| themadatter |
 themadatter Nova Slayer
| nick.h |
 nick.h World Chat Champion
| White Noise |
 White Noise Mr Dudwee
 Posted: 23:11 - 20 Feb 2005 Post subject: |
by means of an internal combustion engine
From my limited knowledge of them i found that the one i was riding could get upto 55-60 at a push but this was a newish riding schools bike.
WN ____________________ Buy my wife: 96' Yam XJ600s (Diversion)
| themadatter |
| nick.h |
 Posted: 23:15 - 20 Feb 2005 Post subject: |
Are you a fat/tall git, you could be losing top-end that way  ____________________ [Italjet MM5A] ll [Rieju RS1 Evolution] ll [Suzuki GS500e] ll [Suzuki GSX600F] ll [Honda CG125] ll [Pug Elyseo 125] ll [Yamaha YZF750R] ll [Yamaha Thunderace] ll [Yamaha R6] ll [Triumph 955i] ll [Hayabusa RZK3] ll [Suzuki RGV250] ll |
| mchaggis |
 mchaggis World Chat Champion
They're relatively indestructable, they tend to get thrashed a lot because they never go very quickly. If you keep feeding it fresh oil every 1000-1500 miles and make sure it's not running too rich, and that it's carburettor isn't gummed up then there's not a lot else that can go wrong. The Haynes recommended valve tappet clearances are pretty loose and it'd be unsurprising were they done up to zero clearance. 0.03 mm or something is perhaps best.
Watch out for a rumbling and heavy vibration in the footpegs. If you get that, it's likely that your main bearings are giving way. At the end of the day, it's a four stroke 125, it's not meant to go quickly, the 93 (I think) model my Mum has in the garage did about 55 tops (before it knackered a bearing and killed it's spark plug). ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush.  |
| stinkwheel |
 Posted: 23:16 - 20 Feb 2005 Post subject: |
Depends how heavy you are, if there is a headwind and if you are going up a hill.
Given someone of average weight on a level straight with no headwind then 65mph should not be an unreasonable expectation.
I would get myself a workshop manual and do all the stuff listed under a major service/tune up then see how you go. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| dibbster |
 dibbster Nearly there...
| Silky |
 Silky Nova Slayer
 Posted: 00:05 - 21 Feb 2005 Post subject: |
I dont think theres anything to worry about mate. Ive got a 97 model, and that doesnt seem to want to go any higher than 50 at all.
unless we have a similar problem
But i doubt it very much. Bullet proof engines!
Just think, would you rather be going at 50 all day on a CG? or 80 now and then on a wanked up RS?  |
| tony532 |
 tony532 World Chat Champion
| themadatter |
| binge |
 binge Emo Kiddy
 Posted: 03:17 - 21 Feb 2005 Post subject: |
Well Compaired to 260mph on you RS125, Im sure that 55mph does feel very slow  |
| dodsi |
 dodsi Dirty Carny
| mchaggis |
| tony532 |
| Silky |
 Silky Nova Slayer
| JodieWodie |
 JodieWodie Reflective Banana
| pipnet11 |
 pipnet11 Brolly Dolly
| stinkwheel |
 Posted: 20:19 - 21 Feb 2005 Post subject: |
You may find that oiling the speedo cable will give you an extra 5-10mph. It used to on my old 125
What I'm trying to say is the speedo on those bikes was designed in the 1970s. Back then speedos were little more than a guide at best, wildly innacurate at worst. You are all probably doing exactly the same speed on your CG125s. It is a fair bet to say that when you hear the valves bounce, it will be doing somehwere between 65 and 70mph ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| themadatter |
| Silky |
 Silky Nova Slayer
 Posted: 00:58 - 22 Feb 2005 Post subject: |
ok... take back what i said about my top speed being 50.
Just got 60 out of it.
All you need is a nice long straight, good clutch control and a lack of wind.
Oh, and make sure you really use ALL the gears have to give, especially 3rd.
Good luck  |
The last post was made 21 years, 102 days ago. Instead of replying here, would creating a new thread be more useful? |
