Bearings
Commuter_Tim
PostPosted: 19:15 - 31 May 2016    Post subject: Bearings Reply with quote
Is there a specific brand to go for with bearings?
Need to replace some shagged ones on a Bandit 600, Wemoto have these...
https://www.wemoto.com/bikes/suzuki/gsf_600_st_sv_sw_bandit_-_gn77a/95-98/picture/front_wheel_bearing_left/
https://www.wemoto.com/bikes/suzuki/gsf_600_st_sv_sw_bandit_-_gn77a/95-98/picture/sprocket_carrier_bearing/
Are they suitable long term or is it another pattern fork rubber situation?
Could anybody possibly recommend a good Ebay alternate?
I ride a Bandit 600... badly.
CaNsA
PostPosted: 19:22 - 31 May 2016    Post subject: Reply with quote
They'll be fine.
PostPosted: 19:46 - 31 May 2016    Post subject: Reply with quote
If you're going for cheap bearings - find the code on them and order by that. Often get them significantly cheaper.
Meatybeaty
PostPosted: 20:14 - 31 May 2016    Post subject: Reply with quote
Just run your mouse over the yellow info sign to the right of the price, that will give you the bearing size, front wheel bearing 17x40x12 and sprocket carrier bearing 25x62x17 , google those sizes and find the price and supplier you want . I generally use these. Thumbs Up
https://simplybearings.co.uk/shop/
Commuter_Tim
PostPosted: 20:24 - 01 Jun 2016    Post subject: Reply with quote
Cheers fellas, I'm not necessarily wanting to prioritise cheapness but think I will go for the Wemoto ones.
I had no clue how bearings were measured or gauged before so cheers for that though. Thumbs Up
haroman666
PostPosted: 20:59 - 01 Jun 2016    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?p=4254658
This has some useful things in it.
Commuter_Tim
PostPosted: 21:02 - 01 Jun 2016    Post subject: Reply with quote
haroman666 wrote:
I did vaguely remember that thread but my main stumbling block before was I had no idea how to measure them or if specific bikes had a special design, if I've learned anything it's that bike manufacturers don't like to make things easy for us. Smile
It seems I was being overly cautious.
PostPosted: 21:21 - 01 Jun 2016    Post subject: Reply with quote
If I was looking for good ones, sorry, I'd still take the same route - wemoto quite possibly are pretty cheap ones.
I'd get the code and make sure I was getting decent brand bearings, what ever that may mean Smile.
Commuter_Tim
PostPosted: 21:31 - 01 Jun 2016    Post subject: Reply with quote
You're probably right, admittedly in life most of my decisions are based around laziness, and Wemoto do a rear bearing and seal set.
I should know better since the chain riveter they sold me which bent before it riveted one pin.
FAGs are supposedly reliable right? (hur hur)
They seemed cheap as chips in the link above, and who doesn't like a cheap fag? Wub
smallfrowne
PostPosted: 23:50 - 01 Jun 2016    Post subject: Reply with quote
SKF Explorers Cool
'90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90
smegballs
PostPosted: 00:57 - 02 Jun 2016    Post subject: Reply with quote
FAG, SKF, Koyo etc etc are all fine.
If they are german, jap or scandi then I'd use them without worrying. I used SKF last time I changed the fronts.
Get the 2RS ones as that is double rubber shielded to help protect against water ingress.
temeluchus
PostPosted: 01:14 - 02 Jun 2016    Post subject: Reply with quote
fronts are 6302 2RS and rear are 6304 2RS
sprocket carrier is 6205 2RS
Major Doss
PostPosted: 05:38 - 02 Jun 2016    Post subject: Reply with quote
Wemoto are not your fist point of call.
Temeluchus has pointed you to the way of righteousness. Shop around, bearing in mind some bearing factors will try to factor you in the Ahole, if you let on it's for a motorcycle.
The last post was made 10 years, 111 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 75.08 Kb
