| sausagepartyb... |
 sausagepartyb... Derestricted Danger
| Kickstart |
 Kickstart The Oracle
| Nobby the Bastard |
| sausagepartyb... |
| davebike |
 davebike World Chat Champion
 Posted: 08:13 - 03 Jun 2016 Post subject: |
ZX6R 6 pot callipers HA ha BTDTGTS
tie the front brake leaver in over night it should sort it
If not you not got the pistons clean enough or not used red brake grease or silicone grease on the seals
Silicone is much better
Ignore Haynes joke book don't use brake fluid as a lubricant it is not ! ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| Kickstart |
 Posted: 23:58 - 03 Jun 2016 Post subject: |
The 6 pot calipers are renowned for seizing up and being a nightmare to bleed. Worth stripping them fully and clean out behind the seals thoroughly.
Clutch wise, think it is a cable clutch, but not sure what adjustment there is. Ie, is there an adjuster other than the one for the cable. Also check whether there are any different thickness clutch plates and if there are whether you put them back in the right order.
Katy ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
The last post was made 10 years, 127 days ago. Instead of replying here, would creating a new thread be more useful? |
