| Yonder |
 Yonder L Plate Warrior
| Pjay |
 Pjay World Chat Champion
| af1 |
 af1 Borekit Bruiser
 Posted: 19:58 - 13 Jun 2016 Post subject: |
You need to look back at the history of the bike , why did they stop using it ?
What have you done to the bike before riding it ?
You need to check the engine over, clean carb, change 2 stroke oil filter.
clean power valve, change crank seals (they will have probably started leaking.
This can cause a lean mixture and seizure)
Did you change the gear oil ?
The carb jets could be blocked ? Unrestricted these bikes will do 85 to 90 mph.
Somethings wrong ! The piston by not being used could have gummed up.
Take the head and barrel off , clean rings , check clearance The piston may be worn.
A bike with long storage will have many problems. Seized chain will reduce power,
brakes stuck on etc
These are worth a few quid. Sell it before you break it. It's not like a pile of
shit 4 stroke.....
Other tests are compression test , looking for worn piston rings etc
leak down test, paticularly looking for air leak , which will kill the engine, crank , pistons....
Other 2 stroke problems can be that the exhaust has gummed up, causing back pressure, lack of performance.....
Pictures would be nice btw |
| Yonder |
| Yonder |
 Posted: 20:12 - 13 Jun 2016 Post subject: |
| af1 wrote: | You need to look back at the history of the bike , why did they stop using it ?
brakes stuck on etc
shit 4 stroke.....
Thanks for the advice Sniffer, I refuse to believe it's supposed to be like this so I'll start working my way through the list. I wouldn't be surprised if it has an air leak somewhere leaning it out as it has indeed been standing for a while, seals have likely dried out and cracked etc. I guess lean running would explain the bogging during initial throttle? With the throttle closed it will roll along on the flat, but opening it to 1/4-1/2 actually slows the bike like putting the brake on!
It's actually in really nice cosmetic condition under the dust. I'll snap a few pics and get them uploaded. Don't worry, I have no intentions of breaking it, I'd actually really like to get it up and running properly for commuting if I can. |
| redeem ouzzer |
| af1 |
 af1 Borekit Bruiser
| Yonder |
 Posted: 20:48 - 13 Jun 2016 Post subject: |
As requested, here is the dusty beast:
https://i64.tinypic.com/106kk6x.jpg
https://i68.tinypic.com/bl7aq.jpg
https://i66.tinypic.com/if1nbb.jpg
https://i64.tinypic.com/335cemh.jpg
As you can see no YPVS on this engine, apparently they only came in from mk2 onwards (the round barrel engine) and this is a mk1.
My dad actually had the carb cleaned ultrasonically by a garage a few months ago, so it shouldn't be that. I took the carb apart and the jet is on the bottom clip which is richer than spec, yet the bike still feels lean - it does actually run slightly better (more low rev power) with the choke open, particularly when cold...
Nice pics btw! Some spotless classic 2t's there. |
| redeem ouzzer |
| Alawson68 |
 Alawson68 Renault 5 Driver
| Yonder |
| Ariel Badger |
 Ariel Badger Super Spammer
| Enduro Numpty |
 Enduro Numpty Could Be A Chat Bot
| Alawson68 |
| spnorm |
 spnorm Crazy Courier
 Posted: 06:48 - 14 Jun 2016 Post subject: |
That's a lovely little bike and just wants the engine sorting. I couldn't quite afford one when I was a 17 year old learner in 1986, so bought a 125 Superdream instead
They weren't that pesky when restricted, but could be if they'd been tuned. I know a lad local to me had one which was virtually as fast as my RD250LC |
| Yonder |
| redeem ouzzer |
| Alawson68 |
| Wednesday Biker |
 Wednesday Biker Spanner Monkey
The last post was made 10 years, 137 days ago. Instead of replying here, would creating a new thread be more useful? |
