Gearbox is a bit rumbly
haroman666
PostPosted: 18:58 - 12 Jun 2016    Post subject: Gearbox is a bit rumbly Reply with quote
Just after a second opinion/suggestion.
After an epic day at Santa Pod last year with some BCF boys, my gearbox has felt shitty. (CBR600F)
A bit sloppy with shifting, not very crisp feeling at all.
And the most noticable issue since has been a rumbling sensation with the engine running that goes away when the clutch is disengaged.
So I get the feeling that I may have killed my gearbox output shaft bearing(s).
I've had the front sprocket cover off to see if I can give it a wiggle but I couldn't do anything conclusive.
Should I whip the engine casing off (clutch side) and give the clutch basket a wiggle? And give the other end of the output shaft a wiggle too.
OR is there a "proper" way to look into this?
sickpup
Old Timer
PostPosted: 17:18 - 14 Jun 2016    Post subject: Reply with quote
Change the oil and filter.
haroman666
PostPosted: 18:26 - 14 Jun 2016    Post subject: Reply with quote
Have done twice since. No change.
sickpup
Old Timer
PostPosted: 18:32 - 14 Jun 2016    Post subject: Re: Gearbox is a bit rumbly Reply with quote
This is normal
You could adjust the chain but if its really on its way out the seal will probably go before the bearing puking out oil which will give you a warning.
The last post was made 10 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 40.16 Kb
