| Andy Rider |
 Andy Rider Two Stroke Sniffer
| davebike |
 davebike World Chat Champion
 Posted: 07:53 - 07 Jun 2016 Post subject: |
Leave the clutch out of it unless you coming to a Stop
engine revving in the middle of its range
try to keep it smooth
Use your indicators ! ____________________ Dave
NC750Xdct + others at work !
davebike1@gmail.com |
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
| RedPanda |
 RedPanda Could Be A Chat Bot
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:13 - 07 Jun 2016 Post subject: |
| davebike wrote: | Leave the clutch out of it unless you coming to a Stop |
Point of order, given the propensity for folk to approach roundabouts at at warp speed and the possibility that you're behind their A pillar, or are perceived as only a bloody bike, I do like to at least cover the clutch.
But yes, a little rear brake is useful for control. You can apply a surprising amount of throttle and rear together even while leaned over.
I'd agree with practising somewhere off the beaten track for a bit.
And I have to give a little shout out to (proper) BMW pushy-button indicators, which make a lot of sense on roundabouts. ____________________ Biking is 1/20th as dangerous as horse riding.
| rubyhorse2 |
 rubyhorse2 Traffic Copper
| UncleFester |
 UncleFester World Chat Champion
| Matt B |
 Matt B World Chat Champion
| DrSnoosnoo |
| Rogerborg |
 Rogerborg nimbA
| rubyhorse2 |
| shdaxner |
 shdaxner Borekit Bruiser
| Andy Rider |
 Posted: 14:02 - 07 Jun 2016 Post subject: |
| DrSnoosnoo wrote: | Do you have a licence? |
Yes I do thanks. But it seemed very easy to come by, I took getting it as them deciding I was safe enough to start learning on my own not that I now suddenly knew everything I'd ever need to know about riding
| RedPanda wrote: | What gear are you using? If you're always in first then it'll be more jolt-y. |
I try to stay in 2nd, assuming I don't have to come to a complete stop in which case I'd be in 1st. I have learnt from bad riding to change up to 2nd as soon as I'm moving, previsouly I had been changing up gear, doing lifesavers and indicating off the roundabout all around the same time. That never made me feel safe and in control though
| shdaxner wrote: | Surely whether you have only done your CBT or whether you have your full licence the whole slipping the clutch whilst using your back brake to control the speed thing should be common practice as it is necessary to have to do this on both CBT and Mod 1. |
I can assure you it is very easy to pass a CBT, mod 1 and mod 2 without mastering clutch slipping and brake use at the same time
My issue with roundabouts isn't the approach or confidence over positioning (I don't think), I cycle a lot so I'm pretty comfortable sticking myself in the middle of the road on a roundabout so people can see me and not try to squeeze me out, I think it's more that multi-tasking moment, where you are starting to indicate off the roundabout while at the same time looking over your shoulder to check no one has tried to sneak up the righthand side, worrying about the idiots approaching the roundabout on your left and steer/ leaning the bike around the bend all pretty much at the same time.
Although having just been out on some quiet roads for a little lunch time ride, I have decided my main issue is leaning, I need get more confidence on leaning the bike over |
| DrSnoosnoo |
| Rogerborg |
 Rogerborg nimbA
| Andy Rider |
| B5234FT |
 B5234FT Brolly Dolly
| UncleFester |
| Pete. |
 Pete. Super Spammer
 Posted: 16:29 - 07 Jun 2016 Post subject: Re: Roundabout, control, indicating & trying not to get |
| Andy Rider wrote: | I googled it and found a post that said keep the rev's up and use the clutch/ back brake for speed control. |
High revs, slipping clutch and use the brake all at the same time? Not necessary, or even good advice!
Use the clutch for stopping, pulling away and changing gear. Otherwise, leave it engaged unless you're doing VERY slow manoeuvrers.
If you've used your brake on the way round you started off too fast - go back again and reduce your entry speed. Accelerate only as you straighten for the exit, this will stand the bike up and send you towards the exit naturally.
As for leaning - next time you tackle a roundabout, as you turn in to it bend your arms and lean forward a bit and a little towards the right bar. Everything will feel a lot more natural and it'll stop you doing 50-pences around it. ____________________ a.k.a 'Geri'
| Pete. |
 Pete. Super Spammer
| Val |
 Val World Chat Champion
 Posted: 09:15 - 08 Jun 2016 Post subject: |
| Andy Rider wrote: | Although having just been out on some quiet roads for a little lunch time ride, I have decided my main issue is leaning, I need get more confidence on leaning the bike over |
Forget about leaning per se. The bike will lean when you do it right. Focus on the line where you want to go and the bike will lean.
On a roundabout hug the curb in the center. I mean try to follow the curb positioning the bike imaginery line that you try to follow say 1 foot from the curb. Try to keep exact 1 foot distance of your front tire from the curb all the time, but also try not to look directly at the curb when doing that.
Keep constant speed at say 2nd gear. In order to keep the speed constant that means you need to add little throttle, because whenthe bike leans and starts turning it will slow down itself so you need to compensate a little.
When you have the bike turning line circle sorted, and going fine like a on a rails, you'll find out you have plenty of time to look around. If you hug the curb there will be no need to look right so focus mostly on your left side. Sometimes you need to speed up or slow down depending on what is coming there. Problem sorted. ____________________ Adrian Monk: Unless I'm wrong, which, you know, I'm not...
Yamaha Fazer FZS 600, MT09, XSR 900 |
| Andy Rider |
| B5234FT |
 Posted: 10:30 - 08 Jun 2016 Post subject: |
If you're anything like me, you're looking around far too much.
My instructor pointed out that your left lifesaver for the green folk needs to be early enough that you can actually do something about it, and therefore theres no point looking further around than just left of your mirror. I also got scolded for checking again, as it as too late to be useful and distracting when I should have been looking at other things.
Provided you're staying in your lane, the blue folks arent a concern (unless they change their mind and become yellows), nor are yellows who are keeping to their lane, so the remaining risk is a yellow exiting into your lane, which will occur after the greens in which case yeah, I'd be checking to the right too, but again, a glance at 45 degrees, not craning my neck right round.
Theres a lot you can do in terms of thinking where you are against the adjacent lane, if you're defensively in your lane, and keeping pace with the inside lane such that youre not sitting in someones blind spot you're less likely to be missed in a last minute "shit I need to go straight on" manouevre.
That said, I'm still green and if anyone more experienced disagrees with the above I'd be keen to hear about it! |
| Matt B |
| Pete. |
 Pete. Super Spammer
The last post was made 9 years, 245 days ago. Instead of replying here, would creating a new thread be more useful? |
