| Draco87 |
 Draco87 Renault 5 Driver
| Peperami |
 Peperami Derestricted Danger
| Draco87 |
 Posted: 15:27 - 11 Jun 2016 Post subject: |
So the tail light is flashing with the indicators?
LEDs do stuff like that sometimes because they'll run on such low currents.
It suggests you have a poor earth connection somewhere or there is a poorly insulated track on the PCB the lighting unit is attached to allowing crossover of current.
When you hooked up the light unit, how many wires did it have? Was there a seperate earth for the stop/tail and flasher parts?
I have LED bulbs in my clocks and some of them glow when it's raining, this is a tiny current leaking across the wet surface in the back of the clocks.
The resistors pepperami is on about will already be fitted so your LED light clusters "plug and play" at 12V so don't worry about that. The ones that were fitted al;ng wth your front flashers will have been ballast resistors to increase the current load so your indicator relay flashes.
The whole idea of fitting ballast resistors with LED flashers so they work with the original relay strikes me as a bit of a nonsense. When I've done it, I use an electronic flasher relay and no ballast, otherwise they use no less power than the normal bulbs.
In fairness, I've gone right off LED taillights. They seem to be no more reliable, they are very narrow angle and therefore difficult to see, more expensive and it is often difficult to differentiate the stop from the tail. They are also prone to nonsense like you describe above due to tiny current leaks about the place that wouldn't bother an incandescent bulb.
I only use LED bulbs in places where the bulb is a pain in the arse to get at (eg clocks) or on bikes with pathetic charging systems. I've shitcanned all the LED tail lght bulbs I had and put filament ones back in. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Draco87 |
 Posted: 07:03 - 12 Jun 2016 Post subject: |
| stinkwheel wrote: | So the tail light is flashing with the indicators?
When you hooked up the light unit, how many wires did it have? Was there a seperate earth for the stop/tail and flasher parts?. |
I must admit it would make sense of suggesting poor ground, on my old lights there were four black wires; I never tried them on the other two from the new lights. As when I fitted them they seemed fine the only reason I noticed the brake light flash with the indicators because I replaced the reg/rec and to test charging system I checked battery under load which is when I noticed it.
Without checking it had: five wires two yellow, one red, one green and one black. On the old set there were two extra black wires ____________________ 1992 Yamaha SR125, 2005 Honda XR125, 1998 Yamaha XJ600S, 2000, 2004 Yamaha R6, 2002 Yamaha Fazer, 2004 Honda CBR |
The last post was made 9 years, 248 days ago. Instead of replying here, would creating a new thread be more useful? |
