drz400sm not starting
hondakawasaki
PostPosted: 15:10 - 12 Jun 2016    Post subject: drz400sm not starting Reply with quote
hi all Very Happy
anyone have any idea on this, go to start it with the electric start and i hear a click coming from the indicator relay under the head light?
got home yesterday cut the bike out went to start it 2 min later and just hear a click every time i push the electric start?
a few hours later go to start it again and it started straight up Rolling Eyes get home after a 20 min ride cut bike out same thing wont start and i hear a click under the headlight
go to bike this morning and push the electric start button a few times hear a few clicks under head light then it started same thing after a 20min ride come home wont start again Neutral
PostPosted: 15:20 - 12 Jun 2016    Post subject: Reply with quote
Check your earth and connections.
hondakawasaki
PostPosted: 15:30 - 12 Jun 2016    Post subject: Reply with quote
thanks for the reply Thumbs Up
checked all wires and connections everything looks fine Neutral
also if i short out the 2 connections on the starter relay with a screw driver the bike will start?
PostPosted: 15:36 - 12 Jun 2016    Post subject: Reply with quote
You mean if you bypass the relay it starts fine everytime?
Meatybeaty
Hi sounds like the clicking you hear is the relay, and that sounds fine , have you tried cleaning out the starter button switch , could have some corrosion/muck in there Thumbs Up
PostPosted: 15:39 - 12 Jun 2016    Post subject: Reply with quote
Surely if the relay is clicking it would mean the switch is fine as it's clicking when the OP hits the switch. I would expect it to be a duff battery connection or similar, but OP says they're fine. Thinking
Suntan Sid
PostPosted: 15:40 - 12 Jun 2016    Post subject: Reply with quote
Had similar problems on my DRZ400E.
I don't know if the wiring is similar, but on mine the main fuse was mounted on the L/H side of the seat subframe. Over the years, taking the seat on and off had rubbed the insulation off on one of the wires.
I renewed the bit of wire and the problem went away!
hondakawasaki
PostPosted: 15:43 - 12 Jun 2016    Post subject: Reply with quote
yeah the starter relay under the seat, i join the 2 screws up and it starts
but when i go to start with the electric start button the indicator relay under the headlight clicks?
yeah checked the starter button looks brand new inside
Meatybeaty
PostPosted: 15:46 - 12 Jun 2016    Post subject: Reply with quote
Easy to check ,get the multimeter onto the starter motor hold down the start button and see if you get 12v at the starter motor, could be starter motor itself
PostPosted: 15:54 - 12 Jun 2016    Post subject: Reply with quote
Change/swap your starter relay.
DRZ4Hunned
PostPosted: 16:00 - 12 Jun 2016    Post subject: Reply with quote
I had a similar problem with my old yamaha 125, I had to hit the starter motor with a block of wood to get it to start. From what I can remember it was the brushes inside the starter motor.
DRZ400-SM
FZS600
hondakawasaki
PostPosted: 21:16 - 12 Jun 2016    Post subject: Reply with quote
so went to start the bike again heard the flasher relay under the headlight click a few times and it started up again must of turned it off and started it atleast 20 times
took it for a ride around the block and it wouldnt start again
can a defective flasher relay stop the bike starting?
thanks
Meatybeaty
PostPosted: 07:35 - 13 Jun 2016    Post subject: Reply with quote
Its pointing toward the starter motor, to make sure its not the side stand/ indicator relay , put down the side stand with the bike in gear ,pull in the clutch and try to start, if there is no click then that relay is working and the bike wont start, as you can see from the diagrams the wiring flows thro that relay to the starter relay, when you get the click it means the starter relay has worked and ready to fire the starter moto
hondakawasaki
PostPosted: 21:08 - 13 Jun 2016    Post subject: Reply with quote
ok i have circled what clicks when i go to start it, thats under the head light i thought it was the flasher relay for the indicators?
the starter relay does not click when i try start it, i can start it by touching the 2 terminals on the starter relay together with a screw driver
how would i go about testing everything i have a multimeter?
Meatybeaty
PostPosted: 22:09 - 13 Jun 2016    Post subject: Reply with quote
If that relay isnt clicking then its faulty , second fault page when not clicking.Do you have the workshop manual , will need it to check components/relays Thumbs Up
hondakawasaki
PostPosted: 02:53 - 15 Jun 2016    Post subject: Reply with quote
thanks for the help Smile im now 99.9% sure its the starter relay, can tap it with a spanner and it will start everytime lol
The last post was made 10 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 90.61 Kb
