply with quote
Never. I don't replace brake caliper bolts either.
Unless it's damaged it goes right back in. Sump is not high pressure area, never had a leak from the bolt area.
Commuter_Tim
PostPosted: 19:53 - 21 May 2016    Post subject: Reply with quote
I've always been surprised how low sump plug Torque is, it's around an M12 bolt and only torqued to around 20nm on my bikes.
Is there a logical reason the torque is so low for sump plugs? (in comparison to the size of the bolt/thread)
Hong Kong Phooey
PostPosted: 21:09 - 21 May 2016    Post subject: Reply with quote
It's not load bearing, it's a large bolt purely to flow at suitable rate.
The last post was made 10 years, 148 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 124.32 Kb
