LED Light bulbs - talk to me
duhawkz
PostPosted: 22:07 - 19 Jun 2016    Post subject: LED Light bulbs - talk to me Reply with quote
So I bought some LED G4 light bulbs to replace the halogen ones in the motorhome, the light fitting in the dining room and sitting room also use G4's nice one so i order a load of them from ebay.
120w down to 6w, Such save, Much efficient, wow
Any how i go home today to find a parcel on the mat, yay light bulbs. I changed all the bulbs in the dining room light fittings, underwhelming they didn't give off enough light to light the room, all bulbs combined where about as bright as bodyguard.
Each light fitting holds 6 G4 bulbs, on halogen bulb was significantly brighter than 6 LED bulbs, the halogens are rated as around 250 lumens, the LED's 180 so while i didn't expect them to be as bright I expected them to at least light the room.
I tried one of the LED bulbs on a battery booster pack and it seemed a work as I originally expected it to, nice and bright. 6 like that would have easily lit the room.
what gives?
Tamsin
PostPosted: 23:16 - 19 Jun 2016    Post subject: Reply with quote
sounds to me like the jump pack was putting out more power than the transformer in the light fitting...
I believe the LED ones require a different transformer but "on grid" electrics are not my forte
Suntan Sid
PostPosted: 23:37 - 19 Jun 2016    Post subject: Re: LED Light bulbs - talk to me Reply with quote
duhawkz wrote:
What gives
Well, despite all the advertising guff your, wonderful, new LED's will blow more often than incandescent, flourescent, or halogen bulbs.
In the grand scheme of things any saving you think you may make, by using less energy, will be spent on replacement LED's!
You'll end up buying them in bulk! Wink
duhawkz
PostPosted: 23:44 - 19 Jun 2016    Post subject: Reply with quote
Yep looks that way, a bit of googling turned up the following
the internet says wrote:
You probably need to replace the power supply with one designed for LEDs. According to various web sites, some LEDs have compatibility issues with transformers designed for halogens. In particular, the power supply may have a minimum load and your all-LED setup uses too few watts: "When replacing with LED bulbs they found they had to keep at least one halogen in the circuit to keep the load high."
which makes sense, when i switched out one of the LED's bulbs for a Halogen everything seems work better, however the halogens put out a soft yellowish light where as the LED's a hard white/blue light so they don't really mix that well
duhawkz
PostPosted: 23:47 - 19 Jun 2016    Post subject: Re: LED Light bulbs - talk to me Reply with quote
Suntan Sid wrote:
duhawkz wrote:
What gives
I bought 30 of the buggers so i'm sorted for a while. Thumbs Up
Jayy
Mr. Ponzi
PostPosted: 00:10 - 20 Jun 2016    Post subject: Reply with quote
Do they actually last longer than normal bulbs?
Rogue_Shadow
PostPosted: 01:06 - 20 Jun 2016    Post subject: Reply with quote
Yep Thumbs Up
Have a 4 bulb light rail in my kitchen & each time a bulb blew I replaced it with a LED equivalent.
Eventually all bulbs were LED and that was just over a year ago.
The sign of a good LED bulb is minimal heat, as heat is a sign of inefficiency & that heat can also cause failure.
When I was running a mix of standard bulbs and LEDs, I could not touch the standard bulbs without burning my finger. But I could press my entire palm against the LEDs without worry.
Admittedly LED's give off intense light in a short area, so your better off getting modern energy saving bulbs, the wierd looking tube ones, for large areas. Yea they need to "warm up" but they are noticeable quicker at doing this compared to the first generation of ES bulbs.
The last post was made 10 years, 2 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 53.8 Kb
