RD125LC - they can't be this bad?!
Yonder
PostPosted: 19:45 - 13 Jun 2016    Post subject: RD125LC - they can't be this bad?! Reply with quote
I've inherited a Yamaha RD125LC from my dad, which I've just taken out for a spin. Choke open or closed, hot or cold, it's absolutely useless to the point of being dangerous!
On a flat road it has huge difficulty pulling up to 30mph, opening the first 1/2 of the throttle actually bogs and slows the bike down. Pinning the throttle to the stop it will creep up by 1mph every 5 seconds or so. This is with between 3 and 5k RPM showing on the dial. Over 7k it will pull pretty hard. It's not modified in any way.
I know it's a 125cc 2t, but I've just come back from Thailand riding 100-125cc 4t's and they have a HUGE amount more pull at 1.5k RPM than this RD does at 5k. Surely they can't be this bad as to be actively dangerous? Honestly a push bike would be significantly quicker. It must be broken in some way?
Pjay
PostPosted: 19:53 - 13 Jun 2016    Post subject: Reply with quote
It's a 2 stroke, it will be terrible at 3k, keep the revs up, as like you said, it pulls at 8k, this means it works as intended.
af1
PostPosted: 19:58 - 13 Jun 2016    Post subject: Reply with quote
You need to look back at the history of the bike , why did they stop using it ?
What have you done to the bike before riding it ?
You need to check the engine over, clean carb, change 2 stroke oil filter.
clean power valve, change crank seals (they will have probably started leaking.
This can cause a lean mixture and seizure)
Did you change the gear oil ?
The carb jets could be blocked ? Unrestricted these bikes will do 85 to 90 mph.
Somethings wrong ! The piston by not being used could have gummed up.
Take the head and barrel off , clean rings , check clearance The piston may be worn.
A bike with long storage will have many problems. Seized chain will reduce power,
brakes stuck on etc
These are worth a few quid. Sell it before you break it. It's not like a pile of
shit 4 stroke.....
Other tests are compression test , looking for worn piston rings etc
leak down test, paticularly looking for air leak , which will kill the engine, crank , pistons....
Other 2 stroke problems can be that the exhaust has gummed up, causing back pressure, lack of performance.....
Pictures would be nice btw
Yonder
PostPosted: 20:02 - 13 Jun 2016    Post subject: Reply with quote
Fair enough comment, I know small 2t's aren't about low rev torque but this just seems ridiculous. I probably should have mentioned I've ridden a 110 semi-auto 2t before and it was quite happy pulling along flatly but steadily, keeping up with traffic, at low revs...
I was hoping to use this bike to commute through the city a couple of days a week, if I have to have it screaming at 8k just to cruise along with 30-40mph traffic it'll be up for sale!
Yonder
PostPosted: 20:12 - 13 Jun 2016    Post subject: Reply with quote
brakes stuck on etc
shit 4 stroke.....
Thanks for the advice Sniffer, I refuse to believe it's supposed to be like this so I'll start working my way through the list. I wouldn't be surprised if it has an air leak somewhere leaning it out as it has indeed been standing for a while, seals have likely dried out and cracked etc. I guess lean running would explain the bogging during initial throttle? With the throttle closed it will roll along on the flat, but opening it to 1/4-1/2 actually slows the bike like putting the brake on!
It's actually in really nice cosmetic condition under the dust. I'll snap a few pics and get them uploaded. Don't worry, I have no intentions of breaking it, I'd actually really like to get it up and running properly for commuting if I can.
redeem ouzzer
PostPosted: 20:29 - 13 Jun 2016    Post subject: Reply with quote
They have cock all bottom end when derestricted but shouldn't bog down. Clean the carb, paying special attention to the emulsion tube and air circuit which should be spotless.
Be a REAL MAN!
af1
PostPosted: 20:37 - 13 Jun 2016    Post subject: Reply with quote
Has the bike got a power valve, they got one after 1983 I think
they always seize , and cause poor performance .....
I love 2 stroke 125's , top speed of 105 officer....
https://i945.photobucket.com/albums/ad293/fatterhatter/Aprilia%20AF1%20resto/CNV000131_zps42a77497.jpg
They are very reliable , if maintained, if it's not working properly , it will seem slow, but twice the power has higher gearing. https://i945.photobucket.com/albums/ad293/fatterhatter/sprort_zpsu5m6lfgx.jpg
Yonder
PostPosted: 20:48 - 13 Jun 2016    Post subject: Reply with quote
As requested, here is the dusty beast:
https://i64.tinypic.com/106kk6x.jpg
https://i68.tinypic.com/bl7aq.jpg
https://i66.tinypic.com/if1nbb.jpg
https://i64.tinypic.com/335cemh.jpg
As you can see no YPVS on this engine, apparently they only came in from mk2 onwards (the round barrel engine) and this is a mk1.
My dad actually had the carb cleaned ultrasonically by a garage a few months ago, so it shouldn't be that. I took the carb apart and the jet is on the bottom clip which is richer than spec, yet the bike still feels lean - it does actually run slightly better (more low rev power) with the choke open, particularly when cold...
Nice pics btw! Some spotless classic 2t's there.
redeem ouzzer
PostPosted: 20:52 - 13 Jun 2016    Post subject: Reply with quote
Pipe is wrong, it's off a mk3 or TZR. Break it, the clocks will do a couple of hundred quid.
Be a REAL MAN!
Alawson68
PostPosted: 21:02 - 13 Jun 2016    Post subject: Reply with quote
if you pull the choke out and it likes it, it's jetted wrong. Looks like he's changed the pipe and left the jetting as standard which means it's running lean and you're heading for a sieze. This generally happens north of 70mph on a country lane.
The crankcase seals may have gone as well. I had one of these 31 years ago to the day (im 48 tomorrow) and it was phenomenal but had to be kept in the power band 8k - 12k. To realise the 'cult of elsie' you need to give it the beans, but not until you've sorted the jetting out, or you'll bin it in a hedge.
1968 Vespa Primavera
2016 KTM Duke 390
Yonder
PostPosted: 21:08 - 13 Jun 2016    Post subject: Reply with quote
I'm aware the pipe is from a later model, should be an all black number without a seperate end can but there you go. I wonder if could be a significant cause of low rev issues in that the pipe is designed for a YPVS engine, which in this case it isn't attached to. As far as I know it's had that pipe on for years, certainly since before my dad had it.
Good point about the jetting Alawson. I'll either get that looked at or source an original pipe.
PostPosted: 21:17 - 13 Jun 2016    Post subject: Reply with quote
The bike in the pics is a mk1. The mk2 (16" front wheel) didn't have a power valve either. The late RDZ125 had a power valve.
Katy
Ariel Badger
PostPosted: 21:48 - 13 Jun 2016    Post subject: Reply with quote
Lovely little bike, please do not break it.
Enduro Numpty
PostPosted: 21:55 - 13 Jun 2016    Post subject: Reply with quote
As above!! Would be a crime to break it Crying or Very sad
Alawson68
PostPosted: 23:11 - 13 Jun 2016    Post subject: Reply with quote
That would be why, the ypvs pipe is designed to work with the variable exhaust timings, where as the standard unit is designed to work with fixed exhaust timings, hence the poor running at low revs, when the valve is partly open
Change the pipe for standard, put the jets back to stock and away you go
2016 KTM Duke 390
spnorm
PostPosted: 06:48 - 14 Jun 2016    Post subject: Reply with quote
That's a lovely little bike and just wants the engine sorting. I couldn't quite afford one when I was a 17 year old learner in 1986, so bought a 125 Superdream instead Embarassed
They weren't that pesky when restricted, but could be if they'd been tuned. I know a lad local to me had one which was virtually as fast as my RD250LC
Yonder
PostPosted: 08:44 - 14 Jun 2016    Post subject: Reply with quote
Don't worry, the bike won't be getting broken by me. It might get sold in one piece in a worse case scenario, but definately not broken.
Looks like the thing to do now is source a mk1 exhaust, which having a scan around the internet seems easier said than done - couldn't find any!
redeem ouzzer
PostPosted: 19:19 - 14 Jun 2016    Post subject: Reply with quote
If you can't find a stock pipe then a Micron will do, however the later big can ones benefit from surgery.
Be a REAL MAN!
Alawson68
PostPosted: 20:22 - 14 Jun 2016    Post subject: Reply with quote
Don't forget to rejet if using a micron, if you're going for an aftermarket pipe a K&N air filter will help you get the best out of it
2016 KTM Duke 390
Wednesday Biker
PostPosted: 19:06 - 15 Jun 2016    Post subject: Reply with quote
Its not running right.
I had one and the wheel comes up on acceleration in first and second.
The powerband was about 7 or 8k if I remember and are a bit depressing under that.
Probably not as fast as I remember but they were pretty pokey, so yours just doesn't sound right.
There might be a washer thingy that needs chiselling out at the front of the pipe. Was on mine.
The last post was made 10 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 107.08 Kb
