| root |
 root Two Stroke Sniffer
| mudcow007 |
 mudcow007 World Chat Champion
 Posted: 10:46 - 17 Jun 2016 Post subject: |
| root |
 Posted: 07:27 - 18 Jun 2016 Post subject: |
Cheers. That video doesnt show the assembly of the springs and levers at the side...why did i remove them lol...
Also ive got a tube that comes off the petrol tank and has a gold screw on end....unsure where that goes back hahahaha...
know the other goes on top of carb...
like i said...the bikes a project and i think from now on ill take pics when taking things apart lol |
| Commuter_Tim |
 Posted: 20:36 - 18 Jun 2016 Post subject: |
| root wrote: |
Take pics now, and post here, then we can point out what's what.
Gold screw sounds odd, seems like your describing the brass screw bottom of the carb which sits next to the fuel drain hose?
The CG fuel pipe running from carb to petrol tank only has a fuel hose and hose clip and fuel tap on the end though iirc.
Regarding springs, you mean in the throttle tube/needle assembly?
If so my CG carb the spring was symmetrical and didn't appear to matter its orientation.
The images below may help, it depends on your CG copy year but I doubt the main carb and fuelling assembly varies much.
https://storage.googleapis.com/pfk-megabucket-732/HPL/Images/13KCHWU1/IMGE/F__1200.jpg
https://storage.googleapis.com/pfk-megabucket-732/HPL/Images/13KCHWU1/IMGE/E__1500.jpg ____________________ The above post is most likely nonsensical.
I ride a Bandit 600... badly. |
| root |
 Posted: 11:39 - 25 Jun 2016 Post subject: |
https://i66.tinypic.com/2m77xvt.jpg
Thank you..
this is the pipe that i dont know where it goes...
The end without brass coloured bit goes onto the fuel tap under the petrol tank and i dont know where the other end attaches.
i think its some kind of vacuum. I cant get fuel through the tap without this pipe attached... |
| Meatybeaty |
 Meatybeaty World Chat Champion
 Posted: 15:17 - 25 Jun 2016 Post subject: |
Hi , is your fuel tap manual (gravity) or Automatic (vacuum) if its vacuum the you should have one pipe from the fuel tap to the carb , and one pipe from the fuel tap to the intake duct to create the vacuum to draw the petrol from the tank  |
| root |
| Meatybeaty |
 Posted: 19:50 - 25 Jun 2016 Post subject: |
Hi , no stop tap so it must be vacuum ,thats where your other pipe comes in  |
The last post was made 9 years, 225 days ago. Instead of replying here, would creating a new thread be more useful? |
