Losing power when I pull throttle all the way
Matty MT
PostPosted: 18:04 - 29 May 2016    Post subject: Losing power when I pull throttle all the way Reply with quote
Hi can sombody help me pls, I know bits about bike but I am stuck, I have had my Yamaha mt125 2016 for 2 months, but from new I didn't spot it because I was tryin to run it in correctly, but on the odd accessions I didn't, I found if I ease the throttle all the way to top rpm every thing is fine. But if I ease the throttle up mid rpm range then pull the throttle all the way, the engine makes a dull pitched noise, and I lose power.. Then I let go of the throttle and pull it again, then I can feel the power, can anybody help please thanks
Matthew christian
PostPosted: 18:06 - 29 May 2016    Post subject: Reply with quote
Still under warranty? Take it back to the dealer.
Matty MT
PostPosted: 18:44 - 29 May 2016    Post subject: Reply with quote
It's goin in for its 600 miles service on Wednesday, hopefully they can fix it, it's jus I am too impatient lol, and if was an easy fix I would like to fix it myself, and I would like to know what the problem is so I could tell the mechanics in the dealership to get to the problem faster, and thank u for the fast reply
Matthew christian
PostPosted: 18:50 - 29 May 2016    Post subject: Reply with quote
It's their job and what you pay them for. Just give it back to them. If you dick around with it you run the risk of invalidating said warranty. Wink
MCN
PostPosted: 19:10 - 29 May 2016    Post subject: Reply with quote
I don't know what is fitted to that bike but....
AN issue for some 'modern' bikes is when the battery is disconnected the ECM 'can' lose the information for where the min-max is for the Throttle. The procedure is:
Ignition on.
Do not start the engine.
Throttle all the way open.
Return to zero.
Off Ignition.
Ignition on and start.
That's on Fly-by-wire systems your bike may have a more simple mechanical cable. Sad
If in doubt dealer-ise it.
Ichy
PostPosted: 20:06 - 29 May 2016    Post subject: Reply with quote
Best advice ever. Part of the premium you paid for a new bike was that it would do what it should.
Matty MT
PostPosted: 23:31 - 29 May 2016    Post subject: Reply with quote
Thanks for all the advice guys, like I sed its goin in for its 600 mile service in a few day so I will let them know, it's jus always in the back of my mind wanting to know what it is, I will keep used informed on the problem when I find out thanks guys
Matthew christian
The last post was made 10 years, 128 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 52.9 Kb
