Cars in the outside lane.
Kawasaki Jimbo
PostPosted: 21:01 - 27 May 2016    Post subject: Cars in the outside lane. Reply with quote
I'm no newbie but somehow I've missed this tip until recently. It's not uncommon to encounter a single car on a deserted stretch of dual carriageway (A10) which will not budge from the right hand lane. I figure they're either self-annointed alpha-males/females who think they belong in the overtaking lane, or they have such poor spatial awareness that having the nearest kerb just two feet away from their right side window is less scarey than having it eight feet to the left and out of view.
I've tried Delboy's tip and it really works. Until now I'd have been either in their 6 o'clock position and expecting that my headlight centrally positioned in their rear view mirror would convey the message, "I'm on a sportsbike, what do you think I want to do?" or in the "8 o'clock" position (centre line just to my left) for a good view ahead, still with a view to getting past. Occasionally my patience will run out and I'll undertake. "4 o'clock" is a place I don't really want to be, but used momentarily it does seem to influence car drivers to move to the left as if by magic.
https://m.youtube.com/watch?v=REU39NgkBws
tl:dw - Try 6.30 to 9.30 mins.
PostPosted: 21:05 - 27 May 2016    Post subject: Reply with quote
Saturday mornings on the A2 you usually get a lot of hung-over third-laners. I just go around. If they want to use the third lane I'll use another.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:17 - 27 May 2016    Post subject: Reply with quote
I just give it the berries in the inside lane. Aint got the time for their shit.
Triumph Sprint ST 1050
PostPosted: 21:27 - 27 May 2016    Post subject: Re: Cars in the outside lane. Reply with quote
https://www.youtube.com/watch?v=ZgdufzXvjqw
MCN
PostPosted: 21:28 - 27 May 2016    Post subject: Reply with quote
Standard approach.
Pass on inside and kick the door mirror off as you go past. Rolling Eyes
First ensure there's no PoPo around and do them ahp the inside.
PostPosted: 21:35 - 27 May 2016    Post subject: Reply with quote
https://i.imgur.com/BOo3mTo.gif
BTTD
PostPosted: 22:07 - 27 May 2016    Post subject: Reply with quote
Laughing That's brilliant.
I've watched a few of Delboys vids, but there is one where he started banging on about what a great job MAG do and how we should all be members. Apparently we should read up on it. Rolling Eyes That pissed me off.
On the whole there's some interesting stuff he posts on the workshop vids.
Overtaking dawdlers, if there's a gap you can get through, use it.
PostPosted: 23:40 - 27 May 2016    Post subject: Re: Cars in the outside lane. Reply with quote
I've have been past in the left hand lane at 6:40 while he was still Teffing his Jedi mind tricks.
Beehive Bedlam This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
PostPosted: 08:22 - 28 May 2016    Post subject: Reply with quote
M1 is usually nose to tail in lane 3 full of Audis and BMWs who rarely let you past. I just undertake them all in the rarely used inner lanes when on the bike.
PostPosted: 08:45 - 28 May 2016    Post subject: Reply with quote
Is't possible? Does BCF actually... agree on something? Shocked
[Looks out window for other Signs of the Apocalypse]
PostPosted: 08:54 - 28 May 2016    Post subject: Reply with quote
Not really there's just a lot of people out there who don't need to watch some fool blabbering on a vlog to know how to get along the road.
PostPosted: 09:10 - 28 May 2016    Post subject: Reply with quote
I think Mr Moonfleet should try riding in rush hour rather than cruising along at lunch time. It's very different......
PostPosted: 09:23 - 28 May 2016    Post subject: Reply with quote
Actually I was going to say the same. If I tried his tactic on my commute I would be sat behind every car until it got to a slip road. At least one of his examples was looking like they were going to move anyway, and in fact started moving before he'd even closed up to jedi-range.
The other problem with his tactic is if you get fed up with waiting for them to move and switch to a left-side pass, you're movement in their mirror might be what causes them to notice you and suddenly try to 'get out of your way'.
PostPosted: 10:08 - 28 May 2016    Post subject: Reply with quote
They made the bikes narrow and powerful for a reason. Any gap is a way of making progress Laughing
sepher
PostPosted: 10:33 - 28 May 2016    Post subject: Re: Cars in the outside lane. Reply with quote
6:36 would of been a perfect opportunity to get past Very Happy
Also if you get in that position (4 o clock?) his in on a dual carriageway I've actually seen cars pull over staying in that right lane expecting you to filter past on the right side between a car and the kerb Shocked so then you have to hang back as if to say your not overtaking so they resume normal position and then you can filter past on the left.
techathy
PostPosted: 11:32 - 28 May 2016    Post subject: Reply with quote
In lower density traffic DCs I’d do a variation of Del's suggestion.
Approaching a car hogging lane 2 make sure I’ve got a 10mph or bigger speed difference. At about 80-100m move to the extreme right of the lane and a single quick main-beam flash, then return to the centre of the lane. This will either cause them to change lanes or they’ll ignore you. If they’ve not started change lanes by 50m out I’ll move to the left hand side of the lane and evaluate an immediate undertake, which almost certainly is on. If it’s not on then I’ll drop into to my close following awaiting overtake opportunity position, rather than my standard distances (standard & close are relative. My close following distance is bigger than the typical following distance).
If it's high density traffic, which is typical, then make progress in what seems the most prudent manner for the exact situation.
PostPosted: 12:23 - 28 May 2016    Post subject: Reply with quote
So you flash a vehicle over when you're 20 seconds away then sit 10 seconds back expecting them to move?
kramdra
PostPosted: 12:56 - 28 May 2016    Post subject: Reply with quote
I just stay left. Lane is always empty.
Vid above he gets far too close for my liking. Any "pressuring" on a car is asking to be brake checked. It is much safer to go between two cars.
Val
PostPosted: 14:17 - 28 May 2016    Post subject: Reply with quote
Just overtake in the left lane whilst doing a wheelie and giving the two fingers sign.
Safer and you are more visible that way Laughing
techathy
PostPosted: 14:35 - 28 May 2016    Post subject: Reply with quote
20 seconds away? Laughing I think your calculator is broken.
A car doing 70mph in lane 2 means I’m at 80mph. So my flash is when I’m about 2.5 seconds back and closing. At that distance out it’s not “get out of my way”, which may well cause an aggressive response, it’s “Hi, I’m here you might want to pay a bit of attention to me”. Now from that point they then have 10 seconds or so to work out how fast I’m closing and if they can pull into lane 1 sensibly or not.
If at 1.5 seconds back from the car there’s no reaction, that’s not they’re in lane 1 but rather showing intention to move into lane 1, then they’re not going to move and I’ve got time to evaluate at my options. If the transition straight into an undertake doesn’t seem on I’ll hold at around 1.5 seconds back from the car waiting for my opportunity.
I get an 70-80% hit rate using this and an awful lot of thumbs up, nods or hand up from drivers as I pass. Why is that? Well because I gave them loads of time and never put them under pressure. Less than 1% of the time I can’t transition into an undertake, if this doesn’t work. If I can’t undertake I was the one that screwed up because I need the space they should have moved into to undertake them.
PostPosted: 14:38 - 28 May 2016    Post subject: Reply with quote
Heh, do your sums again. You're not 2.5 seconds away at 100m doing 80mph unless the vehicle you're following is parked.
DJP
PostPosted: 15:24 - 28 May 2016    Post subject: Reply with quote
This^^.
Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https
PostPosted: 20:03 - 28 May 2016    Post subject: Reply with quote
Why bother flashing? Just increases the chance of the other user being a dick as they usually interpret headlight flashes as aggression. I've also tried flicking on my right indicator like our friends do on the autobahn. None of these things work, so I just undertake and get on with my day. Life is too short.
Ichy
PostPosted: 20:41 - 28 May 2016    Post subject: Reply with quote
Totally agree. No faffing about, I just use the space available. I suspect that a good number of drivers never even realised I was there and I'm gone before it matters.
The last post was made 10 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 136.7 Kb
