My bike won't rev up at all!
ryanwilson190...
PostPosted: 16:45 - 07 Jun 2016    Post subject: My bike won't rev up at all! Reply with quote
Hi guys, I have a 2002 Honda CG 125, and it won't rev at all. The bike starts and idle's no problem and it doesn't cut out when you try to give it throttle. It has a brand new throttle cable and a brand new needle assembly, everything works as it should, the throttle moves the slide up and down, the fuel is getting through.
If you have any ideas then I would be greatful! Thanks!
RhynoCZ
PostPosted: 17:20 - 07 Jun 2016    Post subject: Reply with quote
Water in fuel, too lean mixture (no air filter fitted?), or too rich mixture (clogged air filter, stuck choke?).
ryanwilson190...
PostPosted: 17:25 - 07 Jun 2016    Post subject: Reply with quote
[quote="RhynoCZ"]Water in fuel, too lean mixture (no air filter fitted?), or too rich mixture (clogged air filter, stuck choke?).[/quote]
Thank you, I do have quite a bit of water in my fuel. The guy I brought it off as new fuel cap put in the left if you come off during the winter so I'd presume that quite a bit of water maybe in there. Will have a look thanks!
RhynoCZ
PostPosted: 17:28 - 07 Jun 2016    Post subject: Reply with quote
Drain the carburetor and tank, let the tank to dry out. You're might gonna have to take the carburetor bowl off, to clean any crud and white residue. Water reacts with the aditives in modern petrol and creates slime that clogs the jet/s. Thumbs Up
PostPosted: 17:49 - 07 Jun 2016    Post subject: Re: My bike won't rev up at all! Reply with quote
At all? No change in revs whatsoever?
What does it do?
Why?
How fast is it idling?
ryanwilson190...
PostPosted: 18:00 - 07 Jun 2016    Post subject: Re: My bike won't rev up at all! Reply with quote
[quote="Rogerborg"][quote="ryanwilson1905"]it won't rev at all.[/quote]
At [i]all[/i]? No change in revs whatsoever?
[quote="ryanwilson1905"]it doesn't cut out when you try to give it throttle.[/quote]
What does it do?
[quote="ryanwilson1905"]It has a brand new throttle cable and a brand new needle assembly[/quote]
Why?
How fast is it idling?[/quote]
No not at all! -- exactly that nothing -- and new cable because the old one was snapped and the guy I bought it off wedged the top of the carb in and bent the needle -- and it is idling at about 2500 - 3000 rpm but I can't change it without a throttle
ryanwilson190...
PostPosted: 19:01 - 07 Jun 2016    Post subject: Reply with quote
[quote="RhynoCZ"]Drain the carburetor and tank, let the tank to dry out. You're might gonna have to take the carburetor bowl off, to clean any crud and white residue. Water reacts with the aditives in modern petrol and creates slime that clogs the jet/s. Thumbs Up[/quote]
Thanks mate will do!
Commuter_Tim
PostPosted: 20:00 - 07 Jun 2016    Post subject: Re: My bike won't rev up at all! Reply with quote
...Completely fucking buggered main fuel jet then maybe? (the needle sits in the jet, if some twat bashed the needle in, I can't see the jet surviving) Thinking
I would be thinking new carb at this point, they're cheap as chips and who knows what the previous owners (twats) have done to it other than the visible.
I ride a Bandit 600... badly.
Teflon-Mike
tl;dr
PostPosted: 20:28 - 07 Jun 2016    Post subject: Re: My bike won't rev up at all! Reply with quote
That is a rather fast idle.... and you should change it without the twist-grip.
There is a screw on the side that adjusts the height that the throttle slide 'stops'... you wind that 'out' and the slide should drop to get the idle speed down to between 800 & 1000rom at tick-over.
But to start with this simple/stupid first... the choke is 'off', isn't it?
Most motors wont rev-up with the choke 'on'.. and it makes them idle high..... not that high, usually, but higher than 800-1000rpm.
Islander
PostPosted: 20:36 - 07 Jun 2016    Post subject: Reply with quote
Is the slide dropping right down and seating properly with the throttle closed?
techathy
PostPosted: 20:51 - 07 Jun 2016    Post subject: Re: My bike won't rev up at all! Reply with quote
I thought carbed bike engines generally stalled if the choke was on and you tried to rev them...
Commuter_Tim
PostPosted: 21:06 - 07 Jun 2016    Post subject: Re: My bike won't rev up at all! Reply with quote
I thought Haynes CG idle was 1100rpm? Neither here nor there though I guess if hes running at 3k. Very Happy
To be fair though, my CG idle never changed from half choke until stalling, and wouldn't idle at all on full choke.
ryanwilson190...
PostPosted: 22:04 - 07 Jun 2016    Post subject: Re: My bike won't rev up at all! Reply with quote
[quote="Commuter_Tim"][quote="ryanwilson1905"]
No not at all! -- exactly that nothing -- and new cable because the old one was snapped and the guy I bought it off wedged the top of the carb in and [i][b]bent the needle[/b][/i] -- and it is idling at about 2500 - 3000 rpm but I can't change it without a throttle[/quote]
I would be thinking new carb at this point, they're cheap as chips and who knows what the previous owners (twats) have done to it other than the visible.[/quote]
Alright thanks mate was looking at getting another carb soon anyway so hopefully that's the problem
ryanwilson190...
PostPosted: 22:06 - 07 Jun 2016    Post subject: Re: My bike won't rev up at all! Reply with quote
[quote="Teflon-Mike"][quote="ryanwilson1905"] and it is idling at about 2500 - 3000 rpm but I can't change it without a throttle[/quote]
Most motors wont rev-up with the choke 'on'.. and it makes them idle high..... not that high, usually, but higher than 800-1000rpm.[/quote]
In answer to your question yes the come is off, and thank you well sort that out! Thumbs Up
The last post was made 10 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 84.06 Kb
