Hole in Downpipe - Advice
Googley
PostPosted: 16:05 - 01 Jun 2016    Post subject: Hole in Downpipe - Advice Reply with quote
Hi guys. Bike has been sounding strange recently, had a look around and have found a little hole in the downpipes. I'm planning selling the bike in the next couple of weeks, what would you do? Get it welded? Exhaust putty? Any advice would be greatly appreciated.
CaNsA
PostPosted: 16:07 - 01 Jun 2016    Post subject: Reply with quote
Type of bike?
Make, model and year.
Y'know because we're not mind readers or anything like that.
Googley
PostPosted: 16:10 - 01 Jun 2016    Post subject: Reply with quote
CaNsA wrote:
Type of bike?
Sorry mate, didn't know that would influence the decision. But it's a 2010 Street triple R.
PostPosted: 16:21 - 01 Jun 2016    Post subject: Reply with quote
Weld or replace.
If the bike is generally a shit heap then some exhaust putty won't be out of place and won't devalue it further.
c_dug
PostPosted: 16:52 - 01 Jun 2016    Post subject: Reply with quote
Depends if you're the honest seller type, and on how bad the hole actually is.
Personally, I'd be tempted to sell as is if we're talking less than a 2mm hole. I'd be honest about it in the advert too.
Googley
PostPosted: 16:57 - 01 Jun 2016    Post subject: Reply with quote
I think I will get it welded. Trying to upload a picture but phone won't allow me for some reason. I'm by no means dishonest, just not motor mechanical minded. The putty said permanent repair so thought I would get some advice. The hole is probably about 2mm but I'm sure I can get it welded easily.
jaffa90
PostPosted: 22:39 - 01 Jun 2016    Post subject: Reply with quote
What has caused the hole?
NJD
PostPosted: 22:42 - 01 Jun 2016    Post subject: Reply with quote
It's not the drain hole, is it?
Googley
PostPosted: 22:43 - 01 Jun 2016    Post subject: Reply with quote
I honestly don't know. It's right next to the weld but not the weld itself. I would upload a picture but the only have my phone and keeps saying the image is too big. I think i could get it patched up. Very small but the sound difference is crazy. Want to get it MOT before I sell it too so has a full year for the buyer.
PostPosted: 07:37 - 02 Jun 2016    Post subject: Reply with quote
All exhaust repairs are temporary. They generally corrode from the inside out and once a hole appears it's usually joined by others. You may find there's not much left to weld.
By which we mean, is this right underneath the exhaust at the lowest point? Pictures would really help.
c_dug
PostPosted: 08:17 - 02 Jun 2016    Post subject: Reply with quote
If it sounds different now than before then it isn't the drain hole.
ssray
PostPosted: 08:22 - 02 Jun 2016    Post subject: Reply with quote
COMMON PROBLEM, WELD OR REPLACE
PostPosted: 08:53 - 02 Jun 2016    Post subject: Reply with quote
Maybe, the mind can play tricks on you once you've "noticed" an issue.
Pics still needed.
lingeringstin...
PostPosted: 11:04 - 02 Jun 2016    Post subject: holy moly Reply with quote
Put a screw in it. I've done that lots of times to pinholes in downpipes. Just find a self tapping screw the right size and bung it in the hole.
Of course most people would say never do this or it will make your babies be born naked and cause you to careen down the motorway in a fireball crashing into a busload of nuns and orphans, but ignore them. A screw in the downpipe is a decent and cheap temporary (years in some cases) fix and I have never had any issue with it at an MOT.
skatefreak
PostPosted: 11:06 - 02 Jun 2016    Post subject: Reply with quote
Few months ago, after having left my cbr600 laid up for 6 months,
got it back on the road and it promptly blew a hole where the two 2-1 reducers join to the final 2-1.
Jabbed it lightly with a screwdriver and the hole started to grow ...
Not a big problem, still only talking 1-1.5cm or so...
Whipped the headers off and popped round my welding buddies workshop.
"That section will need a full wrap" he said...
After fannying around a bit to entertain me, it needed a full wrap round the whole section...
This was done by a friend as a favor, cost me nothing and did the job well however illustrates how a little hole can be a sign of far worse corrosion Shocked
The problem is gone... for now Evil or Very Mad
https://cdn.bcf.44bytes.net/files/img_2051.jpg
https://cdn.bcf.44bytes.net/files/img_2074_128.jpg
Googley
PostPosted: 11:54 - 02 Jun 2016    Post subject: Reply with quote
I'll try and take a lower resolution photo when I get back from work as my photos are too large of an attachment by the looks of things. If you Google Street triple Downpipe though you will see it is 3 into 1. On the 3 pipes they are joined by horizontal pipe, it's next to the weld on one of the horizontal, about 2mm max. I'll try and get a picture up aroind 5pm.
Googley
PostPosted: 12:01 - 02 Jun 2016    Post subject: Reply with quote
Managed to download an app to resize the picture. Hope it's OK.
PostPosted: 12:09 - 02 Jun 2016    Post subject: Reply with quote
I've give a breakers a call see how much another set is, There should be loads about. There are a few Triumph specialist breakers out there. Thumbs Up
sinedtomuch This post is not being displayed because the poster is banned. Unhide this post / all posts.
Googley
PostPosted: 12:33 - 02 Jun 2016    Post subject: Reply with quote
sinedtomuch wrote:
Looks a lot bigger than 2mm.
I didn't measure it, was just a guesstimation. Just want to know if it could be welded or needed to be replaced really...
Pjay
PostPosted: 12:39 - 02 Jun 2016    Post subject: Reply with quote
Sorted!
https://www.gbsalpine.com/image/collection_part/header_wrap/h_wrap_img.jpg
P.S. Dont buy a bike from me.
PostPosted: 12:41 - 02 Jun 2016    Post subject: Reply with quote
its really close to the original weld, you can't be sure its not damaged that. I'd probably replace it if it were me but take it to your local welding place and ask the question.
Make sure they disconnect the battery before welding anything.
The last post was made 10 years, 114 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 120.49 Kb
