Roundabout, control, indicating & trying not to get squa
Andy Rider
PostPosted: 07:39 - 07 Jun 2016    Post subject: Roundabout, control, indicating & trying not to get squa Reply with quote
So I've been struggling with roundabout confidence and living in Milton Keynes I get a lot of practice (chances to scare the hell out of myself)!
I googled it and found a post that said keep the rev's up and use the clutch/ back brake for speed control. Been trying that and it does seem to help as I'm less jolty not using the throttle. But I have little girly hands! and find it hard to use the clutch and the indicator switch at the same time, especially while keeping an eye on all the cars etc around me trying to squash me...
So any top tips, please?
davebike
PostPosted: 07:53 - 07 Jun 2016    Post subject: Reply with quote
Leave the clutch out of it unless you coming to a Stop
engine revving in the middle of its range
try to keep it smooth
Use your indicators !
Dave
NC750Xdct + others at work !
davebike1@gmail.com
DrSnoosnoo
PostPosted: 07:57 - 07 Jun 2016    Post subject: Reply with quote
Do you have a licence? If so, you should have sorted the clutch and brake control out to be second nature? If not; you need to get out to a quiet place and practice those techniques before you start needing to concentrate on hazards
RedPanda
PostPosted: 08:01 - 07 Jun 2016    Post subject: Reply with quote
What gear are you using? If you're always in first then it'll be more jolt-y.
CBF125 (2013) -> CBR600F (2001) -> 'Ninja' 300 (2014)
PostPosted: 09:13 - 07 Jun 2016    Post subject: Reply with quote
Point of order, given the propensity for folk to approach roundabouts at at warp speed and the possibility that you're behind their A pillar, or are perceived as only a bloody bike, I do like to at least cover the clutch.
But yes, a little rear brake is useful for control. You can apply a surprising amount of throttle and rear together even while leaned over.
I'd agree with practising somewhere off the beaten track for a bit.
And I have to give a little shout out to (proper) BMW pushy-button indicators, which make a lot of sense on roundabouts.
rubyhorse2
PostPosted: 09:15 - 07 Jun 2016    Post subject: Reply with quote
it still amazes how many people have no clue how to use roundabouts (not aimed at OP, just general road users).
My main biking advice is to dominate the road, make car drivers and other road users know your there and arent taking any shit.
See so many people ride too defensively and poorly positioned, this just makes car drivers more likely to use space they shouldnt be using.
For roundabouts, just keep observant and in control, know your exits and plan your entry and exit so you can be as smooth as possible, including any lane changes and signals. But as above, dont be pushed around, be confident and smooth.
UncleFester
PostPosted: 09:16 - 07 Jun 2016    Post subject: Reply with quote
You have to have ridden / driven in MK to understand how people there approach roundabouts and it's never with care and almost always in the wrong lane with no or incorrect signalling.
Get your observations ( shoulder and mirror checks) sorted, approach with care but not too much caution and get all your braking done / gears / signalling on before you get to the 'line'.
You can cancel the signal after you've dealt with the roundabout.
Smooth is key.
2017 Z1000SX
Matt B
PostPosted: 09:29 - 07 Jun 2016    Post subject: Re: Roundabout, control, indicating & trying not to get Reply with quote
Maybe that for tight little mini roundabouts.
However, most of our roundabouts here in the Magical Land of Milton Keynes are massive, two lane, in the middle of a NSL dual carriageway monsters. Unless I'm coming to a complete stop I tend to do them in 2nd or even 3rd gear depending on speed/visibility.
The biggest issue is the fact that most mongtards, bored with another roundabout, don't bother to indicate. Coupled with an inability to get in the correct lane that makes it difficult. As said, keep it smooth and make sure you indicate yourself. Lifesavers are important around here too. With more time on the bike you will gain confidence.
DrSnoosnoo
PostPosted: 09:36 - 07 Jun 2016    Post subject: Reply with quote
My most recent observation of poor roundabout use;
Last night
NSL road
2 lane entry on to the roundabout for us
5 exits, including coming right around and returning on ourselves.
(Surprisingly) A Volvo estate thing thought that using the roundabout at approx. 10 mph in the inside lane, with no indication, was the best way to arrive at the 4th exit.
PostPosted: 10:18 - 07 Jun 2016    Post subject: Reply with quote
And when you're hidden behind a foot thick A pillar?
I'd rather take avoiding action (and have had to) than be confidently collected on someone's bonnet.
rubyhorse2
PostPosted: 10:31 - 07 Jun 2016    Post subject: Reply with quote
true, but i have seen bikers being utterly molested on roads, being edged into the kerb simply because they ride like frightened little rabbits and most car drivers will simply see more of a space and think they can use it.
shdaxner
PostPosted: 11:29 - 07 Jun 2016    Post subject: Reply with quote
Surely whether you have only done your CBT or whether you have your full licence the whole slipping the clutch whilst using your back brake to control the speed thing should be common practice as it is necessary to have to do this on both CBT and Mod 1.
Could it be possible that you are depressing the clutch too early (under confident driver seem to do this alot going round corners and such) and having to release it alot causing the rough ride?
Bikes - 65' Keeway RKV 125 (sold), 55' Kawasaki ZX6R C1H
Andy Rider
PostPosted: 14:02 - 07 Jun 2016    Post subject: Reply with quote
Smile Yes I do thanks. But it seemed very easy to come by, I took getting it as them deciding I was safe enough to start learning on my own not that I now suddenly knew everything I'd ever need to know about riding
I try to stay in 2nd, assuming I don't have to come to a complete stop in which case I'd be in 1st. I have learnt from bad riding to change up to 2nd as soon as I'm moving, previsouly I had been changing up gear, doing lifesavers and indicating off the roundabout all around the same time. That never made me feel safe and in control though Shocked
I can assure you it is very easy to pass a CBT, mod 1 and mod 2 without mastering clutch slipping and brake use at the same time Very Happy
My issue with roundabouts isn't the approach or confidence over positioning (I don't think), I cycle a lot so I'm pretty comfortable sticking myself in the middle of the road on a roundabout so people can see me and not try to squeeze me out, I think it's more that multi-tasking moment, where you are starting to indicate off the roundabout while at the same time looking over your shoulder to check no one has tried to sneak up the righthand side, worrying about the idiots approaching the roundabout on your left and steer/ leaning the bike around the bend all pretty much at the same time.
Although having just been out on some quiet roads for a little lunch time ride, I have decided my main issue is leaning, I need get more confidence on leaning the bike over
DrSnoosnoo
PostPosted: 14:09 - 07 Jun 2016    Post subject: Reply with quote
Probably one of those mind over matter things. You're possibly overthinking it.
*insert Tef* Less finking, moar doeing! *Tef left*
PostPosted: 14:22 - 07 Jun 2016    Post subject: Reply with quote
Probably, it takes me a good while to switch from 'Winter' (September to May) mode into 'Summer' riding. Wink
Andy Rider
PostPosted: 14:26 - 07 Jun 2016    Post subject: Reply with quote
Coming into my first summer, until the last couple of times on the bike every time I've used it, it's been cold wet and miserable. So if it take a while for you seasoned riders to get your lean on, I surely can be forgiven for taking a little longer Wink
B5234FT
PostPosted: 14:52 - 07 Jun 2016    Post subject: Reply with quote
It's one of the things I've found most difficult about going from cars to bikes, trusting the tyres and knowing how much margin you have, when the consequences of finding the limit are so much greater.
Normal large roundabouts you can countersteer round are fine, and slow speed stuff in carparks and so on is fine, but mini roundabouts are the devil because everything happens so close together and its too slow and yet not slow enough.
UncleFester
PostPosted: 16:06 - 07 Jun 2016    Post subject: Reply with quote
The issue with MK is often diesel or debris out of your line of sight on a large roundabout so there's a good line ( Ha ) between going too slow and getting in the way and going too fast that you can't avoid issues.
Realistically you should know where your indicator switch is, when you don't have to look for it, it's much easier and that comes with practice.
Good observation prior to the roundabout means you can be smoother as you're already preparing for the turn.
Speed / progress come after smoothness and that only comes with practice.
If you want to practice on quieter roundabouts, go off over to Tattenhoe / Westcroft on an evening about 7pm or later. Lots of roundabouts, won't be maniac busy.
If you're an early bird ... the A422 gives you a good run of dual carriage way and open roundabouts with good road surface to practice on too.
2017 Z1000SX
PostPosted: 16:29 - 07 Jun 2016    Post subject: Re: Roundabout, control, indicating & trying not to get Reply with quote
High revs, slipping clutch and use the brake all at the same time? Not necessary, or even good advice!
Use the clutch for stopping, pulling away and changing gear. Otherwise, leave it engaged unless you're doing VERY slow manoeuvrers.
If you've used your brake on the way round you started off too fast - go back again and reduce your entry speed. Accelerate only as you straighten for the exit, this will stand the bike up and send you towards the exit naturally.
As for leaning - next time you tackle a roundabout, as you turn in to it bend your arms and lean forward a bit and a little towards the right bar. Everything will feel a lot more natural and it'll stop you doing 50-pences around it.
PostPosted: 16:39 - 07 Jun 2016    Post subject: Reply with quote
This seems to be your biggest problem. There is NO good reason to look over your right shoulder when on a roundabout unless you want to change lanes to the right which means you set yourself up in the wrong lane anyway. Stop doing it - you're going to get yourself killed.
Val
PostPosted: 09:15 - 08 Jun 2016    Post subject: Reply with quote
Forget about leaning per se. The bike will lean when you do it right. Focus on the line where you want to go and the bike will lean.
On a roundabout hug the curb in the center. I mean try to follow the curb positioning the bike imaginery line that you try to follow say 1 foot from the curb. Try to keep exact 1 foot distance of your front tire from the curb all the time, but also try not to look directly at the curb when doing that.
Keep constant speed at say 2nd gear. In order to keep the speed constant that means you need to add little throttle, because whenthe bike leans and starts turning it will slow down itself so you need to compensate a little.
When you have the bike turning line circle sorted, and going fine like a on a rails, you'll find out you have plenty of time to look around. If you hug the curb there will be no need to look right so focus mostly on your left side. Sometimes you need to speed up or slow down depending on what is coming there. Problem sorted.
Andy Rider
PostPosted: 10:13 - 08 Jun 2016    Post subject: Reply with quote
See attached photo. This is a typical roundabout.
I'm red sticking to my lane going straight on but you will potentially have other vehicles using the roundabout in a blue or even yellow fashion hence my right shoulder check to make sure no one is yellowing up my ass. But you also have to worry about those green folk who are still half a sleep and not seen you! There's just danger coming from everywhere.
B5234FT
PostPosted: 10:30 - 08 Jun 2016    Post subject: Reply with quote
If you're anything like me, you're looking around far too much.
My instructor pointed out that your left lifesaver for the green folk needs to be early enough that you can actually do something about it, and therefore theres no point looking further around than just left of your mirror. I also got scolded for checking again, as it as too late to be useful and distracting when I should have been looking at other things.
Provided you're staying in your lane, the blue folks arent a concern (unless they change their mind and become yellows), nor are yellows who are keeping to their lane, so the remaining risk is a yellow exiting into your lane, which will occur after the greens in which case yeah, I'd be checking to the right too, but again, a glance at 45 degrees, not craning my neck right round.
Theres a lot you can do in terms of thinking where you are against the adjacent lane, if you're defensively in your lane, and keeping pace with the inside lane such that youre not sitting in someones blind spot you're less likely to be missed in a last minute "shit I need to go straight on" manouevre.
That said, I'm still green and if anyone more experienced disagrees with the above I'd be keen to hear about it!
Matt B
PostPosted: 10:34 - 08 Jun 2016    Post subject: Reply with quote
I always do a quick look on the left shoulder to check the green line. That's the only one you really need to worry about. They tend to start creeping out at you or just don't bother stopping because they hit a roundabout at 70 and didn't slow enough. If the yellow line is beside me at the exit then they won't be for long, just accelerate away.
Get set up before the roundabout, get your observations done and check what is near or on it and what will be there when you are. Check the right mirror on approach to see what will be going round with you on that yellow line (normally a chav in a Civic Type aRse). Then just smooth and steady, quick left shoulder check, left indicator, exit, disappear.
If it's clear I will straightline or straighten out every roundabout I cross in MK.
PostPosted: 10:37 - 08 Jun 2016    Post subject: Reply with quote
So you come here looking for advice because you can't negotiate a roundabout but it's everyone else who is half asleep or an idiot that's the problem.
Here's a tip - stop watching youtube vlogs and get some miles under your belt. You're cramming your own head with nonsense.
The last post was made 9 years, 240 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 138.92 Kb
