What am I looking for? A can of gas.
Gazz
PostPosted: 20:50 - 03 Jun 2016    Post subject: What am I looking for? A can of gas. Reply with quote
What's the brand name of the gas used for heating localised areas to remove hard to remove bolts?
I seen someone use what looked like a deoderant can the other day to remove exhaust studs but I assume that there is a can of something out there with the correct type of nozzle on it for doing this type of work.
Brendan110_0
PostPosted: 20:55 - 03 Jun 2016    Post subject: Reply with quote
B&Q - gas blow torch - buy torch piece then cans of gas to screw on.
sreeB fo gniK
Raffles
PostPosted: 21:15 - 03 Jun 2016    Post subject: Re: What am I looking for? A can of gas. Reply with quote
Are you sure that heat was being applied?
Could it have been this stuff:-
https://manxmotortrader.com/shop/wp-content/uploads/2013/03/freeze.png
Gazz
PostPosted: 22:11 - 05 Jun 2016    Post subject: Reply with quote
He used a lighter to get it started so was heat.
However, what would be better for getting a nut off?
Cold treating or heat treating?
PostPosted: 22:30 - 05 Jun 2016    Post subject: Reply with quote
Freeze and release works, but a blowtorch works too.
Personally I'd probably go freeze and release or a penetrant such as plusgas first, before I applied a blowtorch to a bike full of fuel and other flammable liquids.
The Artist
PostPosted: 22:37 - 05 Jun 2016    Post subject: Re: What am I looking for? A can of gas. Reply with quote
Don't know about a brand name but it could be propane/butane/acetylene or some combination of those. All make stuff hot. You can pick up a cheap blow torch from B&Q which will do the job.
anthony_r6
PostPosted: 23:37 - 05 Jun 2016    Post subject: Reply with quote
I second Plusgas - helped me remove a particularly difficult sprocket nut.
Pjay
PostPosted: 23:40 - 05 Jun 2016    Post subject: Reply with quote
Heating expands and freezing contracts, so both can work.
I think that heating and then freezing fast can also work wonders, but you have to be careful that you only warm up before freezing, so as not to temper the metals.
DrDonnyBrago
PostPosted: 10:04 - 06 Jun 2016    Post subject: Reply with quote
Probably means plusgas, it's a penetrating oil.
smallfrowne
PostPosted: 12:46 - 06 Jun 2016    Post subject: Reply with quote
Maybe it was a can of lynx Africa, or PlusGas used in the style of James Bond
https://i.imgur.com/MmAfJX0m.png
Or maybe it was a bit like this?
https://i.imgur.com/ClLQx3Am.jpg
https://www.toolstation.com/shop/Hand+Tools/d10/Soldering+Torches+%26+Accessories/sd3158/Auto+Blowlamp+with+Gas+Cartridge/p78079
I'd go for something like this though:
https://i.imgur.com/OWdkFgym.jpg
https://www.toolstation.com/shop/Hand+Tools/d10/Soldering+Torches+%26+Accessories/sd3158/Vortex+MAP+Torch+Pack+/p71324
The torches that fit to "butane/propane mix" bottles (campingaz) do not fit to the propane or MAP bottles (which are the more professional plumber type job) and vice versa. You'll probably get more fire out of the latter, definitely with the MAP bottles.
...edited for more james bond
'90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90
The last post was made 10 years, 100 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 65.02 Kb
