2013 Wk sp125 clocks...
Dan12345
PostPosted: 13:36 - 12 May 2016    Post subject: 2013 Wk sp125 clocks... Reply with quote
Hi there
I have a WK Bikes Sp125 with a clock issue. It is a digital jobby with display showing speed, temperature and fuel level; then a needle for rpm. For some reason the speedo and odometer have pretty much stopped working, the fuel indicator is constantly flashing empty even with a full tank, yet the needle, temp, indicators and lights display are still working. Had the front wheel off this morning, cleaned and re greased the speedo drive yet the problem persists. Any ideas would be muchly appreciated!
Dan12345
PostPosted: 10:34 - 30 May 2016    Post subject: Reply with quote
Quick update, have now tried a brand new clock set, still got the same issues. Any ideas at all?
Snowdonia Rider
PostPosted: 15:35 - 30 May 2016    Post subject: Reply with quote
How old is it? Out of warranty I gather?
PostPosted: 16:04 - 30 May 2016    Post subject: Reply with quote
Sounds like:
A snapped speedo cable. The strands might still be catching a bit and giving you the odd reading.
A dodgy fuel sender.
For the former, I'd detach the cable at both ends and check if the inner is intact, then replace if necessary.
For the latter, I'd put some tape over the light.
Dan12345
PostPosted: 18:31 - 31 May 2016    Post subject: Reply with quote
Haha great stuff. Don't know much about bikes generally, but had the speedo drive off, took it apart, cleaned and re-greased the whole unit. Can't see a way to get the wire out of it at all, looks to be a sealed unit with a 3 point electrical connector that plugs into the wiring loom just below the clocks. Just wondered if there might be anything 'electrical' to look for as both speedo and fuel indicator bust at the same time. For now I will take the advice and stick some electrical tape over the flashing indicators Very Happy
The last post was made 10 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 43.15 Kb
