| CHR15 |
 CHR15 Turbo nutter bastard
| Pjay |
 Pjay World Chat Champion
| Pjay |
| Andy_Pagin |
 Andy_Pagin World Chat Champion
| Andy_Pagin |
| CHR15 |
 Posted: 13:59 - 19 Jun 2016 Post subject: |
The machine is a mitutoyo bx303 cmm.
It's basically a very accurate measuring machine that uses a probe attached to a gantry to produce point cloud data, ie. Hole centres, faces, edges ect...
The idea being that you can verify that components are manufactured to drawing, or copy existing components that have complex features that would be difficult to measure by hand.
https://www.cmmsales.co.uk/cmmsales/machines/Mitutoyo%20BX303.htm ____________________ Turbocharged drag thing / project death weapon / GK73A
Ste: I'm not entirely sure how you'd go about verbally abusing someone with a potato but I'm sure it's possible. |
| Andy_Pagin |
 Posted: 14:26 - 19 Jun 2016 Post subject: |
Ok. The thing on the interface port is a dongle, basically this is an electronic licence for the software, take off the dongle and the program refuses to work.
The interface itself is I strongly suspect IEEE488, which back in the day was the de-facto choice for interfacing computers with stuff, like USB today really.
You can still buy IEE488 cards, so in theory you could bung one on a modern PC and run the old DOS program through an emulator. ____________________ They're coming to take me away, ho-ho, hee-hee, ha-haaa, hey-hey,
Yamaha Vity -> YBR125 -> FZS600 Fazer -> FZ1-S Fazer |
| MarJay |
 MarJay But it's British!
 Posted: 14:41 - 19 Jun 2016 Post subject: Re: putting a dos program on a new machine |
| CHR15 wrote: | I've bought a piece of equipment, which was manufactured in 1989.
the machine communicates to a pc through an interface box, the pc then runs a dos program to give you the info you need.
the problem is, if the computer toasts itself, im a bit stuck.
so, question is, can i somehow suck the program out this pc, make a few copies for safety and put it on something modern.
i also need to be able to connect the interface box to the new pc, i dont know what kind of connector it is and the expansion card doesn't look like any kind of expansion socket from any pc i've seen.
the program im interested in is called geopak, but i'm not sure if other things need to come with it for it to work.
The program itself is easy peasy. You just copy it onto some media which is readable by a modern machine (floppy would probably be ideal) and copy it to the modern machine. you can use DosBOX to run the program and that is all fine and dandy and all is well with the world.
Except it isn't. Your system there has custom hardware which means you'll need to emulate that somehow. If it is merely a parallel port card and you can plug up the dongle to it, then you might be able to get away with it with a modern equivalent. You'll just need to tweak the DosBOX settings so it runs at native speed just in case it uses CPU clock cycles for timing or something.
However... if that card in that PC is a custom ISA card, you may very well be out of luck. You'll not find a modern PC with an ISA Bus, and so transplanting the card is no longer feasible. You may find an older PC for sale on Ebay with an ISA bus, which might be your best bet but it'll still be as unreliable as the PC you have.
It's a potentially complex problem all hinging on that card sitting in the PC. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| Andy_Pagin |
 Posted: 14:48 - 19 Jun 2016 Post subject: |
Interface is IEE488.
You can still buy them, even one that plugs into a USB port.
Likewise you can buy 3.5" Disk drives.
Hardware shouldn't be a problem.
Finding a DOS emulator that works may be an issue, but until you have the hardware you'll never know.
Quick Google shows IEE488 cards for about £200 new, and 3.5" Drives for £20 or less.
I'm guessing your investment in that super-duper measuring thingy justified a £220 punt on interfacing stuff.
Ultimately the weak point will always be the dongle, if that dies you're buggered, unless the software or hardware manufacturers are still around and willing/able to help. ____________________ They're coming to take me away, ho-ho, hee-hee, ha-haaa, hey-hey,
| wodge |
 wodge Nitrous Nuisance
| CHR15 |
 Posted: 17:13 - 19 Jun 2016 Post subject: |
It hasn't actually failed, the computer works fine.
This was more about long term and also reducing the size of the whole job. It would be nice to have a tiny computer with a usb card that I can connect to the interface box and tuck it all out the way. I can then mount an lcd on the wall behind the machine and it's all nice and modern.
Also, I opened both ends of that grey cable, there's no microchips or anything inside, it's literally just a cable with the cores crimped to pins at both ends. ____________________ Turbocharged drag thing / project death weapon / GK73A
| Andy_Pagin |
| wodge |
 Posted: 17:43 - 19 Jun 2016 Post subject: |
It is very difficult to predict how old dos software will behave on new hardware. There may be timing problems because the software is not expecting everything to happen so quickly with faster computers. There wil almost certainly be driver issues if you want to run it in a windows dosbox.
However, IEEE488 is an old standard communications system for Instrumentation. You can get modern PCI to IEEE488 interface cards and there is a good chance there is other software which can understand the device. In fact you link to one for sale which is using something called inspect3d software.
TBH the last time I linked up something with IEEE I think it used an 800khz (yes, kilohertz) Hewlett Packard computer (HP85) the interface was called hp/ip then! |
| Pjay |
| CHR15 |
 Posted: 19:39 - 19 Jun 2016 Post subject: |
So what we're saying is I need a computer with an isa connector, and try using the original 488 card out of this computer. (Because is has the dongle built into it)
Can you get something like a usb to isa or pci to isa?
How do I suck the software out of the orignional computer? (I think the floppies are calibration backups rather than the program) you have to calibrate the machine to square of the axis and other things.
Is it normal to snigger when saying dongle? ____________________ Turbocharged drag thing / project death weapon / GK73A
| Evil Hans |
 Evil Hans World Chat Champion
| Pjay |
| Andy_Pagin |
| CHR15 |
 Posted: 20:22 - 19 Jun 2016 Post subject: |
Yeah it was in Surrey,
I've just found the orignional order paperwork, it says the card that connects the interface box to the pc is called a 'hpib interface'
Also, for people that were around then, what did £13.5k buy you in '89? ____________________ Turbocharged drag thing / project death weapon / GK73A
| CaNsA |
 CaNsA Super Spammer
 Posted: 20:37 - 19 Jun 2016 Post subject: |
The BIOS on a 1989 pc is unlikely to support that size of drive. ____________________ a.k.a 'Geri'
| CaNsA |
 CaNsA Super Spammer
| Andy_Pagin |
| wodge |
The last post was made 10 years, 86 days ago. Instead of replying here, would creating a new thread be more useful? |
