L.E.Ds
Draco87
PostPosted: 19:41 - 09 Jun 2016    Post subject: L.E.Ds Reply with quote
Quick question I have leds fitted to my r6 front indicators have a resistor each side and flash work correctly. However I've fitted an integrated taillight with indicators do I need to fit a resistor or two for the taillight and if so what size. The symptoms are when I turn the indicator on with the side lights they flash as normal but so is the red light but nothing noticeable to the person behind. Any help would be great thanks[/i]
1992 Yamaha SR125, 2005 Honda XR125, 1998 Yamaha XJ600S, 2000, 2004 Yamaha R6, 2002 Yamaha Fazer, 2004 Honda CBR
Peperami
PostPosted: 12:23 - 11 Jun 2016    Post subject: Reply with quote
Hi Draco87,
It is normal for LED's to have a resistor in series though sometimes this can be integral to the assembly. Some designs have a solid-state driver built-in to supply the LED's with the correct current so no additional components are required.
Without more information on the particular assembly you have its difficult to give a precise answer. As for the value of any such series resistor it very much depends on the safe-current the LED assembly is designed for.
Did you receive any technical info with the LED's which you can share? We really need more information in order to answer your questions.
Regards,
Peperami.
Draco87
PostPosted: 13:02 - 11 Jun 2016    Post subject: Reply with quote
Unfortunately, I had no information for them, only specs are that it was advertised as 12v which is standard. But it is a solid built in unit so unsure if it has built in resistor. The only I can do is take a couple of pictures but not sure how that would help. The option I could do is to try and fit my existing resistor to the rear and see it stops the flashing of the red light
PostPosted: 15:27 - 11 Jun 2016    Post subject: Reply with quote
So the tail light is flashing with the indicators?
LEDs do stuff like that sometimes because they'll run on such low currents.
It suggests you have a poor earth connection somewhere or there is a poorly insulated track on the PCB the lighting unit is attached to allowing crossover of current.
When you hooked up the light unit, how many wires did it have? Was there a seperate earth for the stop/tail and flasher parts?
I have LED bulbs in my clocks and some of them glow when it's raining, this is a tiny current leaking across the wet surface in the back of the clocks.
The resistors pepperami is on about will already be fitted so your LED light clusters "plug and play" at 12V so don't worry about that. The ones that were fitted al;ng wth your front flashers will have been ballast resistors to increase the current load so your indicator relay flashes.
The whole idea of fitting ballast resistors with LED flashers so they work with the original relay strikes me as a bit of a nonsense. When I've done it, I use an electronic flasher relay and no ballast, otherwise they use no less power than the normal bulbs.
In fairness, I've gone right off LED taillights. They seem to be no more reliable, they are very narrow angle and therefore difficult to see, more expensive and it is often difficult to differentiate the stop from the tail. They are also prone to nonsense like you describe above due to tiny current leaks about the place that wouldn't bother an incandescent bulb.
I only use LED bulbs in places where the bulb is a pain in the arse to get at (eg clocks) or on bikes with pathetic charging systems. I've shitcanned all the LED tail lght bulbs I had and put filament ones back in.
Draco87
PostPosted: 07:03 - 12 Jun 2016    Post subject: Reply with quote
When you hooked up the light unit, how many wires did it have? Was there a seperate earth for the stop/tail and flasher parts?.
I must admit it would make sense of suggesting poor ground, on my old lights there were four black wires; I never tried them on the other two from the new lights. As when I fitted them they seemed fine the only reason I noticed the brake light flash with the indicators because I replaced the reg/rec and to test charging system I checked battery under load which is when I noticed it.
Without checking it had: five wires two yellow, one red, one green and one black. On the old set there were two extra black wires
The last post was made 9 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.9 - MySQL Queries: 13 - Page Size: 47.44 Kb
