Wifi range boost?
Bike Chat Forums Index -> The Geek Zone Goto page 1, 2  Next
DrSnoosnoo
PostPosted: 16:37 - 21 May 2016    Post subject: Wifi range boost? Reply with quote
Ahoy ahoy ahoy.
I'm with Virgin and have the superhub thingy.
Now. The speeds wireless-ly are very good downstairs but upstairs the signal can be a little lacking, so far as having no signal in the back bedroom.
I've had a quick look on ebay and for sale are some devices that get plugged in which supposedly pick up the weak signal, amplify it and emits that signal. Are they as good as they say?
Also, if they're rubbish, could you provide me with links to what I would need to solve this issue?
image riot
PostPosted: 16:56 - 21 May 2016    Post subject: Reply with quote
I had the same issue with the Superhub. What helped a lot for me was to use an external router plugged into the Superhub and that extended the range. I switched the Superhub to 'modem mode' to do this. Not really what you expect from a 'Superhub' but it worked for me.
https://help.virginmedia.com/system/selfservice.controller?CMD=VIEW_ARTICLE&ARTICLE_ID=27555&CURRENT_CMD=SEARCH&CONFIGURATION=1001&PARTITION_ID=1&USERTYPE=1&LANGUAGE=en&COUNTY=us&VM_CUSTOMER_TYPE=Cable
GSXR750 > GSXR1100 > ZX9R > CBR900RRP >CBR929RR>K1200S
DrSnoosnoo
PostPosted: 16:58 - 21 May 2016    Post subject: Reply with quote
I know the grand sum of cock all about routers. How would i choose what to buy?
image riot
PostPosted: 17:01 - 21 May 2016    Post subject: Reply with quote
For me I used a Netgear one I had lying around but you can pick up cheap ones on ebay. I'm not an expert myself but I'm sure there's extenders on ebay too.
CaNsA
PostPosted: 17:44 - 21 May 2016    Post subject: Reply with quote
Chuck the hub in "modem mode" and grab a Netgear WNDR3700 then chuck ddwrt on it.
WIFI ALL THE PLACES!
DrSnoosnoo
PostPosted: 17:57 - 21 May 2016    Post subject: Reply with quote
I will look for one of those WNDRs and then I'll be back later to ask wtf is ddwrt! Smile
t121anf
PostPosted: 19:11 - 21 May 2016    Post subject: Reply with quote
Defo bin the super hub, I did and never looked back.
andy_uk
PostPosted: 22:58 - 21 May 2016    Post subject: Reply with quote
DrSnoosnoo wrote:
wtf is ddwrt! Smile
It's a 3rd party firmware upgrade. Much more powerful than the OEM firmware. I use it here to wirelessly link routers 'cause I can't be bothered to run CAT5 everywhere Wink
https://www.dd-wrt.com/site/index
herulach
PostPosted: 23:44 - 21 May 2016    Post subject: Reply with quote
What are you connecting to? And have you tried basic stuff like changing the channel first?
If its a proper puter then get a new network card with external higain antenna, if it's a laptop or similar then you'll need a new router, but I wouldn't recomend the one Cansa posted simply because it doesn't have replaceable antenna. If you find you need a bit more oomph still you're kind of stuck.
I use an Asus AC56U, which does a solid 250mbps across opposite corners of the house (probably 10m in a straightline, through 3 walls and the floor.
YBR 125>FZS600
CaNsA
PostPosted: 23:46 - 21 May 2016    Post subject: Reply with quote
Good advice, but the VM Hub is shit. Complete and utter shit,
If OP was using a different device I would have offered the same info as you.
herulach
PostPosted: 00:18 - 22 May 2016    Post subject: Reply with quote
100% agreed, I have one too!
Still think a router with replaceable antennas is a good idea though.
YBR 125>FZS600
anthony_r6
PostPosted: 10:06 - 22 May 2016    Post subject: Reply with quote
£17.99 WiFi extender from Argos (TP Link) did me alright. Cheap and cheerful and the signal no longer drops. Plug it in near the hub, let it connect to it wirelessly (using WPS) and then move the plug where it can still pick up a good signal, somewhere between the hub and the area you're looking to reach. It's about as easy as any solution can get.
DrSnoosnoo
PostPosted: 10:54 - 22 May 2016    Post subject: Reply with quote
Upstairs, the missus struggles with her laptop. Also we bave some wireless cameras we use to spy on the birds, the signal is very slow and thus the picture is very stop starty and sometimes no signal at all.
I might try changing the channel on the hub now and see if theres a difference. What do replaceable antennae routers have as a bonus? Does the antenna help boost the signal more?
Does ddwrt effectively boost the wndr signal even more?
CaNsA
PostPosted: 10:55 - 22 May 2016    Post subject: Reply with quote
Yes.
You can increase the transmitting power too Very Happy
Omega
PostPosted: 11:02 - 22 May 2016    Post subject: Reply with quote
I tried using a couple of different wifi extenders and found them to be unreliable and slow.
I've got something similar to this now and am happy with it:- https://www.argos.co.uk/static/Product/partNumber/1168680.htm
It's not perfect but it was easier and cheaper than upgrading my router.
DrSnoosnoo
PostPosted: 11:27 - 22 May 2016    Post subject: Reply with quote
CaNsA wrote:
Yes.
Theres one on ebay im watching that finishes tonight so I'll have a punt. Thumbs Up
DrSnoosnoo
PostPosted: 21:03 - 22 May 2016    Post subject: Reply with quote
OK, step forward has been taken. I won a WNDR3700-100UKS "300 Mbps Gigabit Wireless N Router".
And it'll be with me probably by end of the week. I like the feature of having my hard drive plugged into it so stuff on the network can see that.
Anyway, I've been on that ddwrt wesbite, and I'm possibly being very lazy, but I can't really see how to download what I need to download. I found the supported devices tab and found some versions of that router, not sure how I'll know unless it's on a sticker on the unit when it arrives. EDIT - oooh it's a v3, I found that out ...
This webpage is the wiki for it, is it a case of following some simple destructions ?
CaNsA
PostPosted: 21:40 - 22 May 2016    Post subject: Reply with quote
Yeppers.
Update the stock netgear firmware using this
WNDR3700 v3 Firmware - Webflash image for first installation
https://www.dd-wrt.com/routerdb/de/download/Netgear/WNDR3700/v3/dd-wrt.v24-21061_NEWD-2_K2.6_mini-WNDR3700v3.chk/4036
Once that has been done, upgrade the DDWRT firmware with this.
https://download1.dd-wrt.com/dd-wrtv2/downloads/betas/2016/05-19-2016-r29739/broadcom_K26/dd-wrt.v24-29739_NEWD-2_K2.6_mini-WNDR3700v3.chk
DrSnoosnoo
PostPosted: 16:06 - 25 May 2016    Post subject: Reply with quote
CaNsA wrote:
Yeppers.
Ok. I've got the router through. Reading the instructions regarding the 30/30/30 reset it says I have to hold the reset button while unplugging etc. I assume this means the Restore Factory Settings button underneath the router? There's only a power button on the back otherwise which you can't really hold down, seeing as it's just a push switch thingy.
CaNsA
PostPosted: 16:41 - 25 May 2016    Post subject: Reply with quote
https://i.imgur.com/azv8Bg3.png
DrSnoosnoo
PostPosted: 16:55 - 25 May 2016    Post subject: Reply with quote
Yeah I got it. I've just done the upgrade ddwrt bit and it kicked me out sending me to 192.168.1.1/upgrade.cgi. how long should I wait for something to happen? Should I reset the router?
DrSnoosnoo
PostPosted: 17:12 - 25 May 2016    Post subject: Reply with quote
Oh I just switched the router off n on again and I'm back. Now, to look through these settings and see if I can understand anything ...
DrSnoosnoo
PostPosted: 20:25 - 25 May 2016    Post subject: Reply with quote
Next question, what stuff do I play with to get me some super awesome signal all over the house?
CaNsA
PostPosted: 20:32 - 25 May 2016    Post subject: Reply with quote
In the Wireless tab, put a tick in the "advanced settings" box.
Look at TX Power and Antenna Gain.
https://dd-wrt.com/wiki/index.php/QCA_wireless_settings#TX_Power
DrSnoosnoo
PostPosted: 18:33 - 26 May 2016    Post subject: Reply with quote
Next Next question.
Why does this build not have access to USB, under services? I only have access to Services, VPN and Hotspot. To a hard drive across a network would be swish!
EDIT - Assume it's in the Mega build (link enclosed to the download) ?
I assume this build gives more awesome buttons that I probably don't need access to as a basic user?
The last post was made 10 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 132.56 Kb
