CG125 carb assembly
root
PostPosted: 10:43 - 17 Jun 2016    Post subject: CG125 carb assembly Reply with quote
Good morning gents. I have a superbyke rbp 125, which has a cg125 engine.
i took the carb apart to clean it and I cant figure out how to reassemble....just the side parts with springs and gold levers...anyone got any pics or something on how to reassemble. Cheers
mudcow007
PostPosted: 10:46 - 17 Jun 2016    Post subject: Reply with quote
voila
https://www.youtube.com/watch?v=BsnQOH4ECLs
root
PostPosted: 07:27 - 18 Jun 2016    Post subject: Reply with quote
mudcow007 wrote:
Cheers. That video doesnt show the assembly of the springs and levers at the side...why did i remove them lol...
Also ive got a tube that comes off the petrol tank and has a gold screw on end....unsure where that goes back hahahaha...
know the other goes on top of carb...
like i said...the bikes a project and i think from now on ill take pics when taking things apart lol
Commuter_Tim
PostPosted: 20:36 - 18 Jun 2016    Post subject: Reply with quote
Take pics now, and post here, then we can point out what's what. Thumbs Up
Gold screw sounds odd, seems like your describing the brass screw bottom of the carb which sits next to the fuel drain hose?
The CG fuel pipe running from carb to petrol tank only has a fuel hose and hose clip and fuel tap on the end though iirc.
Regarding springs, you mean in the throttle tube/needle assembly?
If so my CG carb the spring was symmetrical and didn't appear to matter its orientation.
The images below may help, it depends on your CG copy year but I doubt the main carb and fuelling assembly varies much.
https://storage.googleapis.com/pfk-megabucket-732/HPL/Images/13KCHWU1/IMGE/F__1200.jpg
https://storage.googleapis.com/pfk-megabucket-732/HPL/Images/13KCHWU1/IMGE/E__1500.jpg
I ride a Bandit 600... badly.
root
PostPosted: 11:39 - 25 Jun 2016    Post subject: Reply with quote
https://i66.tinypic.com/2m77xvt.jpg
Thank you..
this is the pipe that i dont know where it goes...
The end without brass coloured bit goes onto the fuel tap under the petrol tank and i dont know where the other end attaches.
i think its some kind of vacuum. I cant get fuel through the tap without this pipe attached...
Meatybeaty
PostPosted: 15:17 - 25 Jun 2016    Post subject: Reply with quote
Hi , is your fuel tap manual (gravity) or Automatic (vacuum) if its vacuum the you should have one pipe from the fuel tap to the carb , and one pipe from the fuel tap to the intake duct to create the vacuum to draw the petrol from the tank Thumbs Up
root
PostPosted: 19:00 - 25 Jun 2016    Post subject: Reply with quote
i think its a vacuum one for sure..its not a typical cg one as it doeant have a lever on it to turn it off and choose reserve fuel..ill look at the intake duct area tomorrow..thank you very much Smile
somewhere near the air filter right? Haha
Meatybeaty
PostPosted: 19:50 - 25 Jun 2016    Post subject: Reply with quote
Hi , no stop tap so it must be vacuum ,thats where your other pipe comes in Thumbs Up
The last post was made 9 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 57.81 Kb
