Xtrs issue
Betco
PostPosted: 19:32 - 15 Jun 2016    Post subject: Xtrs issue Reply with quote
I'm not very good with this writing thing so I have made a video of what the issue is if anyone can help
Thanks Steve
https://youtu.be/GBXDZW211uE
charlie74
PostPosted: 19:37 - 15 Jun 2016    Post subject: Reply with quote
spam vid link at a guess, youtu.be... I aint clicking it..
Betco
PostPosted: 19:44 - 15 Jun 2016    Post subject: Reply with quote
No I'm not but I can't write very good but I'm having issues with my bike only going to 7,500 revs
It's a standard YouTube like
charlie74
PostPosted: 20:05 - 15 Jun 2016    Post subject: Reply with quote
https://www.youtube.com/watch?v=GBXDZW211uE
that's a clean link to your vid
and don't worry about your typing skills, you would be surprised at what we have managed to decipher,
just give us as much info as possible and what tools you have available and folks will do what they can
Evil Hans
PostPosted: 20:28 - 15 Jun 2016    Post subject: Reply with quote
Couldn't really be bothered with watching the whole video, so sorry if these questions were answered after the first minute or so.
Does it rev above 7500 in neutral?
Have you looked at or changed the air filter?
Have you checked for air leaks around the carb?
Have you fitted new HT lead/cap.
Has it always had this problem or has it developed recently?
Evil Hans
PostPosted: 20:33 - 15 Jun 2016    Post subject: Reply with quote
... oh, and did you really mean 0.008 for the valve clearance? I think it should be 0.08
Betco
PostPosted: 20:37 - 15 Jun 2016    Post subject: Reply with quote
New filter
New cdi
New ht
New ht cap
New spark
Clean carb
Checked for leaks with brake cleaner and carb cleaner
Sometime it will rev up in neutral and sometimes not
Yes 0.08 on both
charlie74
PostPosted: 20:47 - 15 Jun 2016    Post subject: Reply with quote
the way it sounded in the vid was like it hits a limiter of some sort,
or like car ht leads breaking down under load
so I would go over all the electricals and give a squirt of wd in the connectorblocks, undo the ones that look dirty/brown and check for rust and finally check your earthing points,
and just to be sure, when you say new.. is that new new or new to you off ebay 2nd hand?
Betco
PostPosted: 20:52 - 15 Jun 2016    Post subject: Reply with quote
New new
Also put a 110 carb injector to see if that would work as the filter is a cone
It's had the issue since I got the bike
Also new fuel line and breather
charlie74
PostPosted: 22:44 - 15 Jun 2016    Post subject: Reply with quote
Betco wrote:
New new
seems a bit high,, what colour deposits are on the spark plug? grey/brown.. or white/grey
PostPosted: 08:39 - 16 Jun 2016    Post subject: Reply with quote
Tappet gaps are right, but were they done with the engine stone cold?
Although that sounds electrical. It's mis-firing rather than firing poorly.
Betco wrote:
New ht
Coil, or coil and lead? If it's coil and lead then it sounds like you've replaced everything in the ignition circuit, so I'd hazard a guess at a bad connection.
Either the main earth, the CDI plug, or check that the low tension leads on the coil at secure - I had both the latter two issues on my CG125 copy-engine, which produced similar behaviour.
If it's not that, I'd suspect the pickup coil on the stator, but I'd check all the connections first.
Snowdonia Rider
PostPosted: 08:57 - 16 Jun 2016    Post subject: Reply with quote
When a similar problem happened with my bike it ended up being a problem with the spark plug cap not connected to the lead properly.
Betco
PostPosted: 09:41 - 16 Jun 2016    Post subject: Reply with quote
Yes it was cold and at tdc
I didn't change the coil it self as it was in tolarance I do have a spare tho so I can try it
Steve
PostPosted: 11:21 - 16 Jun 2016    Post subject: Reply with quote
Worth a try, it sound like something in the electrical system and you've ruled out pretty much everything else. I had to crimp my spade connectors a bit to get them tight on the (aftermarket, because racebike) coil.
The last post was made 10 years, 122 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 77.39 Kb
